Video on how to change your brake pads - JKowners.com : Jeep Wrangler JK Forum
post #1 of 28 Old 04-07-2010, 06:52 PM Thread Starter
usmcdoc14's Avatar
Easy, stupid easy, it took me twice as long to do it due to video recording it easy
And if you have to replace the rotors its 2 more bolts and remove/replace the rotors
YouTube - How to change brake pads on a Jeep JK, yes even you can do it.
usmcdoc14 is offline
post #2 of 28 Old 04-08-2010, 03:54 AM
bodybrdng's Avatar
Awesome man.
bodybrdng is offline
post #3 of 28 Old 04-08-2010, 05:40 AM
Ogie's Avatar
How ironic...I just did mine last night (pimp add for Woods - I bought Hawk pads from Jeepswag.com (http://www.jeepswag.com/jeep_jk_brakes/index.html)...OK, actually I went to his house and picked them up but same difference)
Nice vid...would like to add:
Equivalent of 1/2" = 13mm
If you don't have a c-clamp, a pair of big channel locks can be used - just have the old brake pad in between the channel locks and piston - don't put the channel locks directly onto the piston. you could also wedge a screwdriver between the rotor and the old pad (while it is still assembled) and push the piston back in -just be careful not to nick the rotor (unless you plan on replacing the rotors, then who gives a crap).
Also, I recommend taking off the rotor. Good time to inspect the parking brake assembly and you'll want to scuff up both sides of the rotor's brake pad surface with 100-120 grit sand paper. This will give it a non-directional surface -better for brake pad seating. I also sand down the rust on the wheel-to-rotor mating surface and on the back side of the rotor as well. If the rotor is really warped, grooved, or has massive heat spots, it might be best to replace the rotors instead of machining being that they're fairly thin to begin with. If you decide to turn them, be sure not to exceed the minimum thickness which is stamped on the inside of the rotor.
One last note, I didn't bother putting lube on the pads' tabs. I'm afraid all that will do is attract dust, dirt; mud. I found that my pads moved quite easily without it.
Edit: One final reminder, when pushing the pistons back in, that fluid is going back into the reservoir. If your reservoir was full to begin with, it will now overflow. Do yourself a favor and buy a turkey baster and siphon some of that fluid out of the reservoir before starting your brake job. Just be very careful in not spilling any brake fluid on any painted surface. Brake fluid will dissolve paint almost immediately! Also, after completing the brake job, push down on the brake pedal a few times until you have a firm pedal BEFORE putting into drive/reverse and taking off.
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #4 of 28 Old 04-08-2010, 06:16 AM
ynkedad's Avatar
Good information...Just did the brakes on the mini-van yesterday.
No, seriously, I have a mini van also.
I Freakin' Love My JEEP!! Hey, you in the Hummer..
I Love and Miss You Brodude..RIP.
ynkedad is offline
post #5 of 28 Old 04-08-2010, 06:40 AM
RiggerMike's Avatar
Where can I get a pair of those ventilated brake changing pants?
Current Mods:
  1. Cleghorn tailpipe mod
  2. Cleghorn side step ventilation with Gold Mtn. enhancement
  3. Heartbreak Ridge bumper scuffs
  4. Goler gas tank skid mod
  5. Miscellaneous pin striping
  6. Woods evap cannister relocate (Wow, an intentional mod!)
  7. 2"BB and swapped in stock Rubi coils and shocks (thanks Seth!)
  8. Calico fender realignment and texturing
  9. Calico "explodey the side step" ez removal kit
  10. Stock Rubicon rails courtesy of JackTuttle (Thanks Jack!)
  11. Solid Axle dif covers
RiggerMike is offline
post #6 of 28 Old 04-08-2010, 10:16 AM
ynkedad's Avatar
Just curious...On average with 35's, how many miles before you guys are changing the original pads etc.
I know it depends on one's driving habbits and all. But on average..?:
ynkedad is offline
post #7 of 28 Old 04-08-2010, 10:20 AM
Ogie's Avatar
I replaced my rears at 16,000 miles which is unusually low. I still had a few mm of material to go before reaching the sensor but I don't like to run that low. When the material is the same thickness of the metal backing, that's when I change mine out. For the record, I have 35'' tires on steel rims and I do a lot of stop 'n' go driving with frequent visits to the surrounding mountains.
Vidi, vici, veni
Ogie is offline
post #8 of 28 Old 04-08-2010, 10:59 AM
riverzendz's Avatar
Man. That dude in the video swears a lot! I find this video offensive.
Thanks for posting that.
riverzendz is offline
post #9 of 28 Old 04-08-2010, 11:12 AM
bkw
bkw's Avatar
Thanks! I'm at 15k miles and I'm pretty darn close to the steel plate.
bkw is offline
post #10 of 28 Old 04-08-2010, 11:25 AM
gold knight's Avatar
Nice write-up doc
Originally Posted by Ogie View Post
I replaced my rears at 16,000 miles which is unusually low........
