Viair 400H ( 400C) torture test - Small compressor > Big results - JKowners.com : Jeep Wrangler JK Forum
post #1 of 103 Old 03-01-2010, 04:05 PM Thread Starter
Woods's Avatar
Feedback: 10 reviews
Anybody who read my thread about the speed of the 400H and 400C compressors knows that I had a little torture testing that I've been wanting to do. Finally had some warmer weather today and I've completed the torture test.
Some back story, and why am I doing this? The 400H and 400C are the same compressor, other than the fact that the 400H has an integrated on off switch. These two compressors are very interesting for two reasons. First off they are among the fastest compressors that Viair offers, putting up to 2.56 CFM. The are also among the lease expensive compressors that Viair offers. Their size makes them a natural to install in the JK engine compartment.
Viair Compressor Speed Comparison Data:
For the price and size the 400C and 400H stand out as the speed leaders, in a big way.
The big question for these compressors is duty cylce. Rated at 33% duty cycle at 100 PSI, how would they do filling tires?
My first test was filling 8 tires, connected through an air manifold to 4 tires at a time. The first set of tires were 37's on 17" rims and they were followed by 35's on 15"rims. The fill time for all eight tires was 50 minutes. So with no more than a very short break the compressor did not overheat with a 50 minute run time. Of course, I wanted to know more so... I decided to torture this little compressor and here's what I did.
My goal was to see how long the compressor would run. These compressors are are equiped with thermo-protection and automatically shut down when they get too hot. I gathered up a 20 gallon air tank, 50 foot air hose, a high quality liquid filled Wika pressure gauge, infrared thermometer and a stop watch (later on, I had to find a 5 gallon water bucket - more on that later). I installed the pressure gauge on the air tank hooked one end of the air hose to the compressor and the other end to the air tank. I turned the compressor on and let it run, until the tank reached 30 PSI. I then opened the air tank drain valve and adjusted it, to where the pressure even. I didn't have a way to keep the pressure at a prefect 30 PSI, but it never dropped below 26 psi and never went above 34 PSI. Now these things get hot. REALLY HOT. After the compressor ran for a few minutes, I noticed that the air hose wasn't looking very good. The air coming out of the compressor was heating it and it looked like it was going to fail so I gathered up 5 gallon bucket of water. I emersed the quick connect fitting and a couple feet of hose to keep the air hose cool. This wouldn't effect the testing of the compressor in any way. Every ten minutes, from the 50 minute mark on, I checked the temp of the compressor head and outside cylindar wall.
Here is the data:
Here's the graph:
Results and Conclusion:
After the compressor filled the 20 Gallon tank, it ran for 2 hours 32 minutes, then shut down. After about 20 minutes if fired back up again.
On the tire fill testing the compressor filled four 37" tires from 9 PSI to 27 PSI in 16 minutes.
What have we learned from all this? First of all, we know that this is only a 33% duty cycle compressor. But two and a half hours at 30 PSI, that's friggin great. For filling tires, the 400C and 400H represent what I believe is by far the best value for compressor based onboard air systems.
5/16 update: Torture test part duex.
This one was a different and done for the guys who have been concerned about how the 400 series compressors will run after being in a hot engine compartment. For this test I really turned up the heat. Here's the test.
After a 2 hour drive from the desert.
I set out to repeat the following steps over and over again until the thermal protection kicked in on the compressor. Fill the 2 gallon tank to 145 PSI, drain the tank to zero and repeat. I figure this is the compressor running at an average of about 110 PSI, which should really kick it's butt. I defined success for this test if it would run continuously for 20 minutes in this manner. This given I was pleasantly surprised that it ran for a total of 54 minutes. Again, the 400 series compressor kicked ass. This is the same 400H that I've used for all of my testing.
As far as tires fills are concerned, I did gather one piece of data today. If I fill the tank to 145 PSI and turn the compressor off, the tank will fill one tire from 9 PSI to 18 PSI.
Woods Storage Tub Enlargement Kit - Steering Stabilizer Relocation Kit - Evap Can Relocation Kit Muffler Relocation Kit - Tailgate Shock Kit
Buy Woods Kits at:
Woods is offline
post #2 of 103 Old 03-01-2010, 04:20 PM
Dragline's Avatar
Great test with great results. I'll be ordering 400 in the future as soon as I get a bracket. Speaking of that, you ever get the bracket issue resolved?
08 Rubicon 2DR Red Rock
Dragline is offline
post #3 of 103 Old 03-01-2010, 04:55 PM Thread Starter
Woods's Avatar
Yup
The guys from Two Track Minds have started a new company (Sinister Fab Works) and they will be selling them.
They should be shipping next week.
Buy Woods Kits at:
Woods is offline
post #4 of 103 Old 03-01-2010, 06:42 PM
bly109's Avatar
Feedback: 9 reviews
interesting data woods! I'm definitely thinking about ditching the 450 now...and getting a POWERPLANT! Hahahaahahhaaa.
