JK aux fuel tank- The Long Ranger - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 06-25-2010, 10:17 AM Thread Starter
New here, but perhaps some will recognize me from other forums. Anyways, I just finished up installing a Long Ranger auxiliary fuel tank in a 2007 JK (actually, it's an EarthRoamer XV-JP... but same difference, right?), and thought I'd share it with you all. I posted the full writeup over on Expedition Portal.
WhereTheHellIsJames? is offline
post #2 of 19 Old 06-25-2010, 10:23 AM
gold knight's Avatar
Welcome WTHIJ, nice write-up. Would you be interested in posting it here as well?
gold knight is offline
post #3 of 19 Old 06-28-2010, 12:35 AM Thread Starter
Sure... here's the install writeup and pics:
The JK 4-door is a pretty cool rig. Make it a Rubicon, and it's even better. Make that Rubicon an XV-JP Earth Roamer and the coolness factor pretty much skyrockets. Whatever the model though, there's a common issue amongst these vehicles, and that is the potential range.
So what does one do to increase a vehicles range? For the most part, the options for JK owners are pretty limited- either carry around a bunch of fuel cans, order a GenRight and cut out your muffler, or wish you lived in Australia, where you could pick up a Long Ranger.
The long and the short of it is, that carrying around a bunch of fuel cans just wouldn't work for the application that I'm working on, nor would removing the exhaust be an option- after all, this vehicle is not just an off-road rig, and needs to be very drivable on the street too.
Below is the solution that I came up with. After being told that there is absolutely no warranty, nor is there any guarantee that it will fit, and, after a couple months of waiting for a container from down under... The Long Ranger TA64P:
For those of you who are curious, here's what the contents of the package look like:
After many emails with the manufacturer, I decided that it "should" fit into a USA-spec vehicle. However, according to both the manufacturer and ARB, this is apparently the first time anyone has attempted this install in a USA-spec JK, so it may or may not be a typical installation... nobody really knows for sure.
Come to think of it though, this can't be a typical install... if for no other reason than the tank is being fitted to an EarthRoamer XV-JP. There will need to be some modifications made to the undercarriage before the tank will even fit in the spot that it's made for on its Aussie brethren. First things first, will be to remove the EarthRoamer skid-plate:
The challenge here, is that underneath the skid-plate is where the two group 31 auxiliary batteries reside:
These will obviously need to be relocated, but there are space limitations on this vehicle which will likely make things somewhat interesting.
I'll post up more info and pics as I progress towards and through this project- likely next week.
post #4 of 19 Old 06-28-2010, 12:45 AM Thread Starter
...and the followup
Good news for those who are wondering if a Long Ranger auxiliary fuel tank will fit in a U.S.A. spec JK 4-door... oh yes, like a glove.
It was a long day of work on the XV-JP today. First was the task of uninstalling the auxiliary batteries to make room for the new Long Ranger fuel tank that will be taking up the space where the batteries currently live:
For what it's worth, here's a pic of the storage compartment under the floor in the rear of the EarthRoamer. This is where I intend to put the two group 31 auxiliary batteries- if I can somehow make them fit:
I measured and remeasured this space a couple of times, and I think that if I cut out the floor, cut out the box, fab up a new box about 1/2" deeper, 1" wider, and about 2" longer, not to mention square instead of rounded corners, they'll be a perfect fit. I'll model it up before any cutting though... just to make sure.
Installation of the Long Ranger fuel tank required 4 holes do be drilled through two different chassis cross-members, 2 holes in each. The first hole is required so that a heat shield can be placed to protect the fuel tank from the hot exhaust pipe. Here's a pic of the heat shield in place, batteries out of the way, and the area cleared for installation of the fuel tank:
There are a couple of ways that the installation steps can be altered to break up the work a bit, so that all of your time isn't spent under the truck. One of the steps is to install a breather for the Long Ranger tank. This requires one to cut the factory breather tube, place a little metal fitting to fill the section that you cut out, then attach it all with hose clamps. Sounds easy, right? Well it would be if there was any other way to access this thing. The only access though, is through the left rear taillight hole, and it's difficult to fit both arms in there to do the work. Here's the finished product of that step, looking forward through the taillight hole:
The tank requires a bit of servicing and build-up before it gets installed. The first thing that I did was to thoroughly vacuum out the tank. It was pretty clean in there, but there were a few metal shavings (I suspect from fabrication) in there, so I'm glad I took the time to take this precaution. A bit of time spent in prep is a lot easier than changing out a damaged fuel pump.
