Big Viair compressor mount - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 12-23-2010, 06:37 AM Thread Starter
Tribe4x4's Avatar
I know everyone has seen the brackets to mount an ARB or smaller compressor. We had a customer that purchased a 450 Viair and wanted to mount it in the same spot, but it was too long for the old bracket. So, we whipped out the Torchmate and jammed out this bracket. Check it out.
It also mounts in the front to help support the weight.
We also made this little bracket out of aluminum the hold the coupler.
Anyone interested???
Tribe4x4 is offline
post #2 of 9 Old 12-23-2010, 06:52 AM
XJK07's Avatar
You guys do some good fab work! I have a question though. Being that close to the ABS and brake control module...even the bracket is notched it still seems to be really close. I could be deceived by the pictures! However with the compressor on, does it vibrate and rub on those lines any?
XJK07 is offline
post #3 of 9 Old 12-23-2010, 07:04 AM
BadAssJK's Avatar
I take it you made that plate that you mounted the quick release to?
BadAssJK is offline
post #4 of 9 Old 12-23-2010, 07:16 AM Thread Starter
Tribe4x4's Avatar
Thanks! Deceiving pic, there is good clearance around all the lines. The next one I build will add some more also. Say, anouther 1/4".
We did. Just out of some aluminum laying around. Suprising the compressor didn't come with hardly anything. No wiring, relay, fuze, switch, or pressure regulater switch. Maybe I missed something when we ordered it.
Tribe4x4 is offline
post #5 of 9 Old 12-23-2010, 08:43 AM
BadAssJK's Avatar
It came out really nice. I know when I ordered my Arb compressor it came with all the extra goodies.
BadAssJK is offline
post #6 of 9 Old 06-06-2011, 05:06 PM
jeeperjkj's Avatar
Can you build one for dual 350c's to go in that location?
jeeperjkj is offline
post #7 of 9 Old 06-09-2011, 05:59 PM Thread Starter
Tribe4x4's Avatar
Not sure, i'de need to get the dimensions on the compressor first. We did dual 400 before on the tail gate because of the same issue, no room.
Tribe4x4 is offline
post #8 of 9 Old 06-11-2011, 03:58 PM
b1pig's Avatar
wow!!!
I had a 450c in the back of a ZJ... and I cant believe how massive that thing looks next to the tiny little engine!!!
b1pig is offline
post #9 of 9 Old 06-11-2011, 04:34 PM
jeeperjkj's Avatar
http://viaircorp.com/OffRoad/Schematics/10009_dd.pdf
Let me know what you can come up with...
