Rutdigger: Snorkel - JKowners.com : Jeep Wrangler JK Forum
post #1 of 36 Old 01-02-2011, 09:38 PM Thread Starter
rutdigger's Avatar
Send a message via Yahoo to rutdigger
Rutdigger: Snorkel
Ok, this is a fun project. Its very time consuming, but I think will turn out really well.
First you have to make a foam plug to get your shape. I chose to use insulation sheets from Sutherlands. Anyway, cut about 4 or 5 5" inch strips and glue them together with a hot glue glue:
Then you just begin to shape your block to the shape you want your snorkel to look like in the end. I recommend that you go about .75 of an inch smaller in diameter than you want because you are going to be adding fiberglass and bondo later in the process:
Keep shaping until you get the right look, then make your upper piece. Once you get everything looking good wrap it with tape. Painters tape would be better if you have it handy. Make sure you make the indentions for your mounting brackets and to clear the hood and the antenna:
Now go tape off the section around your air box in preparation for a fiberglass mold:
Wrap your plug with fiberglass chop mat. I used small staples to hold the chop mat in place. I would NOT recommend that as they did not come apart like I planned later in the process...grrr.
Lay mat around your air box. Oh...I forgot to mention before you lay any mat give your tape a good once over with Johnsons floor paste wax. This will allow the setup fiberglass to release easily:
2015 Stone White Unlimited Rubicon
To many mods to list..lol
Visit my website:
rutdigger is offline
post #2 of 36 Old 01-02-2011, 09:39 PM Thread Starter
rutdigger's Avatar
Continued:
Lay your fiberglass resin on your air box and your plug:
Join the plug and the platform you just made together. I used small wire across the top to give the fiberglass something to sit on while it dried:
Ok, now that your plug has dried you will need to find the center line and cut it down its center to be able to pull the two half’s apart. This is where those stupid little staples were a VERY bad idea. Anyway, long story short I could not just simply pull the fiberglass off the plug because of those staples, so I ended up destroying my plug to get the half’s apart:
Profile of the JK fender area:
The two halfs apart and cleaned out and taped together:
Visit my website:
post #3 of 36 Old 01-02-2011, 09:40 PM Thread Starter
rutdigger's Avatar
Continued:
Begin laying your fiberglass over one section of thin chop mat. You won't need much because later on you will be using bondo to smooth everything over:
First of many layers of bondo:
Ok..now you need to make a piece that the pre-filter will attach to. I was not able to find the correct diameter plastic pipe I needed so I had to make one. I used a 3" ID pipe for a plug and fiber glassed the outside:
Visit my website:
post #4 of 36 Old 01-02-2011, 09:41 PM Thread Starter
rutdigger's Avatar
Continued:
While that was drying I rough sanded the layer of bondo:
Primed and wet sanded to be able to see the high and low spots still:
Add your mounting brackets you made out of 16 gauge steel to your snorkel. In these locations is the metal you inserted earlier to be able to drill and tap holes for these screws:
Visit my website:
post #5 of 36 Old 01-02-2011, 09:42 PM Thread Starter
rutdigger's Avatar
Continued:
Add the section you made earlier to the top of your snorkel and then attach the snorkel to the Jeep using your mounting locations. Once you have it on and bolted down be very careful to make sure your tube is plum vertically and horizontally. Once you get ot plum make a line so you can recreate it on your bench:
Bring back to your bench, line everything up, trim to length and sand bondo smooth:
Test fit with pre-filter attached:
That's where I'm at on this build. I hope to get it finished in the next few weeks.
Visit my website:
post #6 of 36 Old 01-03-2011, 12:57 AM
Hittnthebz's Avatar
Very impressive!
Hittnthebz is offline
post #7 of 36 Old 01-03-2011, 05:09 AM
bonecollector's Avatar
I build seat pans for custom HD motorcycle seats the same way, Ive found that if you use fglass cloth you can use the fglas resin to hold it to your form, no more satins staples. Its stronger than the fglas hair, then follow up with resin and hair coats. I really like your projects, got a lot of time on your hands, or just like hanging out in the shop? Check out some of our stuff at Howards killer customs,unsub
No Good Deed Goes Unpunished
bonecollector is offline
post #8 of 36 Old 01-03-2011, 10:19 AM Thread Starter
rutdigger's Avatar
Originally Posted by Hittnthebz View Post
Very impressive!
Thanks guys. I will definetly check out your stuff Bro, I am all about learning new ideas. When I do speaker boxes I use your techique. I got a wild hair up my ass that day and decided to try the staples...bad idea! lol. Right now I am an industrial equipment tech/fabricator and love all the cool toys for the Jeep but am to cheap to buy them..lol. Plus I love building cool shit. I think my son and I are about to get into RC rock crawling...
Visit my website:
post #9 of 36 Old 01-31-2011, 09:47 PM Thread Starter
rutdigger's Avatar
Welp guys..I have been gone for a bit, but now I am back at home so I thought I would get this snorkel almost completed.
