Maglite glass breaker mod - JKowners.com : Jeep Wrangler JK Forum
post #1 of 44 Old 03-17-2011, 06:09 PM Thread Starter
venom's Avatar
After having to bust a double pane, tempered, safety window with a mag last night, I realized this may come in handy.
There are several premade options that replace the tail cap, but I figured $30 for something I may or may not ever use again was silly.
This took 10 minutes and was free from stuff laying around.
take the tail cap off, remove the spring and spare bulb (unless its an LED model, then its just the spring)
drill a hole to fit whatever size bolt you're using.
Here's all of the hardware - a bolt, a couple of washers and a nut.
I used a 3/8"x1" grade 8 bolt - screw a nut all the way down it so that it will fix the threads for you after grinding - by removing the nut, it will usually dress the threads for you.
A couple of minutes with a bench grinder put a conical point on it - it doesnt need to be a sharp tapered stabbing point - wider is stronger, you're just trying to focus all the inertia into one area
put the bolt through the cap - I used a pretty big washer on both sides to help distribute the impact, the cap itself is pretty thin.
thread on your nut- I used a nylock I had laying around because it was thinner and wouldn't come loose. and you now have a glass/head breaker
Originally Posted by My Wife
venom is offline
post #2 of 44 Old 03-17-2011, 06:23 PM
JohnnyWalker's Avatar
I like it...
JohnnyWalker is offline
post #3 of 44 Old 03-17-2011, 06:33 PM
paramaniac's Avatar
Nicely done!
I've had much success just using the outside edge of the battery cap on my D cell mag-lite
Sent by carrier pigeon
paramaniac is offline
post #4 of 44 Old 03-17-2011, 06:35 PM
Mr.RonGilbert's Avatar
Nice.
I have one of these..... have not had the chance to bust some glass with it. The key would be to not push one's hand through when you strike the glass.. that may leave a mark.
It also works well on humans too.... but with more follow through
I do keep a seatbelt cutter / window punch in the Jeep though....
Mr.RonGilbert is offline
post #5 of 44 Old 03-17-2011, 06:39 PM
Drill the center out a bit and stuff in a chunk of spark plug ceramic. Will destroy any tempered/safety glass with zero effort.
Fnord5 is offline
post #6 of 44 Old 03-17-2011, 06:50 PM
e-jeep's Avatar
Feedback: 12 reviews
Not Bad!!! With the long handle it should keep your hand from getting shredded. I smell marketing idea Venom!!
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #7 of 44 Old 03-17-2011, 06:57 PM
Originally Posted by JohnnyWalker View Post
I like it...
Useful AND deadly.
Me too
Dancin Dan is offline
post #8 of 44 Old 03-17-2011, 08:23 PM Thread Starter
venom's Avatar
Originally Posted by paramaniac View Post
Nicely done!
took me about 6 good,heavy shots with the edge of the cap to break the outside pane on the window this morning, and the problem was I was having to swing so hard, when it did let go, I threw glass about 15'
this should be a lot more controllable
venom is offline
post #9 of 44 Old 03-17-2011, 08:33 PM
FLLawdog's Avatar
Our car burglars use a spark plug and rubber band.
Great mod! Wonder what the department would say if I did that to mine...errr.....theirs.
Originally Posted by StubEXrube
Once upon a time grown men didn't act like assholes for no reason nor get butt-hurt by complete strangers.
Then the internet was born.
FLLawdog is offline
post #10 of 44 Old 03-17-2011, 08:38 PM Thread Starter
venom's Avatar
eh, if they bitch, then unbolt it and stick a plastic christmas tree plug in the hole.
or buy yourself a new mag and swap caps
I may redo mine sometime when I have the RTV out and waterproof it
venom is offline
post #11 of 44 Old 03-17-2011, 08:40 PM
Safety glass does bring the suck...... I took a swing at some lexan with a fire axe and it bounced right off. Imagine my surprise
post #12 of 44 Old 03-17-2011, 08:42 PM Thread Starter
venom's Avatar
carry a can of compressed air/computer duster stuff
hold it upside down and spray the lexan for 5 or 10 seconds then give it a whack and see what happens...
venom is offline
post #13 of 44 Old 03-17-2011, 08:51 PM
rubirobv's Avatar
Damn, I love the education I get here.
rubirobv is offline
post #14 of 44 Old 03-17-2011, 08:55 PM
Lol.... I am running out of pockets.
