Another M416 Trailer Build - JKowners.com : Jeep Wrangler JK Forum
post #1 of 63 Old 01-04-2011, 06:31 PM Thread Starter
YingYang's Avatar
I always thought that these little trailers look sweet behind a Jeep. Wasnt planning to build one but one just fell into my lap. Why not then?
Tons-o-pics
This was rusting away in a field behind a friends fathers house.
YingYang is offline
post #2 of 63 Old 01-04-2011, 06:34 PM Thread Starter
YingYang's Avatar
Getting everything stripped down.
Sandblaster not doing to much to this paint
On to the stripper
YingYang is offline
post #3 of 63 Old 01-04-2011, 06:42 PM Thread Starter
YingYang's Avatar
Gettin it primed.
Starting paint.
Herculining tub, exterior and interior.
New wheels, tires and axle.
YingYang is offline
post #4 of 63 Old 01-04-2011, 06:48 PM Thread Starter
YingYang's Avatar
Putting it all together.
New shock brackets. I had to relocate the shocks since I undermounted the axle to give myself room for 33" tires.
YingYang is offline
post #5 of 63 Old 01-04-2011, 06:51 PM Thread Starter
YingYang's Avatar
Here she is as of today. I really like what Loki did to his and he has some awesome ideas. I am not sure what this will turn into later but this will be it for now. I think it turned out nice and get great comments anywhere I take it.
YingYang is offline
post #6 of 63 Old 01-04-2011, 06:54 PM
Pat Harrison's Avatar
Really like the way that turned out! Well done.
Proud manufacturers of TRAILMOUNTZ Top QUALITY aluminum mounts for LED lighting.
Pat Harrison is offline
post #7 of 63 Old 01-04-2011, 07:36 PM
maverick's Avatar
Very nice! Hopefully I'll start my M416 project upon my redeployment.
maverick is offline
post #8 of 63 Old 01-04-2011, 07:41 PM
venom's Avatar
sweet!
looks good
since you did the spring under conversion, don't forget to do something about bumpstops so you don't crack the leaves
I used a pair of front bumpstops off of an F-150 2WD that I had laying around, they worked great but a set of generic single post urethane stops would work just as well, just drilled one hole in the frame above where the axle sits on each side and bolted them to the frame rail.
I also used some 4" wide 1/4" plate doubled up to extend the dog leg in the front.
Originally Posted by My Wife
venom is offline
post #9 of 63 Old 01-04-2011, 07:46 PM Thread Starter
YingYang's Avatar
Originally Posted by venom View Post
sweet!
looks good
Yea, thought about that. These dang springs are so stiff. I did end up removing 2 of the 10 to make it a little softer. I can still jump in the back of this thing and it doesn't move.
YingYang is offline
post #10 of 63 Old 01-04-2011, 08:15 PM
Heavy D's Avatar
I love these trailers. I wish that I could find one to build.
Heavy D is offline
post #11 of 63 Old 01-04-2011, 08:21 PM
SgtMikey's Avatar
Dude that trailer looks awesome!
Mikey
08 4 door Rubicon, RE 4.5" Long arm lift, Hutchinson Rock Monster Wheels and 37" M16's, Banks exhaust, AFE, Hypertech, Superior 5:13 gears, JE Reel 1350 drivshafts, Fabfour bumpers and rock slider, Tuffy, interior Line-Xed, Warn, Poly Performance, IPF, Lightforce, Hella fogs.
SgtMikey is offline
post #12 of 63 Old 01-04-2011, 09:13 PM
rballman's Avatar
That is one nice trailer, good work!
I cant imagine buying 7 of those rims!!!!
2007 Wrangler X - Jeep Green, 4" lift, 4.88s, locked rear, custom bumper/fender/cage, rolling on 35s w/ 15s
rballman is offline
post #13 of 63 Old 01-04-2011, 10:58 PM
Hittnthebz's Avatar
Looks great! Simple build with awesome results!
Hittnthebz is offline
post #14 of 63 Old 01-04-2011, 11:42 PM
Loki646's Avatar
Very Nice work....at least you had one in better shape to start with than I did...
If you are willing to do some metal cutting and some minor welding to make new mounting points. The easiest way to fit even larger tires is to simply raise your fenders. This will work for say upto 35s, anything bigger and you will likely need to have new fenders custom made due to the distance from the bottom edges is around 36".
I know those springs are stiff as shit with the trailer empty, but once you put a good load on them, you'll see the difference. Keep in mind, my tub was not original, the frame was, but not the tub or tongue. Well I loaded mine completely full of pavers and was pushing 1300#s, yea those springs weren't so stiff and bouncing on that trip....