Before the tank is mounted, the installer need to add a couple of things- the fuel gauge sender unit, a breather hose between the two high points of the tank, the filler hose to the main tank, and the fuel pump:
The next big step is to test fit the tank. It's hard to maneuver it in there, especially by one's self, and a floor jack came in quite handy. Once the tank is in place, the next step is to drill more holes through the cross-members to mount it, 1 in the front, and 2 in the rear. It's important that the holes are in the correct location, otherwise there may be some driveline interference when you're flexed. Tip: you'll need a very long 3/8" drill bit for the rear right hole.
Once the holes are drilled, you get to practice your skills as a contortionist. This was my least favorite part of the install- you're all crossed up, then your neck, arm, whatever, gets tired, then cramps up and causes you to drop a nut that you were trying to place right into a cutout of the cross-member. Then the whole thing comes out, you retrieve the nut, and start over. meh. As a side note- if you're planning this install, be it known that there's no room for mechanics gloves, and you'll probably cut up your hands really nicely. If your day job is being a hand model or something, you'll probably want to have this tank professionally installed.
Anyways, here's what it'll look like when you *finally* get the thing in:
After you finally get this thing all bolted up, you feel pretty good- it's in! then you remember that you still have some plumbing to do, not to mention that you still have to relocate the emissions goodies. Actually, the emissions goodies are supposed to be relocated prior to final installation. I believe that on a typical JK 4-door that this option would be the best route to go. However, because of several factors of what;s under the EarthRoamer, I though it to be best to save that step until after the tank was in. Hopefully I don't kick myself for this later! Here's the rear of the tank prior to finishing up the plumbing:
A lousy shot, I know, but it was the end of a long day. I'll get some more pics up later this week when I finish the plumbing and emissions goodies re-installation and relocation.
post #5 of 19 Old 06-28-2010, 12:49 AM Thread Starter
FYI-
Good news! I finished the plumbing and took the vehicle for a test drive... no lights, no codes. Apparently this tank does work in a U.S. spec JK.
*sigh of relief*
Note: FWIW, this was not an 'easy' job. It takes time, a lot more than you'd think. Also, there are a couple of specialty tools that will make the job a LOT easier, and I'd suggest taking on the project only if you are confident in your skills, and have good facilities to do this type of work in. I spanned the project over two days (1 full, and 1 partial), but feel that I could now probably do this install in one day after having this first one under my belt.
post #6 of 19 Old 06-28-2010, 02:24 PM
Porter's Avatar
Very nice work. How thick is the aux tank? Will it need a skid plate if you take it one the rocks or is it good as is?
Porter is offline
post #7 of 19 Old 06-28-2010, 02:36 PM
.:eMETAL:.'s Avatar
awesome! will other companies skid systems work with this?
.:eMETAL:. is offline
post #8 of 19 Old 06-28-2010, 06:36 PM
Mr.RonGilbert's Avatar
Nice setup, how about some more pics of the earthroamer...
Mr.RonGilbert is offline
post #9 of 19 Old 06-28-2010, 07:41 PM
idrivejeep's Avatar
Nice installation, thanks for taking the time to do the write-up.
My dog is worried about the economy because Alpo is up to 99˘ a can. That's almost $7.00 in dog money.
idrivejeep is offline
post #10 of 19 Old 06-28-2010, 08:03 PM
maverick's Avatar
As a Jeep owner you are naturally adventurous. The
4 door wrangler is now capable of some serious
outback touring. The Longranger Auxiliary tank
extends the capabilities of the vehicle, allowing
you to explore every track. An 80% increase in
fuel capacity safely carried under the vehicle,
brings the total capacity to 153lt.
