Manual Tranny Breather - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 10-14-2010, 03:32 PM Thread Starter
OlegRock's Avatar
After I got about 1 gallon of water in the tranny... I figured I need to extend the breather. Also using TKOB's write-up extend all you other breathers people!!!
I got this idea from Bubba2U and think his idea is better... but I figured I'd show more pix and show how lazy people do shit...
here is Bubba's write-up...
https://www.jkowners.com/forum/showthread.php?t=27213
Step 1
Take your shifter knob off. This is easy... pull on it hard and as you pull wiggle it... it should pop off.
Step 2
Take your shifter boot off... again, very easy. Pull it up from the side closest to the cupholders.
Step 3
Take off the second shifter boot... the same way you did the first.
Step 4
Carefully undo the foam closer to the driver side (see second pic below).
Step 5
See the BLACK PLUG right outside the upper left corner of the circle????
Take it off. I used pliers.
Step 6
Need to put a small piece of 1/2" fuel line on the plug (your breather). It is very tight in there and I was not able to use a ziptie... so I crazy glued the fuel line to the breather.
Step 7
Take a universal fitting (pic below) to convert the 1/2" hose to a hose of your choosing... I used 3/8" fuel line.
Dont forget to use zipties!!
Step 8
Cut a hole in the first shifter boot for the plug... then put it back on. As you see in the pic below... you need to insert the tabs to put it back on...
Step 9
Put your 3/8" line into the fitting and extend it where-ever you need to
Step 10
Put the second shifter boot back on and the shifter handle
OlegRock is offline
post #2 of 20 Old 10-14-2010, 03:32 PM Thread Starter
OlegRock's Avatar
I extended the breather under the passanger dash and around the side dash and the plastic windshield pieces...
OlegRock is offline
post #3 of 20 Old 10-14-2010, 03:46 PM
Hmm thanks for the info. Will have to get to that.
post #4 of 20 Old 10-15-2010, 03:06 AM
Chromantix's Avatar
Because I already have about 200 links to various things on JKO that I want to do, I'm going to just start tagging threads with words which will come up in future searches: waterproofing manual transmission
Thanks OlegRock!
2010 Unlimited Preferred Package: Manual EVERYTHING
Chromantix is offline
post #5 of 20 Old 10-15-2010, 07:23 AM
DataByte's Avatar
Send a message via AIM to DataByte Send a message via Yahoo to DataByte
sweet!
Great pictures!
Matthew D
2008 Silver Sahara
*Mention JKOWNERS.com for a 10% discount at checkout*
DataByte is offline
post #6 of 20 Old 10-15-2010, 11:35 AM
BadAssJK's Avatar
Very good to know. I was just always told the manual tranny had no breather.
What are the red hex heads I see around the shifter bezel. The dealer took mine off one day and it never stays put ever since then.
BadAssJK is offline
post #7 of 20 Old 10-18-2010, 08:58 AM Thread Starter
OlegRock's Avatar
I put nuts and bolts there because the boot tends to come apart so this holds it better.
OlegRock is offline
post #8 of 20 Old 12-07-2010, 01:59 AM
Hate to pull up an old thread, but dont want to post a new one. Will this make it so i can comfortably press the clutch in while underwater??
07 Jeep 2door Rubicon 6-speed
Rescue Green
Teraflex 3.5
OME Long Travel's
Crown Brake Lines
Bedlined Grill
AEV Snorkel
35 inch Goodyear MTR Kevlars. EPIC TIRES
Mickey Thompson Classic II
Narrow Chopped Fenders
OR-Fab Stubby Stinger
Warn 9500
IPF Lights on MBRP Hood Brackets
Midland CB, Firestick II 4'
Custom: Cb Bracket / Grab Handles
SOLID Diff Cover
Rugged Ridge Floor Mats
AndrewCote is offline
post #9 of 20 Old 12-07-2010, 02:09 AM
Hittnthebz's Avatar
Cool writeup!
Hittnthebz is offline
post #10 of 20 Old 12-09-2010, 03:32 PM
2010jk's Avatar
Is that a filter up on the right side?
2010jk is offline
post #11 of 20 Old 12-09-2010, 04:07 PM
paramaniac's Avatar
No. There are vents of sorts on the trans housing underneath the body. No matter what, never press the clutch pedal while submerged
paramaniac is offline
post #12 of 20 Old 12-09-2010, 04:50 PM Thread Starter
OlegRock's Avatar
you mean in the last pick?? Then yes.... thats where I extended the breather to and put a filter there for the breather.
OlegRock is offline
post #13 of 20 Old 12-09-2010, 05:20 PM
2010jk's Avatar
thanks man, and nice wright up to, I am going to have to do this.
2010jk is offline
post #14 of 20 Old 12-18-2010, 12:13 AM
then why do this?
Rescue Green
Teraflex 3.5
OME Long Travel's
Crown Brake Lines
Bedlined Grill
AEV Snorkel
Warn 9500
SOLID Diff Cover
post #15 of 20 Old 12-18-2010, 07:42 AM Thread Starter
OlegRock's Avatar
then why do this?
this is so your tranny fluid doesnt get water in it when your under water.
OlegRock is offline
post #16 of 20 Old 12-18-2010, 08:37 AM
paramaniac's Avatar
Pressing the clutch while submerged allows water into the clutch assembly via those vents. Apparently someone had some sort of brain fart while designing this
This mod will prevent water from entering your gear box and mixing with the trans oil causing a milky non-lubricating mess
Sent by carrier pigeon
post #17 of 20 Old 12-18-2010, 12:41 PM
RubiZealot's Avatar
<Stupid Question> How does replacing a rubber plug with a hose make it more waterproof? Does water get past that plug? </Stupid Question>
Mike 2010 Rubicon 2DR | RK 3.5 X FACTOR MID ARM | ΜΟΛΩΝ ΛΑΒΕ
RubiZealot is offline
post #18 of 20 Old 12-18-2010, 12:52 PM Thread Starter
OlegRock's Avatar
The rubber plug is the breather. So if water is above that breather then water can and will get into your tranny fluid.
I replaced it with a hose and routed the hose. If you see post #2... NOW the breather is almost the same hight as my roof. So now the only way water is getting in the tranny if is I'm below water past that breather (at the passanger side windshield frame).
OlegRock is offline
post #19 of 20 Old 12-18-2010, 01:40 PM
RubiZealot's Avatar
hrm. I'll have to do this. I raised all my other tubes using the RR kit. I guess I can tap into that. Do you smell any difference with the vent now in your passenger compartment?
post #20 of 20 Old 12-18-2010, 01:54 PM Thread Starter
OlegRock's Avatar
no... but I put on doors once a month... and I don't own a top
OlegRock is offline
