Removing radio/hvac controls - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 07-16-2010, 12:13 PM Thread Starter
Blackr6's Avatar
Someone please school me on this. Having a hard time putting all the pieces together I want to put some LEDs under the hvac and disconnect buttons at very bottom but can't figure out how to break it all down....
Blackr6 is offline
post #2 of 3 Old 07-16-2010, 12:52 PM
musicman's Avatar
Send a message via MSN to musicman
Im assuming you want to take the radio bezel off? You start at the top: top cover has 2 snap clips at the back of it and it rolls forward. The you will find 2 7mm bolts at the top of the radio, take those out. At the bottom section (right behind the shifter) there's a flat panel that also pops off, behind that there are 2 more 7mm bolts and they must come out. once the 4 bolts are out the whole bezel is just held in wioth snap clips, gently pop them out and away you go.
Other questions?
musicman is offline
post #3 of 3 Old 07-16-2010, 01:11 PM
maverick's Avatar
http://www.coastaletech.com/WRANGLER_INSTALL.htm
maverick is offline
