PSC Steering System - JKowners.com : Jeep Wrangler JK Forum
post #1 of 48 Old 01-18-2011, 07:45 AM Thread Starter
cjcraig7's Avatar
PSC Steering System
Preparing for 40's + on RJ60's, so I got my PSC Extreme Aftermarket kit today. Seeing one issue out of the box, the reservoir location seems like its going to be a tight fit, or no go, with the dual battery set up. I tried search.....does anyone have a link, or experience, or a pic of an install of the reservoir on a dual battery system? I will post up pics of the solution(s) and a write up on the entire install. (Not that it matters but 2007, 2 door JK)
cjcraig7 is offline
post #2 of 48 Old 01-18-2011, 08:28 AM
Heat'n and a beat'n...
STUPIDFACE's Avatar
Bodyguy on here built a mount. Look him up.
corey d
2008 JEEP...
STUPIDFACE is offline
post #3 of 48 Old 01-18-2011, 10:13 AM Thread Starter
cjcraig7's Avatar
cjcraig7 is offline
post #4 of 48 Old 01-18-2011, 10:48 AM
STUPIDFACE's Avatar
I think he has a pic of it in the "Hydraulic Assist" thread on here. I think the thread was started by USMCDOC14, or something like that.
corey d
2008 JEEP...
post #5 of 48 Old 01-18-2011, 11:05 AM
BenFoo's Avatar
https://www.jkowners.com/forum/showth...t=hydro-assist
BenFoo is offline
post #6 of 48 Old 01-18-2011, 12:05 PM Thread Starter
cjcraig7's Avatar
Located Bodyguys mounting location. Thanks
This thread is a write-up on an install of a PSC Extreme Aftermarket Axle steering system, working around the dual battery issue and upgrading Currie's RJ60 track bar bracket with the Poly 3" axle unit for increased beef and function.
Mod is free to put it any where they want, I'ze could be confused?
cjcraig7 is offline
post #7 of 48 Old 01-18-2011, 04:16 PM Thread Starter
cjcraig7's Avatar
Reservoir Mounting Location
This is the heavy traffic area that PSC recommends to mount the reservoir:
This is the new reservoir with integrated filter. It appear that they made a production change in the body billet base:
Not enough width with dual batteries, actually interference. So, I am removing one of the batteries and ordering a new Optima Battery Box from Poly. I will mount it in the back as I have no rear seat. I will built a custom reservoir mount and place it where it sits in the picture:
cjcraig7 is offline
post #8 of 48 Old 01-18-2011, 07:31 PM
maverick's Avatar
May be other options out there, but I'm not sure if this one had the integrated filter.
Originally Posted by GKR View Post
I'm pretty sure Tribe4x4 also fabricates a similar dual-battery box layout, but can't immediately find it.
Originally Posted by Tribe4x4 View Post
The power steering reservoir is secured using our in house fabricated bracket that bolts directly to the brake booster and is at the highest point of the steering system.
maverick is offline
post #9 of 48 Old 01-18-2011, 08:02 PM
andrelopez99's Avatar
It might be late giving idea's... But ...
andrelopez99 is offline
post #10 of 48 Old 01-19-2011, 07:06 AM Thread Starter
cjcraig7's Avatar
Never to late for ideas - it may help someone else! The mount by the Power Brake mount looks clean, but I have my compressor there (as do many others). In theory though - that location with its long supply line probably add a pint+ of fluid in the system. The front mount from Bodyman was another great mount, but for me the ability to access the front belt and pulley system on the trail, concerns a bit. Both really nice mounts.
I decided that since PSC does what they do, I would like to stay with the spirit of there recommendation as close as possible with a very short pump supply line. One battery under the hood (one in the back) is a good fit for me and the battery tray provides a nice stable mounting platform.
cjcraig7 is offline
post #11 of 48 Old 01-19-2011, 07:12 AM Thread Starter
cjcraig7's Avatar
Missed your mount in my reply Andre - noice! That would have caught my eye. I installed the RR air box in mine and built a custom top that also put my winch controller under the hood. But, if all else failed that would have been the part I cut out. Great idea. Well, if all three mounts were scattered before, there are four mount ideas all in one place now.
cjcraig7 is offline
post #12 of 48 Old 01-19-2011, 07:45 AM
good luck with everything!!! i really like the look of the front end on your jeep!!!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42Ē MTR's
17" Spyderlock Beadlocks
post #13 of 48 Old 01-20-2011, 06:22 PM Thread Starter
cjcraig7's Avatar
So I can go lock to lock with the new steering system, I finished some body and frame prep.