You'll be hearing from me for a dual 400 setup in a few months...
bly109 is offline
post #5 of 103 Old 03-01-2010, 07:29 PM
Administrator
HITMONEY's Avatar
See you in 7 days Brashanic.
Edit: Perma gone now.
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #6 of 103 Old 03-01-2010, 07:52 PM
Good job those results are good to have when on the market for a compressor
jeepinpowerlifter is offline
post #7 of 103 Old 03-01-2010, 07:53 PM
s10x1000's Avatar
You swing that hammer hitmoney
I might have to get me one of these. The price looks good
s10x1000 is offline
post #8 of 103 Old 03-01-2010, 07:55 PM
how much that compressor cost you
qualy is offline
post #9 of 103 Old 03-01-2010, 08:11 PM Thread Starter
Woods's Avatar
400H is $214 shipped
400C is $190 Shipped
LINK
Buy Woods Kits at:
Woods is offline
post #10 of 103 Old 03-01-2010, 08:14 PM
usmcdoc14's Avatar
Dude, damm you I was trying to ban via my phone. Your quickness fucked that up
usmcdoc14 is offline
post #11 of 103 Old 03-01-2010, 08:19 PM
Openly Hostile
I'll have one of these as soon as woods gets the brackets. It will be nice not to have to worry about filling my co2 tank anymore.
Those temps don't surprise me, I burned the shit out of my hand when we testing that day lol.
SDMF is offline
post #12 of 103 Old 03-02-2010, 07:59 AM
stanford's Avatar
Viair
I bought a Viair 450c and loved it till a friend bought a powerplant and is always waiting for me to finish my last tire, maybe the 400 was a better choice?
stanford is offline
post #13 of 103 Old 03-02-2010, 08:12 AM
Openly Hostile
We tested a 450 and a 400 on my 37's and the 400 was quite a bit faster.
SDMF is offline
post #14 of 103 Old 03-02-2010, 08:15 AM
stanford's Avatar
Anybody want to buy a 450c? lol
stanford is offline
post #15 of 103 Old 03-02-2010, 08:17 AM
Slippery's Avatar
I went with the 400C due to the volume/speed, and love it. it does get hot!
Slippery is offline
post #16 of 103 Old 03-02-2010, 08:20 AM Thread Starter
Woods's Avatar
Originally Posted by Slippery View Post
I went with the 400C due to the volume/sped, and love it. it does get hot!
Yeah, I was shocked to see 300 degrees at one point.
Buy Woods Kits at:
Woods is offline
post #17 of 103 Old 03-02-2010, 08:23 AM
stanford's Avatar
Is that because its mounted under the hood?
stanford is offline
post #18 of 103 Old 03-02-2010, 08:25 AM
Slippery's Avatar
I want a way to hook up all 4 tires at one time for airing up, with possibly a cutoff regulator. Where do I get the right stuff?
Slippery is offline
post #19 of 103 Old 03-02-2010, 08:25 AM
Slippery's Avatar
No, it gets hot on a work bench. Compressing air makes heat, and this does it a lot in a small area.
Slippery is offline
post #20 of 103 Old 03-02-2010, 08:28 AM
stanford's Avatar
I have mine mounted behind the front bumper, so I dont normally feel or notice the heat.
stanford is offline
post #21 of 103 Old 03-02-2010, 08:34 AM Thread Starter
Woods's Avatar
I'm working on the four tire part of it. Nobody makes a cutoff regulator. The problem is that the regulator would need to be attached to one of the tires, as that's the only place where the correct pressure reading can be picked up.
Buy Woods Kits at:
Woods is offline
post #22 of 103 Old 03-02-2010, 08:56 AM
maverick's Avatar
Where does the Dominion Offroad 2G Tank Mounting Kit mount the tank??
https://www.jkowners.com/forum/showthread.php?p=328020
Is this current...
Brackets before the tank is installed
maverick is offline
post #23 of 103 Old 03-02-2010, 09:12 AM
i want those brackets and that tank
when when when?
jeepik is offline
post #24 of 103 Old 03-02-2010, 09:16 AM
Slippery's Avatar
OK, I'm game for a system with an in line indicator gauge that then splits 4 ways to clip-ons at the tires. I could also install an in-line pressure relief valve that blows when the desired pressure is reached. I only need to get the pressure close to head out. I could adjust the pressure manually at each tire then. Make a prototype?
Also, check out the manifold I build for the pressure relief valve, ARB system with regulator and switches, quick disconnect, etc. Changed it a little for the final install, but it fits nicely up against the firewall:
Slippery is offline
post #25 of 103 Old 03-02-2010, 09:29 AM Thread Starter
Woods's Avatar
Very nice setup you got there.
I've been working on this for a while. Not sure about the pressure relief valve. I'll have to test it for a while before I would release anything like it.
Why do you use a regulator? I was thinking about going without, but maybe I'm missing something.
My kit will mount to an accessory plate that attaches to the compressor mount bracket and the whole assembly will fit between the compressor and the coolant tank/washer fluid area.
Buy Woods Kits at:
Woods is offline