I took off the S-tube from my air box and attached it to the snorkel:
So then I got the first coat of bedliner on it and attached it to the air box to see if it was going to fit. Everything went ok but I could not get the upper post to lock into the air box. No biggy, it's in there pretty good and it not going anywhere:
Then..SETBACK..remember when I mentioned I was concerned about that hump hitting the hood after it was trimmed...well, that is exactly what happend. So, I had to cut out the hump and make a flat piece to go back in it:
Then I glued the new piece in place with resin and added weight:
Added filler and sanded smooth:
Here is a pic of the snorkel almost complete. I am making the trim bezel for the hood now. Then I need to get another coat of paint on it:
Whatcha think so far?
Visit my website:
post #10 of 36 Old 02-01-2011, 09:52 AM
spillidge's Avatar
I think it is looking killer!
How much time do you have in this project?
spillidge is offline
post #11 of 36 Old 02-01-2011, 01:28 PM
Vryce's Avatar
It looks good, but I would like to know how much strength the bedliner adds to the fiberglass.
Vryce is offline
post #12 of 36 Old 02-01-2011, 02:31 PM
Hittnthebz's Avatar
Millions of strength! Of course, I could break it because I am a normal sized guy with average strength.
post #13 of 36 Old 02-01-2011, 03:33 PM
Hemo's Avatar
Send a message via AIM to Hemo
Rutdigger,
You really do have seriously killer skills and obviously a lot more patience then I have. I am impressed with every single project you have done.
2008 Rubi Unltd • RR Roll Cage - Limb Risers - Evap Skid - Diff Covers • PolyPerf HD Ball Joints • Reid Hi Steer Knuckles • RK 3.5" Triple Threat PRO Longarm • Rebel F & R Coil Overs • sPod Mini • Shrockworks Rock Sliders - Rear Bumper w/ Tire Swing • Xenon Flat Flares • ORO Onboard Air • BD Dual Battery • 5.13 Gears • 35" BFG KM2s • Warn VR12000 Winch • Safari Straps Everything • Tuffy Security Drawer •
Hemo is offline
post #14 of 36 Old 02-01-2011, 03:47 PM
.:eMETAL:.'s Avatar
extremely great attention to detail and great photos to go along with your write up. very well done !
.:eMETAL:. is offline
post #15 of 36 Old 02-01-2011, 03:52 PM
SONIC's Avatar
Nicely done!
Looks exactly like my AEV minus the stupid logo
good job!
How much you think it cost you overall?
-Doc Holiday
SONIC is offline
post #16 of 36 Old 02-01-2011, 06:26 PM
curbsjeep's Avatar
That things cool! Love the satisfaction of doing or making something myself
curbsjeep is offline
post #17 of 36 Old 02-01-2011, 06:52 PM
d'sjk's Avatar
Great stuff!
d'sjk is offline
post #18 of 36 Old 02-01-2011, 07:06 PM
Nice job. That's a lot of work and time. I have never worked with fiberglass so I have no knowledge about how it works. Newbie question: Does it draw or move as it dries?
4x4x4 is offline
post #19 of 36 Old 02-01-2011, 09:25 PM Thread Starter
rutdigger's Avatar
Ummm...I guess I have probably about 30 man hours into it. Working on it a little here and there, etc.
Visit my website:
post #20 of 36 Old 02-01-2011, 09:27 PM Thread Starter
rutdigger's Avatar
The bedliner probably doesn't add crap for strenght. The fiber and the filler is what makes it strong. The injected molded plastic is stronger, but I would venture to say if I kissed a rock with this, it would not break. It has several layers of fiberglass on it.
Visit my website:
post #21 of 36 Old 02-01-2011, 09:28 PM Thread Starter
rutdigger's Avatar
Originally Posted by Hemo View Post
Rutdigger,
Originally Posted by d'sjk View Post
Great stuff!
Thanks guys!
Visit my website:
post #22 of 36 Old 02-01-2011, 09:31 PM Thread Starter
rutdigger's Avatar
Originally Posted by SONIC View Post
Nicely done!
good job!
I have about 80 bucks in the project so far. That is mainly because I had some filler and fiber left over from a speaker box project that I was able to use.
Fiberglass doesn't move as it cures. You can mix it "hot" or normal depending on the amount of time you need to work it. Once it cures, its there to stay.
Visit my website:
post #23 of 36 Old 02-02-2011, 08:27 AM
Vryce's Avatar
Thanks that clears up a few extra questions, and has help to provide some direction for the creative juices.
Vryce is offline
post #24 of 36 Old 02-04-2011, 11:24 AM
man its great to see this thread again Ive been looking for it somewhere else and noticed it had vanished
4DRedRock is offline
post #25 of 36 Old 02-04-2011, 10:58 PM Thread Starter
rutdigger's Avatar
Thats because the prick banned me..
Visit my website:
