Speed up your USB car charger. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 12-10-2010, 07:38 PM Thread Starter
WeGo4x4's Avatar
This is a simple mod. You're basically connecting two points on the USB charger to tell your phone to charge as if it's connected to the wall charger not a computer.
I purchased this USB charger from deal extreme. The first two images are the finished product. I didn't take pictures before working on it.
http://www.dealextreme.com/details.dx/sku.40470
This one is glued together. Some are easier to open. For this one I had to cut along the glue lines. I use a razor blade and just cut enough so I can open it with a screwdriver. I use a small screw driver and pry it open to break the bond.
Once you have it open take out the board.
You'll need to solder pins 2 and 3 together. Generaly they are in the middle. If you want you can check the pins with a voltmeter. I circled the two points that need to be solderd together.
The pins should look like this when you're done.
Put the case back together. I use an epoxy and it holds the cases really good. If you are careful when cutting the seam you can actually save the grooves that connect the top and bottom. I put the epoxy in the grooves and clean it up after it has dried. In the third image you can see the grooves on the case. This one was actual the toughest one to open and it came out pretty good. Not all chargers need this done. This one, when plugged into my phone, only charged at USB speeds not wall charger speeds until the mod was complete. Before plugging in your expensive device check the voltage/amps and such with a voltmeter first.
Disclaimer:
Don't ever leave anything plugged into an always on cig lighter. Some cheaply made chargers and adapters will get hot over time and can start to burn if you leave them plugged in and on 24/7. If you decide to do this mod you are doing it at your own risk. I am not responsibile if you make a mistake or don't check your connections before plugging in your device. I haven't had
have any issues and have done this mod plenty of times. Razor blades are sharp if you have issues with sharp objects you might want to pass on this one.
WeGo4x4 is offline
post #2 of 10 Old 12-10-2010, 07:44 PM
Mr.RonGilbert's Avatar
Did you do one of these for E-Jeep by chance?
Mr.RonGilbert is offline
post #3 of 10 Old 12-10-2010, 07:51 PM Thread Starter
WeGo4x4's Avatar
Nope.
WeGo4x4 is offline
post #4 of 10 Old 12-11-2010, 12:00 PM
nlgrav182's Avatar
Originally Posted by WeGo4x4 View Post
Nope.
Nothin' like turning up the heat on a piece of crap Chinese electrical product!
OKAY FUCKMOUTH.
nlgrav182 is offline
post #5 of 10 Old 12-11-2010, 07:44 PM Thread Starter
WeGo4x4's Avatar
Actually you're not turning up the heat. You are just telling the phone it's not hooked up to a data connection. If you look at the schematic of the USB port pins two and three are for data connections. Most chargers already have these shorted out. The disclaimer is for people that short out pins 1 and 4 on the usb port or just dump a ton of solder on the whole board.
WeGo4x4 is offline
post #6 of 10 Old 12-11-2010, 07:56 PM
nlgrav182's Avatar
I didn't mean literal heat, I meant juice. Be careful with that thing, especially the way people have been turning their Jeep into original recipe buckets.
OKAY FUCKMOUTH.
post #7 of 10 Old 12-11-2010, 08:43 PM Thread Starter
WeGo4x4's Avatar
I totally understand. You are right. The crap from China shouldn't be trusted, that's why I put the disclaimer in. The always on port shouldn't have anything left plugged in I don't care who makes it.
WeGo4x4 is offline
post #8 of 10 Old 12-11-2010, 09:16 PM
Why not just buy one, I got one for my iPhone at Wally world for 12 bucks, it 1 amp I think, all I know is it charges it faster than any where else.
If you were going to all this why not do the same on your radio? I plan on doing this to my mygig one Of these days, solder a cable inside to the front USB connection and add the missing "charge" feature as well. All the cords in the jeep are driving me nuts!
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #9 of 10 Old 12-11-2010, 11:10 PM
axsys's Avatar
Then you couldn't load anything onto the MyGig via USB drive.
axsys is offline
post #10 of 10 Old 12-12-2010, 09:28 AM
Guruman's Avatar
Sounds like we need an "adapter cable" with the shorted pins to plug into the mygig for charging, then bypass the cable for data connections when needed.
_
Guruman is offline
