JK Wrangler Power Locks Tweaks & other Hokey Pokey Settings - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 02-21-2011, 11:31 AM Thread Starter
gold knight's Avatar
This will be a compilation of stuff as I find it. Here's the first installment.
If you have any tricks that were hard to find or not in the owners manual please add them here.
Originally Posted by flick View Post
Maybe you can reset it. I got this info from a guy on our local club. Hopefully it helps.
There seem to be many combinations of the power lock operation in the new JK. Some of these procedures are under debate and some you may need to try a few times to get it right. Use at your own risk.
Set the locks to auto-lock at 15 mph and auto unlock all when either front door is opened.
Get in the Jeep, insert the key. Cycle the key from insertion position to "on" position 5 times, upon completing the 5th cycle make sure the key ends in the "on" position, press the unlock switch up twice.
Set the locks to auto-lock at 15 mph with NO auto unlock all when either front door is opened.
Get in the Jeep, insert the key. Cycle the key from insertion position to "on" position 5 times, upon completing the 5th cycle make sure the key ends in the "on" position, press the unlock switch up once.
Stop the "HONK" when you lock the doors using the fob.
Press and hold the Lock button on the fob for at least 5 seconds, while still holding the lock button press the Panic button and release both. Test operation.
Unlock all the doors with one press of the unlock on the fob.
Press and hold the Lock button on the fob for at least 5 seconds but no more than 10. While still holding the Lock button press and hold the Unlock button. Release both and test.
Turn off the lights flash when locking
Press the unlock button on the fob for 4 to 10 seconds. While still holding the unlock button press and hold the lock button. Release both and test.
Notes on the security system
-Locking the Jeep with the fob always activates the security system.
-Unlocking the door with the key in the lock tumbler and opening the door will set off the alarm. It is disarmed by inserting the key into the ignition.
-To lock the Jeep without activating the alarm, lock all the doors within the Jeep, exit the Jeep, this will unlock the exit door. Lock the door using the lock tumbler.
gold knight is offline
post #2 of 2 Old 02-21-2011, 11:32 AM Thread Starter
Hokey Pokey inside the Jeep
Originally Posted by gold knight View Post
Directly from the '08 Owner's Manual pdf Hopefully these FACTS will put that part of the debate to rest
Change Oil Message
Your vehicle is equipped with an engine oil change indicator system. The “CHANgE OIL” message will flash in the instrument cluster odometer for approximately 12
seconds after a single chime has sounded to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and
release the Trip Odometer button on the instrument cluster.
To reset the oil change indicator system (after performing the scheduled maintenance) refer to the following procedure.
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary repeat this procedure.
More to come
