Rutdigger: Dual Battery Tray - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 01-02-2011, 10:07 PM Thread Starter
rutdigger's Avatar
Send a message via Yahoo to rutdigger
I have been wanting a dual battery tray, so I made one.
Start by removing the monster battery tray. This thing is one huge molded plastic piece that connects the battery tray, fuse box stand, and air box mounting locations all in one mold...take it out:
Next you will need to cut off the section that your fuse box and air box mounts to. You will keep this section and discard the other:
Remove this reservoir from the front of the Jeep to allow easy installation of your new tray:
Make a template using foam poster board for your main mounting plate on the firewall:
Transfer that pattern to your 10 gauge and cut out the template. Next measure the battery width of the batteries you want to install. I found that you can't go much more than 7.25" on each battery compartment side for a total of 14.5" floor plate. It just fits, but barely, weld the sections together after you find your center line and cut a center support:
2015 Stone White Unlimited Rubicon
To many mods to list..lol
Visit my website:
rutdigger is offline
post #2 of 12 Old 01-02-2011, 10:08 PM Thread Starter
rutdigger's Avatar
Continued:
Remove and fabricate the plate the fuse box and air box base will sit and attach to:
Add a mounting post for the Evap solenoid, drill holes for water drainage, and prime for paint:
Paint your choice of paint:
Visit my website:
post #3 of 12 Old 01-02-2011, 10:09 PM Thread Starter
rutdigger's Avatar
Continued:
Install in the Jeep:
Ready for the second battery. To hold everything in place I just used the standard battery mount J bolt kit to hold the batteries down.
Visit my website:
post #4 of 12 Old 02-16-2011, 08:53 AM Thread Starter
rutdigger's Avatar
Project complete. Second Bat in, everthing hooked up and working properly. Good to go.
Visit my website:
post #5 of 12 Old 02-16-2011, 09:03 AM
Looks awesome, nice work!
post #6 of 12 Old 02-16-2011, 09:20 AM
Administrator
HITMONEY's Avatar
Nice work!
įlllllį
Facebook Page
YouTube Channel
HITMONEY is offline
post #7 of 12 Old 05-09-2011, 10:50 PM
What kind of isolator did you use?
Nice work
HOT_DAMN is offline
post #8 of 12 Old 05-11-2011, 05:13 AM
brent_f70's Avatar
Awesome Job!!! Should have come that way from the factory
brent_f70 is offline
post #9 of 12 Old 05-15-2011, 12:55 AM Thread Starter
rutdigger's Avatar
Nice work
If I remember right it was the -T-max system from Autozone.
Visit my website:
post #10 of 12 Old 10-03-2011, 01:04 PM
StetsonJK's Avatar
that looks awesome! want to make me one?
StetsonJK is offline
post #11 of 12 Old 10-03-2011, 03:15 PM
woomdawg's Avatar
Great job man looks real good.
2007 unlimited X
rough country 4" lift
18" KMC Rockstars
superchips flashpaq
1 ton Offset TRE's with 1.5" X .25" wall DOM tubing Tie Rod
1.5" X .25" wall DOM tubing Draglink with 7/8" hiem's
Adam's Front Driveshaft
woomdawg is offline
post #12 of 12 Old 10-25-2011, 11:53 AM
Tank29's Avatar
Me too...Nice job!!!
2007 JK Unlimited "X"
TF 3" Kit w/4 Arm Flex Kit, TF HD F & R Adj. Track Bars, TF HD Steering Stabilizer, Yukon 5.13 gears, CenterForce II Clutch, Black Rock Soft 8's 16x8, Cooper Discoverer STT 315/75/16, RR XHD Front w/Stinger, SB XRC Rear w/Carrier, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fenders, SB XRC8 Winch
Tank29 is offline