Remove all the front body mount outboard bracketry and replaced both with top frame mount poly isolated custom mounts.
I also re-trim the grill and inner fenders to match the slope on the flare.
The last of my parts came in from Poly today - 25 rail fluid cooler. Track bar mount and double-shear tie rod mount tomorrow, as well as a cooler mount.
cjcraig7 is offline
post #14 of 48 Old 01-20-2011, 10:54 PM
KenB1010's Avatar
I installed the PSC resevour in the stock location. It was the best location I could find. I also have a dual battery setup
Ken
Drivers Training = Fun
07 Rubi 2 Dr. 6-sp, 4" Full traction Long Arm, Dynotrax D60's front and rear, Big brakes, Evo double throwdown front coilovers, Kings on the rear, 38" Toyo's on TrailReady beadlocks, 1350 Coast DS's, Atlas 4sp, PSC extreme ram, High steer, GenRight Aux. Tank, Currie Anti-Rock rear sway, Spod, bunch O'h other stuff.
KenB1010 is offline
post #15 of 48 Old 01-21-2011, 06:10 AM Thread Starter
cjcraig7's Avatar
Thanks Ken. I would like to see a picture if it is PSC for the record here - for others. I just thought installing it in between the dual batteries and the engine on that side, and plumbing it, was going to be too tight. I am glad it worked out for you though.
cjcraig7 is offline
post #16 of 48 Old 01-21-2011, 09:36 PM
maverick's Avatar
Another 'too late' add...
Originally Posted by jss View Post
We are building a duel battery box for the Hemi Jeeps and the 3.8L Jeeps.
This box will work with AEV, BOR, JSS Hemi Kits and also stock 3.8L Jeeps, you can use the stock batteries and Optima Batteries.
We are also working on a duel battery switch
https://www.jkowners.com/forum/showth...t=41501&page=4
maverick is offline
post #17 of 48 Old 01-22-2011, 08:39 AM Thread Starter
cjcraig7's Avatar
Originally Posted by maverick View Post
No, I think you actually solved the problem. My battery tray is a MORE. It's batteries run front to rear. The tray in the link, like a previous post run side to side. The side to side unit give you adequate room to mount the reservoir. So for the purposes of this PSC Steering thread: if you plan on running both PSC and dual batteries, buy a dual battery tray with the batteries installed side to side.
Thanks Maverick - problem solved, lives saved!
cjcraig7 is offline
post #18 of 48 Old 01-22-2011, 09:03 AM
O2BDrty's Avatar
subscribed for now
I'm sure I'll think of something
O2BDrty is offline
post #19 of 48 Old 01-24-2011, 03:08 PM
Is that a custom front bumper?
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #20 of 48 Old 01-24-2011, 04:34 PM Thread Starter
cjcraig7's Avatar
I was going to have some fun with that bumper issue, I was wondering when someone would want to know what that "ultra" stubby bumper was. So I don't sidetrack this write up, I will send you a PM and post the bumper in the Mod section. Thanks
cjcraig7 is offline
post #21 of 48 Old 01-25-2011, 06:16 PM
gfe jeep's Avatar
subscribed
gfe jeep is offline
post #22 of 48 Old 01-25-2011, 09:42 PM
One of my next projects. Nice write up.
post #23 of 48 Old 01-25-2011, 10:59 PM
maverick's Avatar
Here's GKR's thread...
https://www.jkowners.com/forum/showthread.php?t=37490
While I was installing the Ripp Gen 2, I decided to build my battery tray. Made changing the passenger plugs easier too.
bolted in
still need to make the tie down bar tomorrow.
maverick is offline
post #24 of 48 Old 01-26-2011, 06:12 AM Thread Starter
cjcraig7's Avatar
Thanks for another example of the dual battery configuration that will allow room for the reservoir.
I finished up a new reservoir mount, new Poly track bar and ram mount, a double shear/horizontal tie-rod ram mount, and the cooler mount and install. I will be posting up the tech and pics tomorrow.
cjcraig7 is offline
post #25 of 48 Old 01-26-2011, 06:35 AM
STUPIDFACE's Avatar
Im anxious to see the pics. Im about to insall mine, but have already done the same things you have done. I dont have dual batteries, but i installed the resevoir and mounted some tabs where i plan on putting the cooler (im hoping i picked a good spot). I also made a doubler for the track bar bracket out of 1/4 plate with gussets and made some longer mounting tabs for the ram body at the track bar bracket. I purchased the poly tie rod clamp, but it wont work becuase it hits my diff cover. I was trying to avoid it, but it looks like im going to have to weld tabs to the tie rod.
corey d
2008 JEEP...
