Stock steel stubby + hidden winch + fogs + stinger + swaybar disconnect - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 09-15-2011, 11:18 AM Thread Starter
Jipple28's Avatar
Post Stock steel stubby + hidden winch + fogs + stinger + swaybar disconnect
Inspired by a couple guys (specifically MilitaryMan), I wanted to share my not-so-stock stock winch, stinger & fog stubby.
More pics of stinger to come soon..
Winch installed, prior to stinger:
Prior to winch, aluminum plate to cover the void and swaybar disconnect.
Note the aluminum plates to hold the stock fogs and fill the wide gap:
A few quick details on stinger
I bought some 1 3/4" .120DOM (standard roll-bar tubing) from an industrial metal supplier (about $65 for two 6' lengths) and had a custom bike shop bend it to my specs ($100 for both bends and angled cuts). The center of the two tow hooks is somewhere around 30 1/2" apart. Do your own measuring before you take my word for it, cause I don't really remember.
Then I had another local metal supplier/fabricator produce 3/16" steel plates to fit behind the stock tow hooks and punch the holes for the tow hooks to fit. Cost was approximately $35 for 4 plates. If you do this make sure you measure carefully! The top two holes are about 1/8" further apart than the lower two holes (hard to see with the naked eye). Why, Chrysler?? I think the measurements were something like 5 5/16" apart for the upper holes and 5 3/16" for the lower (both measurements are center to center). Double check before you take my word for it!
*Side note: I was thinking about having some more of these plates made up and making shackles for D-rings, but not sure how many guys would want them.
I bolted the plates behind the tow hooks and had a friend from this forum (Moose4x4) assist me while I began the tack welds. We also used zip ties to help balance the bottom so it was level as I began. Brian (moose) will be the proud owner of the second stinger come end of the week.
So, two custom stingers cost about $200 (not factoring gas and time). I'm pleased with the outcome, and plan to add a small loop inside the top hoop for the winch to clip on. Quite reasonable, if you ask me, and as a beginning/garage fabricator, I'm pleased with the outcome.
For the record I did take some welding/automotive classes a few years back when I bought my Miller MIG, and was careful in layering my welds and ensuring penetration.
Winch
The winch is a Harbor Freight Badlands winch, 12,000lb I bought new for $300.
The winch plate is a heavy steel L-shaped plate I picked up for under $10 at a local scrap yard. I just measured cut to my specs as I marched along, and then mounted to the chassis with a few stainless steel grade-8 bolts.
It's not complete yet; I plan to 'beef it up' with additional supports and a proper steel plate to support the fairlead.. then I want to fab a clean overlay to get the stock fogs flush again. Heck, I may build a whole new [heavier] front bumper if I find the right steel at the scrap yard. I have a couple ideas in mind.
One of the the toughest parts was getting the stock fogs to fit properly as they're fairly deep and just barely touch the winch. I don't like the way they stick out, but I'll live with it for now.
What do y'all think?
2007 Rubicon 2dr, 6spd dubbed 'Longhorn Edition'
3.25" Rough Country suspension lift
315/70/17 Kumho RV MT's on AR Fuel 8's
Modified Gobi roof rack (4 Hella's front, 2 rear)
OR FAB swing-out tire carrier (with dual Jerry cans)
ORO rear license plate light & relocation bracket
Homemade steel stubby front bumper, stinger, 12k winchplate
Homemade rock rails, 'psuedo exocage' (tree sliders)
Jipple28 is offline
post #2 of 11 Old 09-15-2011, 04:49 PM
dwronka's Avatar
Nice work! I LIKE IT!
dwronka is offline
post #3 of 11 Old 09-27-2011, 05:51 AM
moose4x4's Avatar
Can't wait to get my stinnger done jipple! Just remember to pick it up from Scotty today.
09 X, 3.25" Rough Country Lift, NO SWAYBARS
, 34 Swamper's, KC 130w Daylighter, Smittybilt SRC Rock Rails, AEV Snorel, HF Badlands 12000lb, Ace Tube Fenders, River Raider extended breathers, Poison Spyder Hood Louvers
Current projects: off road trailer.
Future upgrades: lockers, long arms, Drive shafts, Humvee 37's
moose4x4 is offline
post #4 of 11 Old 09-27-2011, 08:06 AM
Daniel_M's Avatar
Nice man, I like that a lot. Do you have a write up on it and/or a list of what materials you used? That is very inspiring and I would like to do something like this to my bumper, probably minus the comp stinger. Awesome job.
-Dan
2008 JK X: Sold
Daniel_M is offline
post #5 of 11 Old 09-27-2011, 08:44 AM
Jaybee1669's Avatar
Looks good, you might want to think about adding some triangulation from the stinger back to the bumper incase you ever have to rely on it.
Jaybee1669 is offline
post #6 of 11 Old 09-27-2011, 12:01 PM
Grade 8 stainless? I've never heard of that. Where did you find these?
From what I know stainless is roughly equivalent to grade 2, I'd be ecstatic to learn I'm wrong though!
mysta2 is offline
post #7 of 11 Old 12-12-2011, 04:03 PM
militaryman4455's Avatar
Cool man! Looks good. I was wondering when you were going to get around to this.
Mod..Wheel..Break..Repeat
Criminals prefer unarmed victims:Μολὼν λαβέ
Originally Posted by cjcraig7 View Post
I think I understand your question - but I am a two door guy.
militaryman4455 is offline
post #8 of 11 Old 05-15-2014, 10:08 AM Thread Starter
Jipple28's Avatar
Question
Quick question; I searched the forum but didn't see anything in regards to this.. if I missed it because I searched the wrong criteria, I apologize now.
I'm looking to either flip my factory recovery hooks upside-down or remove them entirely.. I know the bolts are not squared, as I mentioned in my post above the top two and the bottom two have a different measurement between them.. I made a mistake when welded my stinger on the brackets/plates I designed for the bumper so I could still remove everything.
Try to follow me here; I put the stinger mounting bracket on the bumper, then the tow hooks, then welded the stinger on. The recovery hooks are not welded to the stinger/mounting plates, but because the bolts are as long as they are I cannot separate the recovery hooks from the stinger assembly. Does this make sense?
Here's my question: Can I either hammer out the existing upper bolts off the recovery hooks, OR (last resort) do I need to chop them off with an angle grinder and drill the studs out (and then replace them with new bolts)?
Thanks guys! -JPL
Jipple28 is offline
post #9 of 11 Old 05-15-2014, 10:58 PM
Thanks guys! -JPL
Chop them off. Cut off your stinger, rework your recovery points, reweld stinger back on. Let me show you my solution when I decided to get rid of the stock metal garbage after bending it up over and over.
I re-worked the original idea with a better solution. Still cheap, still simple. Maybe I can influence you again
https://www.jkowners.com/forum/showthread.php?t=182585
post #10 of 11 Old 05-16-2014, 07:43 AM Thread Starter
Jipple28's Avatar
I like this very much! Thank you! I will have to find some steel and do this soon. Much cleaner; I will need to drill holes in some manner to fit my factory fogs, however. Come to think of it, a friend has a plasma cutter- he's pretty had lots of practice, maybe he can help me with that.
Terrific write-up, BTW!
Jipple28 is offline
post #11 of 11 Old 08-12-2014, 08:12 AM
Thanks man! You gotten to this yet? I haven't been on in a while.
