Stubbed Stock Bumpers/ Jack Mount - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 01-06-2011, 10:57 AM Thread Starter
07XMan2Door's Avatar
Being the cheap Barstard that I am & also wanting to save weight, I stubbed my stock bumpers & mounted my jack & shovel all for under 10 bucks.
Two 5 inch bolts were welded to the front tow hooks & 30 rivets for the bumpers.
After I cut the end caps off, I had to cut the steel bumper. I cut two slits in it & bent it in towards the jeep until it reached 90 degrees. Then I simply heated up the plastic end caps & forced them over the bumper. Had to cut a slit in them to help accomplish this. Make sure you cut the caps long enough. The passenger side turned out better than the drivers side.
The shovel & Jack are out of the way & easy to get off. Just a 3/4 inch wrench is needed. I put rubber belting between all metal pieces & some radiator hose under the shovel blade. It doesn't rattle at all.
The rear was pretty easy too. The plate is an old yield sign I had. When trimming the rear plastic, you have to leave a "tab" on the top so you can heat it up & bend it down so you don't have a void on the top edge.
Any Q's just ask.
Pics of my Jeep....
07 2 Door Red Rocker, 6 speed, AFE intake, 2.5 Terraflex plus 1", 5.13's, rear locked, 35" Cooper STT's on 15" Ions, EVO Sleeves & Gussets, DIY Bumpers & stuff.
07XMan2Door is offline
post #2 of 5 Old 01-06-2011, 12:33 PM
LS6TT's Avatar
Send a message via AIM to LS6TT
picture of the side profile of the rear bumper without the end caps
-Alex
2010 2dr Sport | 2.5" BB Lift with 4dr Springs | More to come
LS6TT is offline
post #3 of 5 Old 01-06-2011, 12:44 PM Thread Starter
I didn't take any pictures in the middle of the job. Never thought I'd be posting it up. Just knew I hated the stock look so I stayed up one night & finished it up. I didn't take either bumper off to do these mods. I used a wood hand saw for the pastic & a sawsall for the metal.
On the rear there was no metal. Just used wood handsaw & cut from the bottom up, remembering to leave a tab on the top so you can heat it up & bend it down to match the rear most edge.
There is a bracket that must be removed & a bit of plastic in the wheelwell that must be trimmed off.
Pics of my Jeep....
post #4 of 5 Old 01-06-2011, 12:54 PM
Bubblegoose1's Avatar
Nice job. You should market the fuel can holder. Pretty sweet.
Bubblegoose1 is offline
post #5 of 5 Old 01-06-2011, 03:45 PM Thread Starter
Thanks!!
Pics of my Jeep....