In keeping with jeep’s off road qualities the standard
ramp over angle is maintained. A complete new
38mm filler replaces the standard 26mm OEM
unit for improved filling. A new dash mounted
LED switch/gauge provides the user with
the option to transfer fuel at the push of a button when
required, while displaying available fuel in the Auxiliary tank.
Features:
68lt capacity
Easy fitting, supplied with complete fitting kit
and detailed instructions.
3 Year warranty.
2mm Aluminium coated steel construction.
Full internal baffling.
Maintains good departure angle.
No exhaust modifications required.
The safest alternative for fuel storage.
A new HI-Flow 38mm filler supplied in kit.
Fully Mig welded and pressure tested.
maverick is offline
post #11 of 19 Old 06-29-2010, 12:04 AM Thread Starter
I'd suggest a skid plate below this tank if you plan on doing any driving where there is a good chance that the tank could be struck by a hard object.
I haven't seen one that will.
I was hoping that the EarthRoamer skid plate could be bolted right back on to the Jeep after I installed the fuel tank, but the tank hangs about +/- 3/4" lower that the battery carrier that the skid plate was designed to protect (with zero clearance), so I'll need to build a custom skid plate for this XV-JP.
post #12 of 19 Old 06-30-2010, 12:43 PM
MannyLx450's Avatar
Feedback: 17 reviews
Send a message via AIM to MannyLx450
The best info ever found.
Thanks for share We just recive the LongRanger tank yesterday to test it also
Manny
Your Rigid Industries Source
PH: 754-201-58-48
MannyLx450 is offline
post #13 of 19 Old 06-30-2010, 05:18 PM
Features:
68lt capacity
3 Year warranty.
What they don't mention is that you CAN order them with a second, thicker skin on the base of the tank for people who think they'll be doing anything other than touring.
I was going to get one for my diesel but its range is good enough as is and also the JK isn't built well enough to be a proper tourer - so weekend adventurer it remains!
ex: RHD JK 2dr CRD auto
CRDTom is offline
post #14 of 19 Old 07-01-2010, 05:07 AM
maverick's Avatar
Thanks! How thick is that thicker skin?
maverick is offline
post #15 of 19 Old 07-01-2010, 06:02 AM
ADDICTION II build begins....
TXROCK's Avatar
In case anyone is interested, here is the website for the Long Ranger:
http://www.thelongranger.com.au/4wdfueltanks.html
U.S. Army
TXROCK is offline
post #16 of 19 Old 07-01-2010, 02:47 PM
maverick's Avatar
Originally Posted by MannyLx450 View Post
Long Ranger Available Now with Miami 4x4 Offroad
Call us for more INFO.
Manny
So... How thick is the second skin?
maverick is offline
post #17 of 19 Old 07-01-2010, 08:16 PM
4mm plate steel was what I remember.
These tanks are made by "Out of Town 4x4" in Australia.
http://www.ausjeepoffroad.com/forum/member.php?u=12726 This is Rick - he is one of the production guys.
I would say the guys at Miami 4x4 need to get in touch with him and arrange for the the beefed up tanks for you fellas.
If you like rocks though I'd say it'd be a bad idea to get the aux tank. I reckon you'd be better off scrapping the OEM tank and fitting a custom tank which is leveled off at the bottom of the chassis rails and split it up between each side of the vehicle. Would work well to redistribute weight, achieve a higher fuel capacity and increase ground clearance. Possibly not cheap though.
CRDTom is offline
post #18 of 19 Old 09-30-2011, 06:36 PM
jester116th's Avatar
Where can I buy this in the states??
jester116th is offline
post #19 of 19 Old 10-01-2011, 02:22 PM
b1pig's Avatar
judging by previous post... miami 4x4
b1pig is offline
