Easy Fog light upgrade... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 28 Old 01-15-2011, 03:47 PM Thread Starter
tuff2010's Avatar
Well I got bored today and decided to do a little upgrade to the factory fog lights that I have been reading about...
AutoZone sells "Pilot Driving Lights" for 39.00 part no# 203W, they are a great fit into the stock housing!! I removed the stock lights and housings and removed the stock fogs from the housings and replaced them with the Pilots.....then clipped the factory plugs off and crimped new ends onto the wires and finished the install......
I was really surprised to see how much brighter they were...
tuff2010 is offline
post #2 of 28 Old 01-15-2011, 04:06 PM
HOOLIGAN's Avatar
So these are 35w lights?
HOOLIGAN is offline
post #3 of 28 Old 01-15-2011, 04:08 PM Thread Starter
tuff2010's Avatar
55 watts
tuff2010 is offline
post #4 of 28 Old 01-15-2011, 04:12 PM
HOOLIGAN's Avatar
I tried hooking up 55w lights a few years ago and the CANBUS kept shutting them down because it was higher than the 35w stockers. Wonder why it's working for you?
HOOLIGAN is offline
post #5 of 28 Old 01-15-2011, 04:16 PM Thread Starter
tuff2010's Avatar
My jeep is a 2010 model, maybe there is a difference in the electrical systems..???
tuff2010 is offline
post #6 of 28 Old 01-15-2011, 05:08 PM
LS6TT's Avatar
Send a message via AIM to LS6TT
2010 is 24v while 07-09 is 12v from my understanding
-Alex
2010 2dr Sport | 2.5" BB Lift with 4dr Springs | More to come
LS6TT is offline
post #7 of 28 Old 01-16-2011, 03:21 AM
DavidJ's Avatar
My 2010 is definitely 12v
Blue 2010 JK Unlimited CRD
DavidJ is offline
post #8 of 28 Old 01-16-2011, 07:13 AM Thread Starter
tuff2010's Avatar
They are a 12 v system......a jeep tech told me that some 55watt light just aggravates the canbus and it will shut them down, he also said that it will drive 55 watt light just fine, but reccomended nothing bigger on the stock system
tuff2010 is offline
post #9 of 28 Old 01-16-2011, 08:51 AM
Blackr6's Avatar
Would running an HID set up that's wired directly to the battery and only tap into the fogs work better? That way your only using the factory harness as a switch to turn off/on?
Kyle
Sent from my stone tablet and chisel.
Blackr6 is offline
post #10 of 28 Old 01-16-2011, 11:30 AM Thread Starter
tuff2010's Avatar
Kyle
If your planning on running more than 55 watts I would wire it like you described .....
tuff2010 is offline
post #11 of 28 Old 01-16-2011, 12:49 PM
cool! thanks for the write up
BBirish is offline
post #12 of 28 Old 01-16-2011, 04:04 PM
robctry69's Avatar
Send a message via AIM to robctry69
do you have any pics of how they fit in the old housings
robctry69 is offline
post #13 of 28 Old 01-16-2011, 04:08 PM
take a picture of them at night
rokov is offline
post #14 of 28 Old 01-16-2011, 10:35 PM
Thanks for the info! This is a necessary upgrade
What color were the wire connections?
I.e. pilot white to factory:
Pilot black wire to factory:
ski_bum is offline
post #15 of 28 Old 01-16-2011, 10:42 PM
xj
Looking to get another xj. Whats a good year and price range ?
xj90 is offline
post #16 of 28 Old 01-17-2011, 08:41 AM
When I changed my front bumper on my 2010 I mounted a set of 55w 12 volt lights to the bumper and used the stock fog light wiring. No codes. Then one day I was changing the tune on the Jeep with my superchip tuner and there was a code for over current on the fogs. I removed the lights, cleared the code and turned on the fogs without no load on them and the code still pops up. So I put in a relay and new fogs and said oh well. I still see the code on the superchip tuner. Lights work great.
randyb is offline
post #17 of 28 Old 01-17-2011, 12:39 PM
LS6TT's Avatar
then its the reverse. i get it confused. They changed the harness, bulbs, blah blah for the 2010 from what im reading here.
-Alex
LS6TT is offline
post #18 of 28 Old 01-18-2011, 12:25 PM Thread Starter
tuff2010's Avatar
They push right in, then take the supplied screws and insert them, presto...
Night time pics will follow this evening, finishing up a winch install
Just keep the white to white on wiring and you will be fine..
tuff2010 is offline
post #19 of 28 Old 01-18-2011, 06:48 PM Thread Starter
tuff2010's Avatar
Fogs just by thenselves..
Just headlights
Both...
tuff2010 is offline
post #20 of 28 Old 01-19-2011, 11:16 AM
schubbie's Avatar
impressive
schubbie is offline
post #21 of 28 Old 01-26-2011, 08:18 PM
Are the lights still holding up with no trouble from the computer?
2010 Surf Blue Pearl Unlimited
Rob_A is offline
post #22 of 28 Old 01-26-2011, 09:32 PM
Bruzr's Avatar
Do you still have the factory ends?
Im working with a DDM hid kit and factory fogs and need to buy some sockets. . .
Ill still owe you some $ and a paint code.
2008 Unlimited X - Steel Blue
- Slightly Modded
Bruzr is offline
post #23 of 28 Old 01-27-2011, 07:59 AM Thread Starter
tuff2010's Avatar
Nope, I tossed them bro.......
When ever your ready just ship me the part and I'll get it painted and returned to you...
tuff2010 is offline
post #24 of 28 Old 02-05-2011, 04:13 PM
I have my factory ends still.. Clipped the wires kinda close tho. PM if interested in them.
sorohanbrowns is offline
post #25 of 28 Old 04-23-2011, 12:50 PM
upalms's Avatar
Does anyone know if they make these lights in a fog instead of a driving? I'm planning on a new bumper that will have mounts for the factory lights, so these should work, but it also has light tabs, so I want to put a good set of driving lights up higher, and use the bimper mounts for a set of fogs, where we live, it's good to have fogs.
If not, anyone have any luck fitting a pair of fogs in the stock bumper?
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
Synergy Front Suspension
Artec Front JK Armor
5:13's
Tom Woods Drive Shafts
Hi-Lift & Much More
2000 TJ
6" lift
37 TOYO MT's on Worx Rims
$hitty Built bumpers
Air Raid
Corbeau Baja RS seats
upalms is offline
