Hood bounce/Jump/Flutter fix - JKowners.com : Jeep Wrangler JK Forum
post #1 of 31 Old 07-29-2010, 10:47 AM Thread Starter
I am sure many have seen the drake offroad hood latches. I like them and the look but they are too expensive for me...
Then I ran across parts to make it for less than $20...
Found the critical parts on ebay - Race Basics store - while searching for Heim rod ends. Matched up a set of 1/4 male and female for a whopping $12 plus shipping and then found the screw and post at the local hardware store for $1.19.
I used 1/4 drill bit for the holes in the top and a 3/8 bit to drill the lower pin:
I knew I had to remove the original strap so I carefully drilled out the lower pin holding the rubber OEM strap - using the 3/8 drill I drill far enouh to make the cap easy to cut off but not all the way into the bracket:
After I had drilled the middle out I carefully cut the outer plastic with a razor knife:
And end up being able to pull the pin out with needle-nose pliers:
I then inserted my post and screw in the lower portion making sure to have the heim in between the brackets.
Had to drill a hole in the top bracket so i sould insert a top retaining pin:
Then it was a fairly simple process of adjusting the heim threads to the correct length and inserting the retaining pin I got at a local trailer parts store for $2.15:
Then insert the top pin through the holes drilled.
Working great so far:
Hope it helps those of you that like this look. Only took about 20 minutes on each side once you have the parts ready. Go slow so the holes are aligned and no accodents happen.
tbfreebird is offline
post #2 of 31 Old 07-29-2010, 11:04 AM
HOOLIGAN's Avatar
I love it!!!!
links to parts:
Heim Rod End Male 1/4" Righthand - NEW
Heim Joint Rod End 1/4" Righthand thread Female- NEW
HOOLIGAN is offline
post #3 of 31 Old 07-29-2010, 12:03 PM
leman's Avatar
great job.
so the holes are 1/4"? im thinking about putting eye bolts there to run my limb risers
2008 steel blue sahara
with some doo-dads
leman is offline
post #4 of 31 Old 07-29-2010, 03:00 PM
JK-ADD77's Avatar
Nice fix and write-up! Thanks for sharing! We all need to save cash-ola!!!
ADD
JK-ADD77 is offline
post #5 of 31 Old 07-29-2010, 03:04 PM
StubEXrube's Avatar
Sweet. Looks clean- almost factory.....well not really factory, since Chrysler seldom designs something that looks good and actually works.
StubEXrube is offline
post #6 of 31 Old 07-29-2010, 09:45 PM
spillidge's Avatar
Looks really good man!
I took the lazy mans route and took off the hood spring....
spillidge is offline
post #7 of 31 Old 07-29-2010, 09:47 PM
mckbrew's Avatar
Awesome Job. Well done.
mckbrew is offline
post #8 of 31 Old 08-29-2010, 08:46 AM
Sanderbody's Avatar
Nice job!
Sanderbody is offline
post #9 of 31 Old 08-29-2010, 08:50 AM
knyland's Avatar
That looks good. for some reason my flutter stopped when I changed to PSC flares and removed the fender liner. my luck it will come back and i will be doing this fix.
This is one reason I have a strict policy of not eating anything out of another dudes butt. Flick it with my tongue? Sure. Run my tongue around the rim? Depends. Dart my tongue in for a brief second? Maybe. Eat something out of it? No fuckin' way!
If you want to know whats on it check my
knyland is offline
post #10 of 31 Old 08-29-2010, 08:54 AM
RODICON's Avatar
Nice!
2014 Rubicon on the build!
RODICON is offline
post #11 of 31 Old 08-29-2010, 12:31 PM
Mr.RonGilbert's Avatar
Well done.
Mr.RonGilbert is offline
post #12 of 31 Old 09-05-2010, 11:05 PM
OK shit, flame suit all zipped up The stock rubber hood straps are working as designed. No fix is needed. Its designed to work the way that it does. We drive over bumpy stuff so flex is needed
post #13 of 31 Old 09-06-2010, 06:54 PM
JDodge's Avatar
Ok.....so what kind of front flares are you runnin?
JDodge is offline
post #14 of 31 Old 09-07-2010, 10:34 AM
07unlimitedx's Avatar
Nice fix... I'll have to do this someday soon.
07unlimitedx is offline
post #15 of 31 Old 09-07-2010, 03:27 PM
Nice Fix! I'm gonna look into this!
AlanZ is offline
post #16 of 31 Old 10-18-2010, 10:05 AM
Monster Jk's Avatar
Feedback: 23 reviews
hey, did this and it looks awesome, i switched mine so its a little different though. i was able to take the cap i drilled and put it back over the hole. i also broke off the other side and put it in back in the hole to kind of make a nice factory...ish look. i also got some plastic spacers for the bottom so it didnt slide back and forth. looks and works amazing.
Monster Jk is offline
post #17 of 31 Old 02-12-2011, 09:20 AM
i do alot of hwy driving so the flutter was really a problem and kinda scary sometimes so i bought the daystar hood latches and why work awesome !!! and only about $20. a bit of a pain to install but that only because fat fingers and small holes to reach inside of old hood latch! other then that they are rock solid ! no flutter and they are TIGHT !!!
jonnybo20 is offline
post #18 of 31 Old 02-23-2011, 06:30 PM
I removed the spring for the bonnet release. The one that makes the bonnet pop up when you undo the latches. 95% of hood flutter gone.
sixfootfour is offline
post #19 of 31 Old 04-23-2011, 01:45 PM
Butkus34's Avatar
agreed, did this too and took away most of the flutter
2007 JK Unlimited Sahara, Blacked Out
3.5 inch lift sitting on 35's
Poly Performance/Synergy Suspension Ball Joints
Smittybilt Oversized Tire Carrier
Butkus34 is offline
post #20 of 31 Old 04-23-2011, 02:01 PM
hogzilla's Avatar
daystar latches and removed the spring. pretty much fixed it except when a big rig passes me going the other way. just my 2 cents
hogzilla is offline
post #21 of 31 Old 08-30-2011, 11:51 AM
ScaleJK4x4's Avatar
Can we get pictures reposted?
ScaleJK4x4 is offline
post #22 of 31 Old 08-30-2011, 11:55 AM
x2!!!!!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42Ē MTR's
17" Spyderlock Beadlocks
post #23 of 31 Old 08-30-2011, 11:57 AM
Another method:
Remove hood spring.
Discard.
Enjoy flutter free hood.
Cost: FREE.
Dancin Dan is offline
post #24 of 31 Old 08-30-2011, 12:25 PM
gold knight's Avatar
Originally Posted by JKUnlimitedSport_2010 View Post
x2!!!!!
Sorry, there is no way I know of to repair the write-ups once links are broken. You might find a couple more that are still good here.
https://www.jkowners.com/forum/showpo...03&postcount=5
gold knight is offline
post #25 of 31 Old 08-30-2011, 01:54 PM
Daniel_M's Avatar
Another method:
Remove hood spring.
Discard.
Cost: FREE.
Bingo, removed my hood spring too and it stopped. FREE mod. I can do a write up too if y'all want. Seriously the weight of the damn hood keeps it down while driving down the street.
-Dan
2008 JK X: Sold
Daniel_M is offline
