Wanna be Brute with JK running gear... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 40 Old 07-29-2010, 04:33 PM Thread Starter
mikeyapproved's Avatar
Ok, thought I would post this as I go along....
Did this cause I had the TJ.... and I had the JK running gear or most of it...
Hope it works and hope you like it?
Mikey
Started with this tub and frame...
Buy high
Sell low
A motto my wife wants me to change!!
mikeyapproved is offline
post #2 of 40 Old 07-29-2010, 04:38 PM Thread Starter
Then added parts from this:
Buy high
Sell low
post #3 of 40 Old 07-29-2010, 04:47 PM Thread Starter
want it too look something like this:
Note: I had the wrong pic earlier.... this one is a little different, longer wheelbase, but the same overall length.
First one I posted is 2nd in line here.... I like the longer wheelbase better.
That's one of the things I do not like about the AEV Brute, the box design looks terrible with the roof off (box sides are higher than the tub sides) and the rear box overhang is too long.
So I fixed these issues with this photoshop image...
Original Brute 3rd in line
Buy high
Sell low
post #4 of 40 Old 07-29-2010, 04:56 PM Thread Starter
Needed to shorten the tub....
moved it into the shop...
Buy high
Sell low
post #5 of 40 Old 07-29-2010, 05:02 PM Thread Starter
Removed the rear of the tub, took the back panel and positioned it where the cab length dictated...
Note the custom Rockers/corners by TNT Customs!
Buy high
Sell low
post #6 of 40 Old 07-29-2010, 05:05 PM Thread Starter
The Rockers/corners cover all the work done to the tub.....
Rhino liner on the inside of the tub once the rockers are on for good, and I hope it looks ok??
Needed to lengthen the frame a couple of feet in the middle, plus add a custom touch to the rear of the frame too...
That's the next big part of the project...
Cab is from Collin's Bros in Texas...
mikey
Buy high
Sell low
post #7 of 40 Old 07-29-2010, 05:12 PM
Ogie's Avatar
Nnnnnnniiiiiiccccccceeeeee.
But you got to re-size those pics.
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #8 of 40 Old 07-29-2010, 05:15 PM
JohnnyWalker's Avatar
Brutes give me the backwards renob
JohnnyWalker is offline
post #9 of 40 Old 07-29-2010, 07:01 PM
bodyguy's Avatar
? where are you located
bodyguy is offline
post #10 of 40 Old 07-29-2010, 08:06 PM
Trail Concepts Hmfic
jdemonto's Avatar
Interesting build, was goig to build a brute now going to keep my lj and do a motor swap and possibly jk axles.
Jason
602-314-5356 or
jdemonto is offline
post #11 of 40 Old 07-30-2010, 10:29 AM Thread Starter
Sorry forgot to put this in my profile.....
added now.
Buy high
Sell low
post #12 of 40 Old 07-30-2010, 10:32 AM Thread Starter
Jason
The LJ would work really well for this type of cab mod..... you would not have the wheel well cutout messing things up!
The TNT Customs Rocker/corners look like they are going to work well though...
They built them for the Brute Cab initially, but the cab from Collins Bros is 1 1/2" shorter than the AEV cab, so I had to modify the door opening on the armor...
mikey
Buy high
Sell low
post #13 of 40 Old 07-30-2010, 11:36 AM
brokenleaf's Avatar
Cool build. Subscribed!
-Jeff
KG6VPY
brokenleaf is offline
post #14 of 40 Old 07-30-2010, 01:16 PM
Subscribed!
ccwbrd is offline
post #15 of 40 Old 07-30-2010, 01:21 PM
Makin your own Jeep! Sweet!
4x4x4 is offline
post #16 of 40 Old 07-30-2010, 03:49 PM Thread Starter
Frame stretch between axles...
Next is rear long arm mounts at the flat skid...
Buy high
Sell low
post #17 of 40 Old 07-30-2010, 03:53 PM Thread Starter
Rear long arm mounts and front arm mounts at the skid.... along with skid mods.
Buy high
Sell low
post #18 of 40 Old 07-30-2010, 03:55 PM Thread Starter
Oh ya, had to place the JK engine and 6 speed in place and fab mounts
Buy high
Sell low
post #19 of 40 Old 07-30-2010, 04:00 PM Thread Starter
Then I had to mockup the exhaust....
I wanted to use everything I could from the JK, so I used all the exhaust, cats, muffler etc and made it work in this unit.... Note the muffler is in front of the axle, as in a JK it is behind the rear axle. I just used the Tj layout, fuel tank behind the axle, then with the center frame stretch, I was able to tuck the stock JK muffler in front of the rear axle...
Buy high
Sell low
post #20 of 40 Old 07-30-2010, 04:02 PM Thread Starter
Once I had the exhaust mocked, installed the tub, removed the tub and made adjustments, installed the tub, removed the tub etc etc....
I had it done, or so I thought.
More on that later!
Oh, ya added the stock JK heat shield and made some additional ones based on the JK design.
Buy high
Sell low
post #21 of 40 Old 07-30-2010, 04:04 PM Thread Starter
I also started on the box mount design...
Had to make it level and square to the tub.... had to set the tub on and square it to the frame first...
Buy high
Sell low
post #22 of 40 Old 07-30-2010, 04:08 PM Thread Starter
So then the rear frame was too short for the box length I wanted.... so I hacked it off and designed my own rear frame. Because of the way the box floor was going to work, I was able to move the fuel tank back about 7" from stock, plus raise it 3 1/2" from stock
Buy high
Sell low
post #23 of 40 Old 07-30-2010, 04:10 PM Thread Starter
Then I added some bumper mounts
I used the idea from Extreme 4x4 and used spray on box liner for the frame coating...
ok, enough of this, I gotta get back into the shop!!
mikey
Buy high
Sell low
post #24 of 40 Old 07-30-2010, 07:21 PM
curbsjeep's Avatar
Wish I had the garage to play in...
curbsjeep is offline
post #25 of 40 Old 07-30-2010, 09:00 PM
OlegRock's Avatar
SUBSCRIBED!!!
OlegRock is offline
