DIY Control Arm Skids for $15 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 08-13-2011, 08:50 PM Thread Starter
TheBlackSheep's Avatar
I'm new to the site and wanted to contribute something. Here are some front control arm skids i made from 1/4" steel. They are bolt on and protect the CA bushing and housing - which I view as a weak point for damage. The are bolted for ease of removal and use the OEM holes, no drilling.
Tools needed, Option 1: Orbital Grinder w/ Metal cutting disc, Metal saw or jigsaw w/ metal blade, Sanding block w/ 80grit, metal file, square, chalk/white grease-pen
Tools needed, Option 2: Replace grinder and saw with plasma cutter or torch.
First photo: uncut 4" outside dimension: 1/4" steel tube
Second: Cut out shape of skid
Third: Sanded, primed, painted
Fourth: Installed with Grade 8 bolt and washer.
Hit me up with any questions.
O||||O
TheBlackSheep is offline
post #2 of 9 Old 08-13-2011, 08:59 PM
Nice handy work
post #3 of 9 Old 08-21-2011, 08:42 AM
dwronka's Avatar
WOW! Nice Job. Im going to follow your lead on these. Thanks
dwronka is offline
post #4 of 9 Old 09-10-2011, 05:35 PM
Would you have a drawing with more mesurements...
l1011500 is offline
post #5 of 9 Old 09-10-2011, 05:54 PM Thread Starter
ill meausre it for u soon when im not drunk - checlk thread tomorrow
O||||O
post #6 of 9 Old 09-12-2011, 05:13 PM
ASFIR4X4_AZ's Avatar
must have been one heck of a bender....
ASFIR4X4_AZ is offline
post #7 of 9 Old 09-12-2011, 06:55 PM Thread Starter
shit forgot - due to drunkeness...
i am also travelling for work now...
i know they are 5" deep (fron of skid to rear)
the tongue that sticks up to accomodate the bolt is 2.5" tall
and i think the tongue is 2" wide.
best thing u can do is measure. the important part is to get the right size tubing - evertything else is easy.
O||||O
post #8 of 9 Old 09-14-2011, 01:52 PM
l1011500 is offline
post #9 of 9 Old 09-02-2012, 09:11 AM
08rubicon's Avatar
What size bolt did you uses 5"x3/8"?
2012 Unlimited Rubicon
08rubicon is offline
