Off Road Trailer Build - JKowners.com : Jeep Wrangler JK Forum
post #1 of 25 Old 02-21-2010, 06:10 PM Thread Starter
reddragons's Avatar
Hello,
Check out some pics of my off road trailer build. I have built many trailers, but this is my first off road trailer build.
Painted with POR 15 and my test drive today
After the test drive I was very happy with the overall performance. I need to replace the chains with cables, they were too loud, I like a quiet ride. The leaf springs were a little bumpy, so I had to air down the tires for a smoother ride over the bumpy stuff. I am building two more for a couple jeepin buddies I wheel with. I think I will try air bags on my next one.
Let me know what you think.
Steve
reddragons is offline
post #2 of 25 Old 02-22-2010, 07:50 AM
are ur tires on the trailer bigger then the one on ur jeep?
but the trailer looks good.. i wish i could get one of these..
07 2dr Rubicon - Teraflex 6" LA - 37 KM2's - LoD rear bumper - Rockhard front stubby - Poison Spyder Flares - etc.
upcoming: Front D60, 40's, beadlocks.
BiGEN is offline
post #3 of 25 Old 02-22-2010, 08:37 AM
Trail Concepts Hmfic
jdemonto's Avatar
I think its an illusion because of the fenders being a bit lower than the Jeep fenders.
Jason
602-314-5356 or
jdemonto is offline
post #4 of 25 Old 02-22-2010, 09:05 AM Thread Starter
reddragons's Avatar
Thanks for the compliment,
The tires are the same size as the jeep, 35s.
Steve
post #5 of 25 Old 02-22-2010, 09:42 AM
SFCCotton's Avatar
What, no electric brakes?
Kidding, looks awesome. I like the way you have the sides and floor reinforced.
SFCCotton is offline
post #6 of 25 Old 02-22-2010, 03:02 PM
Do you use a pintel hook for the connection or a ball???
DO NOT DO BUSINESS WITH SHAFFERS OFFROAD. YOU WILL BE SORRY YOU DID..
igofshn is offline
post #7 of 25 Old 02-22-2010, 03:06 PM
Send a message via AIM to xxxxBert338
Very cool...you have a talent.
xxxxBert338 is offline
post #8 of 25 Old 02-22-2010, 03:47 PM
RODICON's Avatar
Nice Trailer!
2014 Rubicon on the build!
RODICON is offline
post #9 of 25 Old 02-22-2010, 09:06 PM Thread Starter
reddragons's Avatar
hitch
Regarding the hitch, I made two. One for off road that moves in all directions and one for on road that uses a traditional ball. Below are the unpainted pictures of the two.
On this one, I replaced the pins with bolts.
This is with the off road hitch
Thanks for asking.
Steve
post #10 of 25 Old 02-22-2010, 09:08 PM
JK Inferno's Avatar
Steve
That is a kickass design! I like it
I understand the Jeep thing
JK Inferno is offline
post #11 of 25 Old 02-22-2010, 10:22 PM Thread Starter
reddragons's Avatar
Thanks,
I was originally going to use a pintle hitch, but they are very loud off road. I don't want to hear a trailer rattling behind me when I wheel.
Steve
post #12 of 25 Old 02-23-2010, 05:11 PM
johnmcd's Avatar
Thanks for asking.
Steve
Steve,
does that joint actr like a universal joint in a socket set? That's how it looks frim the camera angle. If so, any problems in reverse?
Originally Posted by H.I.I.K View Post
Ok We need to organize a "Strippers and Blow Trail Run" It can raise money for college scholarships
Raleigh Meet and Greet,
Check the thread ------------->
johnmcd is offline
post #13 of 25 Old 02-24-2010, 08:47 AM Thread Starter
reddragons's Avatar
Hello,
No problem backing up it wont collapse, it only goes right and left.
Thanks,
Steve
post #14 of 25 Old 02-24-2010, 01:47 PM Thread Starter
reddragons's Avatar
This is the bed and tailgate lined with sanded plywood. I covered the wood with Teak Oil top and bottom to protect it. I like the look.
I really want to experiment with air bags. I may sell the trailer for the cost of the build and make another ( I enjoy building trailers and work is slow, so I have the time. Otherwise, I'll cut the hangers and install an air bag suspension.
Steve
Pics with stock Rubi wheels
post #15 of 25 Old 03-01-2010, 05:23 AM
Loki646's Avatar
Hey Red, I'd like to swap notes with ya sometime on your choice in axles and wheels. I'm having an issue with the stock Rubi's fitting on a Dexter idler hub and would like to know which rim you chose to run over the Rubi.
Loki646 is offline
post #16 of 25 Old 03-01-2010, 08:17 AM Thread Starter
reddragons's Avatar
My original plan was to use the wheels on my jeep for the trailer and they fit fine, backspacing was correct. When I decided to to use the stock Rubi wheels, I had to use a spacer, because of the back spacing. This also solved the problem of the grease cap being too large. I have seen others drill out the center of their rubi wheels to allow the cap to fit through the middle of the wheel.
Hope this makes sense,
Thanks,
Steve
post #17 of 25 Old 03-01-2010, 08:41 AM
Loki646's Avatar
Thanks,
Steve
Yea I already tried the 1.5 spidertrax spacers even they won't clear the hub. It comes in around 3" diameter and about 1 3/4 to 2" deep.
Loki646 is offline
post #18 of 25 Old 03-01-2010, 08:56 AM Thread Starter
reddragons's Avatar
Is the end of the hub 3" in diameter or the opening of the spacer?
post #19 of 25 Old 03-01-2010, 09:19 AM
Loki646's Avatar
At the face of the hub is 3" and the spacer's hub bore is only 3" for the first 1" then it reduces down to around 2" or less.
I should be home in an hour or so, I'll snap some pics to better show the problem. This was why I was asking what aftermarket wheels you were running (black ones) and what the hub bore on them were to see if they would clear my hubs.
Loki646 is offline
post #20 of 25 Old 03-01-2010, 09:32 AM Thread Starter
reddragons's Avatar
OK, I got you.
The wheels on the JK are Pro Comp 8179 and are 15 inch rims. The bore is about 3-1/8 approx.
The spacers that I found have a bore of 3-1/4 approx all the way through. That would also work for you.
Steve
post #21 of 25 Old 03-01-2010, 05:00 PM
jdemonto's Avatar
OK, I got you.
Steve
Who makes the spacers?
Jason
602-314-5356 or
jdemonto is offline
post #22 of 25 Old 03-01-2010, 09:36 PM Thread Starter
reddragons's Avatar
Jason
Hello Jason,
I sent you a PM, not sure if I am allowed to post links.
post #23 of 25 Old 03-01-2010, 10:26 PM
07unlimitedx's Avatar
Looks nice... wouldn't mind having one myself.
07unlimitedx is offline
post #24 of 25 Old 03-02-2010, 11:03 AM
dayton1999's Avatar
Steve
So, is the floor liner wood on top of solid metal or wood on top of metal frame?
dayton1999 is offline
post #25 of 25 Old 03-02-2010, 11:22 AM Thread Starter
reddragons's Avatar
I put the wood over the frame. I figuered that it can be replaced after time.
