Monster Valve Installation - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 02-27-2010, 09:57 AM Thread Starter
rooster's Avatar
Tired of airing down and then having to air back up those tires? I am! 40's suck and it takes FOREVER!
Along comes Monster Valves. Now airing down takes about 15 seconds and airing back up takes about 30 seconds! Below is my installation.
The Monster Valve...not for the squeamish, you have to drill a 7/16" hole in your rim. Mess it up and your screwed! Go slow and pay attention.
running Poison Spyder Beadlocks the process is SLOW. Start by removing all 32 screws
Ah sucess!
punch the location you want to drill
drill an 1/8" hole
followed by a 1/4" hole
followed by a 3/8" hole
followed by a 7/16" hole
clean up your mess
You know have a 7/16" hole
rooster is offline
post #2 of 10 Old 02-27-2010, 09:58 AM Thread Starter
rooster's Avatar
Use a 1/4"x18 NPT Tap and very carefully tap your hole. I used an 11mm wrench to turn the tap. Make sure you line your tap up correctly. Use cutting oil or WD40 and slowly begin to tap your threads. You will need to go about 1/2 down the tap and insert the Monster Valve to check the depth. Remove and continue to tap until you have reached the correct length. DONT GO TO FAR! These taps have a taper and you could open the hole up to much!
Once finished you will have a cleanly tapped hole
test fit the Monster Valve
Remove the brass end cap and the red release nut. Use a 9/16" deep well socket to thread the valve into the rim.
verify the depth
remove and apply thread sealant
reinstall the Monster Valve using the 9/16" socket and thread the red release cap back onto the valve
thread on the brass end cap
The finished product. As you can see I placed the Monster Valve directly across from the valve stem. This gives you enough room to place a gauge on the valve stem and air up or down using the Monster Valve.
Reinstall the ring, let the thread sealant stand for at least 15 minutes (I let my set up overnight) and air up!
rooster is offline
post #3 of 10 Old 02-27-2010, 11:01 AM
hidX's Avatar
Killer write-up Jeff!!! I have been eye-balling these for a while now, but the process had me a little sketchy. Now I can see it isnt a big deal. Thanks...
Dave Dorsen [847-410-3750]
*Dealer inquiries welcome*
hidX is offline
post #4 of 10 Old 02-27-2010, 11:36 AM
SONIC's Avatar
Only good if you have well protected rims (IE beadlocks) but way cool!
-Doc Holiday
SONIC is offline
post #5 of 10 Old 02-27-2010, 12:11 PM
The Joker's Avatar
Great write up! I like those valves.
The Joker is offline
post #6 of 10 Old 02-27-2010, 01:43 PM
tank's Avatar
Location: Stuck in Norfolk Nebraska home of no Wheeling
could you or could you not tap the original vale steam hole?
[x] 4in la lift [x] 37in Pro comp E/MT tires [x] eagle 17in 101 wheels [x] super chips [x] ORE outlaw rear fenders [x] ORE C gussets [x] ORE magnum 44 sleeves[x] 5.38 gears
[x] RR front bumper [x] xrc 8000lb winch [x] home brew cage [x] RR front bumper [x] home brew rear bumper [x] home brew front grill guard [x] home brew tube fenders
[x] home brew rubi sliders[ ] red neck ram[ ] 2in bb[ ] 40s
tank is offline
post #7 of 10 Old 02-27-2010, 01:49 PM
Mr.RonGilbert's Avatar
Killer setup, not sure what the exact size of the standard valve is but that looks to be about triple the size.
You will be enjoying a cold one while the rest air up..
What do you use to air up?
Mr.RonGilbert is offline
post #8 of 10 Old 02-27-2010, 02:08 PM Thread Starter
rooster's Avatar
You could if you drilled it to a 7/16" side and then tap to the right threads. But the whole intent is to place a clip on gauge on one and air up or down thru the monster valve so you can monitor it as you do.
A 20lb power tank with CO2
rooster is offline
post #9 of 10 Old 02-27-2010, 03:09 PM
post #10 of 10 Old 02-28-2010, 02:30 AM
sn4cktime's Avatar
Powertanks are so fast. I've got a 4-way split air hose and it takes about 30 seconds to fill all 4 to identical pressure from 8 PSI.
I'm sure with 40" tires and those Spyderlocks, you can go a LOT lower than that and it takes a LOT more air to puff em back up.
2007 2D 6SPD JK X
sn4cktime is offline