The possibilities for these things are endless. The number one recommendation I would make though is converting the Pintle/lunette hitch over to a simple 2" receiver and getting yourself a Max Coupler. Once you tow with one, you'll wonder why anyone would want to use anything else..
Again, absolutely a great job!
Edit: Just noticed it had already been modified to a ball clamp hitch....looks like a perfect excuse to build a new, slightly longer tongue and include that 2" receiver.... Hopefully yours will actually simply unbolt like its designed to, I had to actually torch and grind mine off.
Loki646 is offline
post #15 of 63 Old 01-05-2011, 12:53 AM
maverick's Avatar
Pushed up, expanded a bit, and made a custom bracket to fill between fender and lower tub.
maverick is offline
post #16 of 63 Old 01-05-2011, 06:45 AM Thread Starter
YingYang's Avatar
Thanks everyone!
Loki, I did not spend near the time you did on yours. When I got the trailer I showed my Wife your thread. I was like wow, this guy is going all out. Im not OCD as you, im more ADD. I put in a little over 3 weeks and most of the work was involved in the tub. I blasted, stripped, sanded, beat, welded, painted until I was sick of looking at this thing.
I have so many ideas rollin around in my head its ridiculous. I would like to extend the tongue, put on a different hitch and make a top for starters. I have checked out the Max Coupler, man they are proud of those things.
I won’t be so lucky as to unbolt. The Bulldog hitch is welded on, so looks like a torch and grinder for me as well.
LOL - Yea. Luckily I already had the 5 on the JK. I really needed 3 for the trailer but I cheaped out and only got 2. The tires, wheels and axle made this thing expensive. I figured since the trailer cost me $0.00 I could do a little extra and I think the wheels/tires make the trailer.
YingYang is offline
post #17 of 63 Old 01-05-2011, 10:36 AM
tjkoen01's Avatar
looks good!
looks like mine!
2008 Rubicon
Rugged Ridge XHD Bumper w/Warn XD9000i
315/70/17 Cooper ST Maxx, No Lift
Superchips Flashpaq
Flow Daddy Headers
Gibson Dual Exhaust
tjkoen01 is online now
post #18 of 63 Old 01-05-2011, 10:47 AM Thread Starter
YingYang's Avatar
Originally Posted by tjkoen01 View Post
looks good!
looks like mine!
I like!!! Whats the cover your using?
YingYang is offline
post #19 of 63 Old 01-05-2011, 10:52 AM
I was fortunate enough to work out a horse trade recently that landed me an M416 is fair condition (some body rust and needs the bed repaired. Functional for now though.
Anyways, was wondering if you know anywhere I can score those brake lights like you have pictured here:
Here is what mine looks like at this time:
karnuvore is offline
post #20 of 63 Old 01-05-2011, 11:00 AM Thread Starter
YingYang's Avatar
Just keep an eye out on G503 or Steel Soldiers one will come up for sale at a realable price. Nice trailer and JK!
YingYang is offline
post #21 of 63 Old 01-05-2011, 11:59 AM
tjkoen01's Avatar
it's a lid i made out of wood, nothing special
2008 Rubicon
Superchips Flashpaq
Flow Daddy Headers
Gibson Dual Exhaust
post #22 of 63 Old 01-05-2011, 01:34 PM Thread Starter
YingYang's Avatar
From the pic it kinda looked like a vinyl cover. Show me some close ups. Maybe it will inspire me. Im better with wood than steel.
YingYang is offline
post #23 of 63 Old 01-05-2011, 03:47 PM
Loki646's Avatar
Thanks everyone!
Well trust me if the tub on mine would have been in the shape of yours, my build probably would have never taken on the life that it did.
No, I mean the whole tongue is designed to unbolt from the main frame. there are two bolts per side back at the "wedge" connection then one U-bolt per side at the angle iron at the very front of the tub. Unbolt everything and the whole "A-frame" should come right off, from there you can layout how you want the new tongue to be set up. If you want a longer tongue and want to ditch the Bulldog, then don't waste the time cutting and grinding just the Bulldog off.
Loki646 is offline
post #24 of 63 Old 01-05-2011, 03:57 PM Thread Starter
YingYang's Avatar
Yep, I see where it is "suppose" to unbolt but there is a plate welded on the frame and then the bulldog welded on that. Whoever did it may have even tacked onto the lunette/landing leg holder.
YingYang is offline
post #25 of 63 Old 01-05-2011, 04:06 PM
Loki646's Avatar
Hey Dave, I know these aren't the originals, put they may work for ya....
http://cgi.ebay.com/ebaymotors/NEW-O...-/220719157507
Loki646 is offline
