Soft top tear repair - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 04-24-2011, 01:48 PM Thread Starter
HOOLIGAN's Avatar
Leaned the top up against a tree a couple of weeks ago and wound up getting a small "L" shaped tear in the top. Did a trail patch with some black duct tape just to keep it from ripping any further. That patch worked and it kept the rain out for about two weeks but I wanted something that might work a little bit better and not look so ghetto. Found some fabric and vinyl repair at Cabella's the other day.
I put a small patch on the inside. Then figured I'd put another on the outside just make sure it's sealed well.
The patches are very flexible and should handle folding the top ok. It's not as obvious as it looks in the pic. Hopefully this will get the job done. Either way, for $7 it's a lot cheaper than any other soft top fix I've found.
If you've found something else that works, let's hear about it.
HOOLIGAN is offline
post #2 of 3 Old 04-24-2011, 08:44 PM
Simple Jumper's Avatar
That looks promising. I might grab a pack to keep in the JK just in case. Let us know how it holds up in a few weeks.
Simple Jumper is offline
post #3 of 3 Old 04-24-2011, 09:17 PM
Butkus34's Avatar
that looks way more promising than the black duct tape I have....
2007 JK Unlimited Sahara, Blacked Out
3.5 inch lift sitting on 35's
Poly Performance/Synergy Suspension Ball Joints
Smittybilt Oversized Tire Carrier
Butkus34 is offline
