Buggy Build - JKowners.com : Jeep Wrangler JK Forum
post #1 of 43 Old 02-22-2010, 06:02 AM Thread Starter
Randy727's Avatar
Buggy Build
Alright, I think I am ready to start this project. I have ordered some tools to get started, and DOM tubing should be here tommorrow. I will do my best to take pictures and keep up with what I am doing. This will be a slow project as funds become available. I am still looking for a donor vehicle to strip parts off of so, I am just going to start with the chassis. Here is a pic of the chassis modeled in Solidworks. I have made some changes to it, and decided this is what I am going with. I am sure that some of it will change as the build progresses. I have not put all the bracing in it yet, just the main chassis that I am almost certaing will work. This buggy will have the same wheel base as the 4-door JK and should have the same body width. Anyways, I hope to get started this weekend.
2008 X:Pro Comp 4" lift, 35" Nitto Grapplers, Custom Front Bumper, Custom Sliders...more to come.
Randy727 is offline
post #2 of 43 Old 02-22-2010, 06:03 AM Thread Starter
Randy727's Avatar
Here are a couple of tools that I bought to start the build.
Got some DOM in yesterday. Probably not enough to finish, but will be a good start.
Laser cut the front winch plate, and floor for the back of the buggy. Will probably bend tommorrow.
Randy727 is offline
post #3 of 43 Old 02-22-2010, 06:04 AM Thread Starter
Randy727's Avatar
Got the old Bridgeport Mill set up and ready to do some tube notching.
Rear pan and winch plate bent.
Randy727 is offline
post #4 of 43 Old 02-22-2010, 06:04 AM Thread Starter
Randy727's Avatar
Started bending some tubing yesterday afternoon.
Randy727 is offline
post #5 of 43 Old 02-22-2010, 06:05 AM Thread Starter
Randy727's Avatar
After bending the frame rails I just could not stop. So I went ahead and put the lower part together. As of now I have 3 hours labor.
Randy727 is offline
post #6 of 43 Old 02-22-2010, 06:18 AM Thread Starter
Randy727's Avatar
Started adding the cab over the weekend.
Randy727 is offline
post #7 of 43 Old 02-22-2010, 06:19 AM Thread Starter
Randy727's Avatar
Randy727 is offline
post #8 of 43 Old 02-22-2010, 06:20 AM Thread Starter
Randy727's Avatar
As of yesterday afternoon, this is what I have done.
Randy727 is offline
post #9 of 43 Old 02-22-2010, 06:24 AM
JKDoc's Avatar
Ah, what you can do when you have the correct tools.
So what powerplant/drivetrain have you planned to use? Hope a 4 speed ATLAS is in the makeup. Front and rear winches? Dual steering? Air lift? What axles? Going for light weight or brute strength? Envious. Looking forward to following your build.
"Old age and treachery will overcome youth and skill", Bob Arnett
JKDoc is offline
post #10 of 43 Old 02-22-2010, 06:35 AM Thread Starter
Randy727's Avatar
I am looking for a donor vehicle for the axles, transmission, and transfer case. Looking for a 1-ton chevy. I am going to try and put this together on a budget to get it going. I will be upgrading parts for the rest of my life. Probably run a 350 chevy motor to start with. I am dead set on Dana 60 front, and probably 14 bolt rear.
Randy727 is offline
post #11 of 43 Old 02-22-2010, 07:02 AM
JKDoc's Avatar
Sounds like you are planning on 40 inch tires or bigger. Have fun.
JKDoc is offline
post #12 of 43 Old 02-22-2010, 07:10 AM Thread Starter
Randy727's Avatar
I have planned everything around 42's.
Randy727 is offline
post #13 of 43 Old 02-22-2010, 07:13 AM
OlegRock's Avatar
damn!!!.... watching this thread like a hawk....keep taking detailed pix!
OlegRock is offline
post #14 of 43 Old 02-22-2010, 07:31 AM
makemeknowit's Avatar
Subscribing as well. Itching to start a similar project but it will be next year more than likely before I can begin. I want to do two steering rocks, 4spd Atlas, powerstroke and something in the 46-54" range tire wise.
Jeepless until:.....:....
makemeknowit is offline
post #15 of 43 Old 02-22-2010, 08:06 AM
NE Wrangling's Avatar
Randy,
I'll get a link for you but the design is simular to the Murphylaw motorsport buggy that raced in the KOH. #816
Subscribed!!!! You have such a awesome wife to let you try this. You planning on running a 4 seater so the kids can go?
jk-forum, jk forum, jkforum, jeep jk wrangler, jk-forum.com, jeepforum, jk-board.com, wayoflife, 2007 jk, 2008 jk, 2009 jk, 2010 jk, jk, jk wrangler
Never argue with an idiot, they will bring you down to their level then beat you with experience.[/SIZE][/B]
NE Wrangling is offline
post #16 of 43 Old 02-25-2010, 02:49 PM
JKDoc's Avatar
Powerstrokes are great engines but heavy, maybe the Cummins 4BT.
JKDoc is offline
post #17 of 43 Old 02-28-2010, 04:13 PM Thread Starter
Randy727's Avatar
Picked these 2.5 ton Rockwell's up today.
Randy727 is offline
post #18 of 43 Old 02-28-2010, 04:20 PM
Ogie's Avatar
Man, I wish I had the space, money, time and a strong back to build a buggy. Looks like you're doing it right. Keep posting.
Vidi, vici, veni
2008 Jeep JK Wrangler Rubicon Unlimited
Ogie is offline
post #19 of 43 Old 02-28-2010, 06:32 PM
TheBeatenPath's Avatar
why does it look like there is a brake caliper on top of the diff?
TheBeatenPath is offline
post #20 of 43 Old 02-28-2010, 07:16 PM Thread Starter
Randy727's Avatar
Because there is. I guess alot of people running rockwells set the brakes up like that. I really don't no alot about these axles. As I stated above I was set on a 60/14. I just came across these axles and just could not turn them down. I have been searching all through Pirate the last few days for info. I think I am going to like these. Oh, I forgot to mention the tires are 48's. I will probably use them till I can save up for 42's.
Randy727 is offline
post #21 of 43 Old 02-28-2010, 09:29 PM
reddragons's Avatar
Looks great,
I can't wait to see the progress. I want to build one over the next year.
reddragons is offline
post #22 of 43 Old 02-28-2010, 10:05 PM
paramaniac's Avatar
Subscribed!
im gonna echo Ogie's sentiments... i wish i could pull this off!
paramaniac is offline
post #23 of 43 Old 03-01-2010, 04:29 AM
Like Randy said, it's a pinion brake, standard mod folks do on Rocks.
post #24 of 43 Old 03-02-2010, 01:36 PM
what does a pinion brake do?
post #25 of 43 Old 03-02-2010, 02:55 PM
Mikey's Rubi's Avatar
slows the vehicle down. i should elaborate: you can put a mazda rotor and toyota caliper on the pinion and it is used to stop you. i believe you can find a mercury rotor that works as well. since you probably won't be driving this type of build on the street it can be used to stop the vehicle. i guess that really doesn't have much to do with it but I haven't seen many daily driven vehicles with rockwells and pinion brakes
one more thing to add before i get flammed...i don't know if it is a very good way to stop your vehicle...it could be awesome or it could suck... the bronco i drove with rockwells stopped really freaking well from 25 mph to 0mph but that is my only experience stopping a vehicle with rocks.
Sent Via Zip Line Messenger
Mikey's Rubi is offline
