Home made Quick Disconnects - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 09-17-2011, 07:48 PM Thread Starter
Probably nothing new, but I am cheap. So here is a $50 set of adjustable home made quick disconnects.
Things you will need:
4 x 2"x1/2" -20 bolts
4 x 1/2" -20 rod ends
8 x 1/2" -20 nuts
1'x 1/2" -20 all thread
8 x 1/2" washers
2 x 1/4" tractor pins
1 x something to cut the all thread
1/4" drill bit and drill
I cut the all thred to 5 1/2" lengths and put the rod ends on either side with a jam nut.
The Sway Bar end got a 2" x 1/2" -20 bolt with washer thru the bar with a nut on the inside followed by the rod end and another nut (blue lock tight on the last bolt)
The bottom got a bolt with washer thru the frame bracket followed by a washer and a nut. One this one put the bolt and washers/nuts on, slide on the rod end then use a sharpie to mark where to drill through the bolt.
Remove and drill the bolt with a 1/4" bit
Reinstall as described above and you should be ready to hit the road......and with a pull of the tractor pin and some zip ties you can hit the trail!
09rubicon is offline
post #2 of 15 Old 09-21-2011, 11:44 AM
scotty6336's Avatar
Those are actually pretty badass. Pretty much the same in design as my JKS discos...which were like 130 bucks or something. Nice work.
07 X..3.5 Rock Krawler mid arm, teraflex steering stabilizer, JKS quick discos, smittibilt rocker guards, poison spyder BFH front and rear, XRC8 winch, 37" pitbull rockers on TWF's, CB, Rock lights, KC Stinger lights, Hella pillar lights, High Lift on hood, Cut flares, 3 amps, polk db front, Kicker type R rears, 1 12" P3, Viper throttle, Yukon 5.13's, Pure jeep truss/gussets, home brew switch panel/corner armor etc etc
scotty6336 is offline
post #3 of 15 Old 12-31-2011, 10:52 AM Thread Starter
Just an update. 3+ months and a few thousand miles and two wheeling trips.....no issues! They are no louder than comparable units from RK or Pro-Comp. No slop, and the heim joints are holding up well.
post #4 of 15 Old 01-05-2012, 11:08 AM
Where did you get the female heim ends from?
- Burchie
Burchie is offline
post #5 of 15 Old 01-09-2012, 10:11 PM Thread Starter
Got the at OSH, about $10 each. I believe Tractor Supply and Grainger carry them as well as Fastenal.
post #6 of 15 Old 07-03-2012, 05:32 PM
ovrthetop's Avatar
Where did you find the threaded rod at? IM having trouble coming up with 1/2"-20 rod.
Cincinnati JKOs join our Facebook group
ovrthetop is offline
post #7 of 15 Old 07-04-2012, 02:06 AM Thread Starter
I bought a 36" section from OSH. You should be able to get it at about any hardware store. Home Depot, Lowes, OSH, ACE, all carry it.
post #8 of 15 Old 07-04-2012, 02:33 AM
ADDICTION II build begins....
TXROCK's Avatar
looks good!
U.S. Army
TXROCK is offline
post #9 of 15 Old 07-04-2012, 07:34 AM
neoxxis's Avatar
Looks way better than most "home made" links I've seen...
Especially what we see in the "WTF people were thinking" kind of threads...
Thinking of doing something similar, and looking at this page I have all kinds of good ideas!
http://www.mcmaster.com/#rod-ends/=i9cbe3
neoxxis is offline
post #10 of 15 Old 02-06-2013, 02:41 PM
Send a message via AIM to rerard2 Send a message via Yahoo to rerard2
Thanks for posting this. I've had it bookmarked for a while and finally got around to gathering the parts. I went to OSH and got everything for $70 out the door, guessing it was a little more expensive due to locale. The rod ends were the bulk of it almost $12ea.
rerard2 is offline
post #11 of 15 Old 02-07-2013, 01:00 AM
Now that's pretty badass, great job
post #12 of 15 Old 02-08-2013, 12:30 PM Thread Starter
Yeah, I noticed their prices went up around new years.
Thanks, they are still holding up great.
post #13 of 15 Old 02-13-2013, 12:33 AM
DeucesALLin's Avatar
DONE...
You really stretched my mod budget!
Soon to be a vendor!!!
Looking for a good Rat Rod JK donor vehicle.
DeucesALLin is offline
post #14 of 15 Old 04-23-2013, 08:20 AM
mrclortho's Avatar
What do you use to tie your sway bar up out of the way when disconnected?
'12 JKU, 6 speed, short arm lift, tires, wheels, winch, stubby, tire carrier, armor, blah blah blah...
mrclortho is offline
post #15 of 15 Old 04-29-2013, 10:51 AM Thread Starter
Zip ties
