Heat Fix for the Floor pan! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 07-25-2010, 12:26 PM Thread Starter
mrsig's Avatar
I have the rubber floors in my JK and they get hot! This is fast cheap and easy!
Quick Roof is about $20.00 a roll & you can get it at Home Depo. It will stop the heat and deaden the sound too! Yes this is made to fix your homes roof! One roll will do the drivers and passengers floor.
Pull your carpet, Than clean your floor very good with Simple green than hit it it with some rubbing alcohol.
Next just cut the piece you need and lay it out. Than pull the back paper off and roll it off a little at a time. make sure it is where you need it it will not come off or move once it is on the metal. Work it in the crack and lines of the floor with your finger till the strip is done.
And repeat till your done!
Then put your floor or carpet or mats back in!
Drove for a wile today and it seems to work good!
CEO of Black Sheep 4x4s
mrsig is offline
post #2 of 17 Old 07-25-2010, 12:42 PM
sniper41's Avatar
Nice, thanks for that info, I see my next immediate mod coming up. We pulled the carpets and yes, the floor does get hot even with the heavy duty floor mats!
Jersey
Crew
sniper41 is offline
post #3 of 17 Old 07-25-2010, 12:51 PM
Ron R's Avatar
I wonder, would a Line-X or Rhino shop be willing to spray on top of that? I was thinking of pulling the carpet and doing a complete Line-X interior but the foil on the back of the carpet does offer some heat and sound protection that I would lose so I've held off.
Ron R is offline
post #4 of 17 Old 07-25-2010, 03:14 PM
tkob1060's Avatar
my linex keeps the heat down enough where I can drive barefoot no problem
Sig can that stuff be pealed off if someone decides to remove it?
tkob1060 is offline
post #5 of 17 Old 07-26-2010, 02:56 AM Thread Starter
mrsig's Avatar
Yes but it will take some time! It sticks down very very strong!
mrsig is offline
post #6 of 17 Old 07-26-2010, 10:00 AM
Jaybee1669's Avatar
It has an asphalt base, so once it sets it is really messy to get off.
Jaybee1669 is offline
post #7 of 17 Old 07-26-2010, 12:15 PM
joePILE's Avatar
NICE
might have to do this too
2008 BLACK Unlimited Sahara
and
joePILE is offline
post #8 of 17 Old 07-26-2010, 01:39 PM
Fklein6768's Avatar
Any thought to applying it on the underside of the floorpan?
Fklein6768 is offline
post #9 of 17 Old 07-27-2010, 10:46 AM
Jaybee1669's Avatar
If the asphalt base gets hot enough it will melt and pull away. It doesn't work well inverted on a hot surface.
post #10 of 17 Old 07-29-2010, 07:27 AM
Ron R's Avatar
I should put this on the underside of the hard top, then cover it with a headliner. Should keep the heat down a lot.
Ron R is offline
post #11 of 17 Old 07-29-2010, 07:40 AM
does it have any odour to it since its asphalt based?
Blacked out 07 JKUR, safari straps, Treadwright 35's on stock rims and Spydertrax spacers, stubbied front bumper, trimmed flares, 2" body lift, 2" spacers in front with 1" spacers in rear, Gen Right Tire carrier, more to come!
Badd Andy is offline
post #12 of 17 Old 07-30-2010, 10:49 AM
no they won't and the floor gets hot with the linex
decipher911 is offline
post #13 of 17 Old 07-31-2010, 05:50 AM Thread Starter
mrsig's Avatar
The first 2 days you will have a bit of a tar smell but it will go away after that. I have a long trip coming up so than I will know how good it works..
mrsig is offline
post #14 of 17 Old 08-04-2010, 07:45 AM
Taxx's Avatar
That is going to trap moisture underneath it.
A floormat would be a better option.
Taxx is offline
post #15 of 17 Old 08-04-2010, 09:00 AM
MissMandyOK's Avatar
I was thinking the same thing. If anyone does do that, let me know how it works.
PS- I was looking on their website and they also have it in white.
2009 4 door X 6speed
MissMandyOK is offline
post #16 of 17 Old 10-06-2011, 06:36 PM Thread Starter
mrsig's Avatar
It has been over a year and still working great with no problems.
mrsig is offline
post #17 of 17 Old 10-12-2011, 08:06 PM
Hey thats a great idea. At the Home depo, I have to look around a little more. Boy I'm going to be busy.
Ruben
07 JK Rubicon - Banks Cold air intake and Monster exhaust - ARB front and rear bumpers - Warn 9.5Ti - OME 4inch JK Lift - 33inch MTZ
01 Grand Cherokee - inline 6 - Jeep Hitch Receiver - Jeep Fog-Light kit - Jeep Bug Deflector - Jeep Wind Deflector - Jeep Tow Hooks - Jeep Sub-woofer - OME 1 1/2 coils - Dynomax 2 1/2 Cat back - Running 265 75 16 - K&N air Filter and a modified air box
Valfam is offline