Good to know.
post #15 of 44 Old 03-17-2011, 09:05 PM
van7559's Avatar
venom.. does it again. I love these kinda poor boy mods, I like it great idea. You should seriously market this shit
07' Unlimited X
PSC Bumpers F/R
8k Warn winch
2.5" RK Max Travel
35" MTR's
5:13 yukons
Sleeved/Gusseted front
Dynomax pre-axle exhaust
van7559 is offline
post #16 of 44 Old 03-17-2011, 09:06 PM
Taco08jk's Avatar
Next time carry a roll of tape ( duct tape, clear box tape ) any good holding tape will do, cover the glass with the tape and then poke the corner of the glass with a spring loaded center punch and you have a nice clean glass removal. Do it to both the inboard and outboard lites, It works great. Or if your in a hurry just hit it with the punch, It is still cleaner than whacking it with the mag lite. I'm a glass man by trade and we do this all the time. It freaks people out when we do this off of a swing stage 40 stories up.
BTW, that compressed air trick also works on pad locks you have lost the keys to.
RK 3.5 X Factor mid arm
PSC BFH trail stinger
PSC narrow fenders
A lot more to come very soon!
Taco08jk is offline
post #17 of 44 Old 03-17-2011, 09:08 PM Thread Starter
venom's Avatar
The Venom Customs 'Fang' mod for your Maglite
venom is offline
post #18 of 44 Old 03-17-2011, 09:10 PM Thread Starter
venom's Avatar
yeah if I had known ahead of time I was gonna have to break glass I would have definitely taken a spring loaded center punch with me, but I didnt get that part until dispatch called while I was already en route.
If you were a glass guy in central Texas I could hook you up with a lady that needs a new window in her metal exterior door...
venom is offline
post #19 of 44 Old 03-17-2011, 09:20 PM
TheBeatenPath's Avatar
wait what happens ?
TheBeatenPath is offline
post #20 of 44 Old 03-17-2011, 09:28 PM
nc_fjizzle's Avatar
That's awesome. Functional, well thought out, and beautifully done. May have to do this with mine
ΣX
Order from River City Offroad
nc_fjizzle is offline
post #21 of 44 Old 03-17-2011, 10:25 PM
Taco08jk's Avatar
wait what happens ?
I cant tell if your kidding or not so I will spill the beans, They shatter.
PSC narrow fenders
Taco08jk is offline
post #22 of 44 Old 03-17-2011, 11:00 PM
SgtMikey's Avatar
Ive always taken a bunch of spark plugs and break them up with a hammer and put the chuncks in a 35mm film container and seal the lid back on. Throw it in a work pocket or bag and your good to go.
Need to break glass? Pull these chuncks out and go to town, they work well!
Mikey
08 4 door Rubicon, RE 4.5" Long arm lift, Hutchinson Rock Monster Wheels and 37" M16's, Banks exhaust, AFE, Hypertech, Superior 5:13 gears, JE Reel 1350 drivshafts, Fabfour bumpers and rock slider, Tuffy, interior Line-Xed, Warn, Poly Performance, IPF, Lightforce, Hella fogs.
SgtMikey is offline
post #23 of 44 Old 03-17-2011, 11:44 PM
toolmanTim's Avatar
DAMMIT ... Salsa everywhere and dang my sinus is on Fuego!!!!!
'10 Surf 2Door Rubicon
'01
<-Vid Flexin' Muscle
6.2 liter Motec Ls swapped 2011 Jku with Rock Jock 60, Dynatrac rcv Pr44, and usual other beef on 37" MTR's.
toolmanTim is offline
post #24 of 44 Old 03-18-2011, 05:27 AM
Loki646's Avatar
Great DIY Venom, I considered getting one of Maglite's glass spike caps but that would mean I'd have to give up my custom Spike's logo engraved on my cap. One of the guys here @ work has it right now doing a custom grip wrap using para-chord...
Loki646 is offline
post #25 of 44 Old 03-18-2011, 05:55 AM
.:eMETAL:.'s Avatar
great idea venom.
.:eMETAL:. is offline
