Benchmark Designs dual battery tray support - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-27-2010, 03:00 PM Thread Starter
I just finished installing dual battery's but to my dismay the kit supply's a solid strap to support the forward end of the tray down to the shock tower. Dumb!! as the body is rubber mounted to the frame. This mount will cause flexing of the tray or fire wall that it is bolted to, something is going to brake! I made a bracket to support the tray like the OEM. Also incorporates a mount for the emissions solenoid that they forgot. I am new to this site, so if I did this pos wrong maybe some one will set me straight. If I can help with drawings or complete bracket just email me [email protected]
Doug
Doug4105 is offline
post #2 of 12 Old 02-28-2010, 05:08 AM
The Flower Guy
Tagg's Avatar
I'd be interested in seeing the dimentions because I've got the benchmark kit on the way and I'll probably run into the same problem
Jim
Tagg is offline
post #3 of 12 Old 02-28-2010, 05:32 AM
GreenAmphibious's Avatar
so just curious did you call Benchmark with your concerns? My dealings with them have been nothing but positive and if you bring these issues to his attention he usually makes changes and makes it right with you... just sayin
2015 JKU Sport Virgin
GreenAmphibious is offline
post #4 of 12 Old 02-28-2010, 05:35 AM
RubiZealot's Avatar
That's a good looking bracket, but I think it would interfere with the mounting bracket for an AEV snorkel, which I assume you don't have. :-)
Mike 2010 Rubicon 2DR | RK 3.5 X FACTOR MID ARM | ΜΟΛΩΝ ΛΑΒΕ
RubiZealot is offline
post #5 of 12 Old 02-28-2010, 09:26 AM Thread Starter
Smile
You are correct I do not have a snorkel, it is mounted to the original battery support hole plus an additional hole just forward of the original. I have only talked to john once when I ordered the dual battery kit and axle reinforcement tubes, it took about 4 weeks to get the battery kit and another 2 weeks for the tubes, no instructions with ether, Tried many times to talk to John, no answer and no returned call or email? Enough on that. The material is 11Ga. steel, I have attached the cutting drawing and the bending drawing in pdf format.
I have some extra metal left over and could mfg. a bracket or two if some one wanted me to.
Doug
Doug4105 is offline
post #6 of 12 Old 02-28-2010, 10:50 AM
The Flower Guy
Tagg's Avatar
Thanks for the drawings. I'll wait for the kit before I move forward with it.
Jim
Tagg is offline
post #7 of 12 Old 03-02-2010, 01:41 PM
Feedback: -1 reviews
Nice piece of handywork there!
Email is always the best way to get a hold of me. [email protected]
www.benchmarkdesigns.com
post #8 of 12 Old 03-02-2010, 01:48 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
Nice work
I will tell you i have wheeld our jeep with the Benchmark kit and had no issues everything is just like the day we installed it
www.jeepasylum.com
Dr.Dirty is offline
post #9 of 12 Old 03-02-2010, 02:10 PM
Looks really good.
Nice job on the bracket. I'll have to see if I can make a rough version of it. I like the idea of being able to mount everything from up top, and having some place to mount the emissions solenoid.
My only question would be, if your capable of doing that, why would you order a prefab battery tray at all?
wrangled is offline
post #10 of 12 Old 03-03-2010, 09:29 AM Thread Starter
I Guess I am basically lazy, and it was easier to buy Johns than to reinvent the wheel. It is a good design except for the brace that attaches to the shock tower.
Just thought it needed a little help after I got into the install.
Doug
Doug4105 is offline
post #11 of 12 Old 03-16-2010, 07:03 PM
Hose splice
I was just wondering what type and size of hose you used to splice the rigid plastic line going to the emissions canister.
Is it under pressure, or will any rubber line work?
I find it just too hard to try and get it to bend without kinking.
wrangled is offline
post #12 of 12 Old 05-02-2010, 11:23 AM
The Flower Guy
Tagg's Avatar
Just completed dual battery tray install
At last, and after more hours than I will admit, I finished the dual battery install. In addition to the install as outlined in the Benchmark instructions, I put in an 'L' shaped bracket which I sandwiched between the two Benchmark tray pieces to work as an evap purge solenoid bracket. I had to lengthen the electrical wires and replace parts of the rigid tubing with flexible rubber tubing to suit. Also I put a fuse block attached to the battery tie down bar. All the aftermarket mods go through this fuse bank. I also wired the relay to 'keyed' power from the lighter. The winch and the 'buddy boost' are connected directly to the aux battery. Photos show what it looks like. I have a compressor coming next week and it will be wired off the next fuse. There is quite a traffic jam of wires arround the batteries but I'm basically pleased with how it turned out.
Jim
Tagg is offline
