Transmission cooler return line... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 07-09-2011, 01:33 PM Thread Starter
cardenasrc51's Avatar
Wich is the return line on a 08 Unlimited Rubicon automatic with tow pkg? The top( first picture and I think it's thus one) or the bottom? I think it's the top one I need to splice for a B&M transmission cooler.
2008 Unlimited Rubicon automatic with 35" KM2
15" black procomp 8069
Swag Offroad tailgate conversion
OR-Fab Tire carrier with Amo can for straps & tools
K&N cold air intake
Magnaflow exhaust
Alpine iDA-X305S
MB Quart 4 channel amp
MB Quart 6" Components
Pollk Audio 6" components
cardenasrc51 is offline
post #2 of 4 Old 07-11-2011, 09:41 AM
Yes, the top line is the only one you will have to cut. I was confused about this when I installed mine. I was pretty sure it was just the top line but my father in law insisted on doing it another way and I trusted him rather than my own intuition. His way actually worked fine but it was cooling the tranny alone thru the aftermarket cooler, and not in conjunction with the radiator and the aftermarket cooler. So I changed it after my initial understanding of the concept was confirmed in the JKO write up dept. It's fine now that I re routed the lines correctly, but I spliced a line that I never had to splice. DAMNIT
hapnincapt is offline
post #3 of 4 Old 07-11-2011, 10:04 AM
JIMBOX's Avatar
it doesn't really matter, cause the aux cooler will improve the stock cooler (warmer) when hooked into either line and
The bottom line is the Tranny "hot Oil" line(drivers side) and the top line(passenger side) is the cooler return line !!
I use both lines for temp monitoring and aux coolers, circumventing the stock warmer, which is in the A/C condenser--not the radiator !!
JIMBO
Man, you gotta have style
"YELLOW JEEP No. 683"
JIMBOX is offline
post #4 of 4 Old 07-16-2011, 08:01 PM
Yes, the top line is the return line, back to the transmission. B&M instructions recommend hooking up to the return line for best cooling, if you are adding their cooler to the factory cooler.
Start the engine and run for 30 or 40 seconds, then feel both lines. The hotter line is the line from the transmission. The cooler line is the return line, back to the transmission.
B&M Transmission Cooler instructions
See a write-up here:
B&M SuperCooler install on JK Wrangler
Mabar
The Bigger the Government, the Smaller the Citizen
Mabar is offline
