Another Gauge Pod - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 03-15-2011, 03:09 PM Thread Starter
jct
jct's Avatar
Another Gauge Pod
Yet another gauge pod, sorry no earlier pics available.
I started wiith the Daystar dash top and modified it to fit three 1-1/2 inch gauges, the back storage area was cut out along its inside edge and fliped over and epoxied back in place. A couple pieces of styrine plastic were then epoxied to the sides and cut to the correct profile, drilled three holes of the correct size with hole saw. Right now its it the fill and sand stage, I'll finish off with a couple coats of texture paint.
jct is offline
post #2 of 11 Old 03-15-2011, 03:15 PM
SONIC's Avatar
Looks good!
What gauges you going to put in it?
-Doc Holiday
SONIC is offline
post #3 of 11 Old 03-15-2011, 03:23 PM Thread Starter
jct
jct's Avatar
Planning to run Sunpro mechanicals, volts, water temp, oil pressure
jct is offline
post #4 of 11 Old 03-15-2011, 03:40 PM
Bubblegoose1's Avatar
Nice work
Bubblegoose1 is offline
post #5 of 11 Old 03-15-2011, 03:44 PM
spillidge's Avatar
So you just used styrene plastice and epoxy? Nice work dude!
spillidge is offline
post #6 of 11 Old 03-15-2011, 04:07 PM Thread Starter
jct
jct's Avatar
TNX Guys, $0.00 in the budget makes for max creativity
jct is offline
post #7 of 11 Old 03-15-2011, 08:41 PM
Hemo's Avatar
Send a message via AIM to Hemo
That is a really nice job. You picked a great place for them. It ought to look right at home when it's painted. Please post up pics of the finished project.
2008 Rubi Unltd • RR Roll Cage - Limb Risers - Evap Skid - Diff Covers • PolyPerf HD Ball Joints • Reid Hi Steer Knuckles • RK 3.5" Triple Threat PRO Longarm • Rebel F & R Coil Overs • sPod Mini • Shrockworks Rock Sliders - Rear Bumper w/ Tire Swing • Xenon Flat Flares • ORO Onboard Air • BD Dual Battery • 5.13 Gears • 35" BFG KM2s • Warn VR12000 Winch • Safari Straps Everything • Tuffy Security Drawer •
Hemo is offline
post #8 of 11 Old 03-16-2011, 03:15 AM Thread Starter
jct
jct's Avatar
Will do, there is still a bit of sanding and filling to be done though
jct is offline
post #9 of 11 Old 03-20-2011, 05:44 AM Thread Starter
jct
jct's Avatar
Well here's the finished product, the texture looks very aggresive due to the camera flash but not so bad in the sun. I'm waiting for a heater hose adapter and an oil filter sandwich adapter to arrive then I'll install in the Jeep.
A question, anyone out there know if there is a hole already in the firewall I can pull the lines through or will I have to drill??
TNX
J
jct is offline
post #10 of 11 Old 03-20-2011, 06:12 AM
Dragline's Avatar
Nice work, looks really good...
08 Rubicon 2DR Red Rock
Dragline is offline
post #11 of 11 Old 03-20-2011, 01:26 PM
Sludge Puppy's Avatar
Far right of passenger side you can pull thru the firewall
Sludge Puppy is offline
