Manual brake pedal used as dead pedal in auto trans JK. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 09-19-2011, 05:16 PM Thread Starter
86CJ-07Rubi's Avatar
Since I converted from a manual to an auto during my Hemi swap, I decided to see if one of my extra pedals (the clutch and brake from the manual) would work as a dead pedal/foot rest.
The manual brake pedal works well with about 1-1.5 hours of minor modifications (minor if you have a welder). I realize not everyone has an extra pedal lying around, but for those that want a custom stock pedal look rather than an aftermarket dead pedal, here you go. I can stand on it and it is not going to move.
Here's the final result. The dead pedal is the same height as the gas for the best comfort. I can also get my foot under the dead pedal if I want to put my foot flat on the floor.
I've tried to explain the process in the pic. Basically you would drill a hole in the metal support and then cut a notch for the pedal ball socket to sit into. Then fabricate a bracket to attach the top of the pedal to an unused factory stud.
86CJ-07Rubi is offline
post #2 of 8 Old 09-20-2011, 05:01 AM
neoxxis's Avatar
You're talking about the left pedal?
Isn't it the clutch??
What is a "manual brake pedal" ?
Isn't the brake pedal the same between automatic and manual tranny??
neoxxis is offline
post #3 of 8 Old 09-20-2011, 07:37 AM Thread Starter
In a manual trans JK (and most every manual trans vehicle) the brake pedal is smaller to allow room for a clutch pedal (which is usually the same size). My JK used to be a manual, but when I coverted to an auto (and added the full size brake pedal), I removed the clutch and brake pedal from the manual. I've been calling it the "manual brake pedal" to avoid confusion. The clutch pedal arm bends in a different direction, so I had to use the manual brake pedal in this mod as the dead pedal.
Original manual pedal configuration (not mine):
post #4 of 8 Old 09-20-2011, 07:41 AM
neoxxis's Avatar
Woah... Ok got it!
neoxxis is offline
post #5 of 8 Old 09-20-2011, 10:36 AM
Cool idea I like it. Wonder how much a manual brake pedal is from the dealer
BBirish is offline
post #6 of 8 Old 09-20-2011, 11:57 AM
JK Mountain's Avatar
Pretty cool idea, good write up too.
I don't drink water; fish fuck in it.
Do you feel a desire to dance with other men while behind the wheel of the Prius?
Is it true the car only plays Village People music?
Does it have a light on the dash when you get near a gay bar?
JK Mountain is offline
post #7 of 8 Old 09-20-2011, 01:21 PM Thread Starter
The full size auto brake pedal was $40 so the manual brake pedal should be similar. That makes this dead pedal mod a little cheaper than the aftermarket, but a little harder to install.
post #8 of 8 Old 09-21-2011, 08:28 PM
sweet deal!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42 MTR's
17" Spyderlock Beadlocks
