Quick & Easy Trans Fluid Change - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 05-11-2010, 09:51 AM Thread Starter
TrailDuty.com
PhilD's Avatar
If you have an external transmission fluid filter, you can change the fluid in 10-15 minutes without all the hassle of dropping the pan. Even if you have to drop the pan to change the filter, this method will change more of the fluid than just what is in the pan, so is a good idea anyway.
If you have an additional trans cooler or external filter it will be real easy, if you don't it may be a good time to add an additional trans cooler.
All you need is a bucket, graduated in quarts, and some hose. I like to use a section of clear hose so I can see the color of the fluid coming out. You will need to divert the fluid flow as it goes to the cooler to your bucket, I do it between my additional cooler and filter as it is the easiest place for me to get at.
If you have two people you can try pouring in the fluid at the same time it comes out, but the odds are you won't keep up with it. I run the engine until 2 quarts have come out, stop, add two quarts, run the engine again, etc, etc.
By about the 8th or 9th quart the fluid is looking pretty good. Once it looks good I just run another couple of quarts through for good measure. Then reconnect everything, check the fluid level, and call it a day.
PhilD is offline
post #2 of 7 Old 05-11-2010, 11:34 AM
Prope's Avatar
You must put a ton of miles on your Jeep! Nice thought on the external filter! I'm need to change my fluid & this is a good idea.
'08 Unlimited Sahara - Hemi -
Fenders & Rockers -
Prope is offline
post #3 of 7 Old 05-11-2010, 11:54 AM Thread Starter
TrailDuty.com
PhilD's Avatar
I just like changing the trans fluid This is second time I've done it and I'm at 90k miles.
PhilD is offline
post #4 of 7 Old 05-11-2010, 03:35 PM
tkob1060's Avatar
Great idea Phil
what external filter are you using?
tkob1060 is offline
post #5 of 7 Old 05-11-2010, 03:50 PM
bodyguy's Avatar
When I changed the trans fluid on my dually I placed the suction hose in a five gallon bucket of new fluid and a hose at the cooler where I removed the suction hose in another bucket. Started the truck and let the pump do the work, not sure if its ok to do it that way but it worked great.
bodyguy is offline
post #6 of 7 Old 05-11-2010, 03:55 PM Thread Starter
TrailDuty.com
PhilD's Avatar
Magnefine. Got the idea off usmcdoc.
PhilD is offline
post #7 of 7 Old 05-11-2010, 03:57 PM Thread Starter
TrailDuty.com
PhilD's Avatar
I thought about trying that, but wondered of the suction side of the pump was in the pan or the return line. In the end I just added the fluid manually. The fluid change part actually only took about 5 minutes, the rest of the time was spent prepppring and putting everything back together.
PhilD is offline