That seems to be fairly normal from several JK experiences. My wife is very good to brakes and the first set wore out around 20k miles. We're at 65k and still no need for front pads. ESP seems to be the culprit. YMMV
gold knight is offline
post #11 of 28 Old 04-08-2010, 11:30 AM
jrph's Avatar
Wish I had this 3 wks. ago Nice job that will help when I do the front.
jrph is offline
post #12 of 28 Old 04-08-2010, 04:02 PM Thread Starter
usmcdoc14's Avatar
my pads were 35,000mi...I shit you not and not hitting the squeekers yet
And I will sell you the special vented vehicle work on pants for $35 shipped
post #13 of 28 Old 04-08-2010, 04:58 PM
ynkedad's Avatar
Thanks for the replies..
ynkedad is offline
post #14 of 28 Old 04-12-2010, 11:32 PM
07unlimitedx's Avatar
Thanks Doc... Great video!
I just rotated my tires... gotta change my rear breaks now... go figure.
07unlimitedx is offline
post #15 of 28 Old 04-13-2010, 12:38 AM
WeGo4x4's Avatar
Wow my fronts are low and im at 27k mostly city driving. My rears have a little more than the front. I'm going to be changing both of them very soon.
WeGo4x4 is offline
post #16 of 28 Old 04-13-2010, 04:21 PM
hambone303's Avatar
Thanks for the video.
2007 Rubicon Unlimited 4D Silver, 4" Superlift
35x12.50x15 BFG KM2s, Summit Racing 15" wheels
Smittybilt XRC front bumper with XRC8 Syn
96 XJ, 8"lift, 36" Swampers, 8.8 detroit rear, lots of other mods
hambone303 is offline
post #17 of 28 Old 05-05-2010, 12:18 PM
Megalops's Avatar
I just did my front and backs today. I just passed 30,000 miles on the original ones the backs completely worn but the fronts looked pretty darn good.
Megalops is offline
post #18 of 28 Old 05-05-2010, 02:25 PM
Thanks doc. Now I figured out why I was doing this all wrong. I was trying to undo the wrong friggen bolt. Dumbass me .
JaysJK is offline
post #19 of 28 Old 05-05-2010, 06:15 PM
tkob1060's Avatar
X2 pump the brake pedal before you even start it till its firm, I had a friend back in high school that took off before getting a firm pedal he almost crashed into fence
I've changed my front twice and rears 3 times. PUT THE GREASE on the tabs they will eventually squeak if you dont. I've had to pull them off to grease them to shut damn squeaking up for the one time I didnt put it on.
Your reservoir shouldnt be full if your pads are low unless someone added fluid.
tkob1060 is offline
post #20 of 28 Old 05-05-2010, 06:35 PM
Great Video Doc.
One additional thing I do is to put blue Loctite on the caliper bolts. Wouldnt want those babies coming loose.
Your videos are really great. Many thanks,
Ron
Not planning for failure is planning to fail!
ronner is offline
post #21 of 28 Old 06-06-2010, 10:34 AM
Mr.RonGilbert's Avatar
Good vid doc, you are right about the lefty loosie thing.... a bunch of us watched this guy tighten (when he was supposed to be loosening) on of his caliper bolts - none of us caught it until it snapped.. duh.
And for good measure - hammer the shit out of everything
(the hammer part was a joke)
IMO it is a good idea to get a couple of extra caliper bolts - cheap at the stealership and might save you (or someone else) from some damage and a possible long shitty day.
part number is 68004084AA and costs $2.35 + tax = $2.54 (thanks N2)
Mr.RonGilbert is offline
post #22 of 28 Old 06-14-2010, 04:55 PM
SlowMo's Avatar
Thanks Doc great video. changed mine today. 30k miles with about 17k on 35's. It was stupid easy and saved me some $$ fo sure. Cheers
SlowMo is offline
post #23 of 28 Old 06-17-2010, 04:48 AM
Been hearing an occasional squeal from my rears recently, bought pads and went to install them and still had about 50% left. Decided to wait and will just do front and rear at the end of the summer.
2007 Redrock X two door
Auto
Hardtop
D44 rear
17" Moab wheels
32" BFG M/Ts
Rubicon Rock Rails
Airaid intake
Infinity speakers
pearl-drum-man is offline
post #24 of 28 Old 07-21-2010, 08:02 AM
Clutchfan's Avatar
its also a good time to lube your slide pins while you have everything off.
Clutchfan is offline
post #25 of 28 Old 01-31-2011, 04:58 PM
Bassman's Avatar
Thanks for the video. It does seem like a newb could do it and save big $$$. My wife's Honda Pilot is needing the same, I think I'll give it a go.
Thanks again Doc!
Bassman is offline
