Battery Hold Down Clamp ten-cent Fix - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 02-16-2010, 02:29 PM Thread Starter
gold knight's Avatar
I saw that thread where the guy noticed his battery was loose in the tray. I went and looked at mine and, sure enough, it was loose too.
The clamp is plastic with some ridges on the front to grip the lip of the battery. With the screw completely tight, the battery still slides back and forth freely. So here's what I did for a permanent fix.
Piece of vacuum hose (about 1/8" id??) cut the same length as the clamp. You can kind of see the ridges there, they were worn from the movement.
Put the clamp in place with the hose under the front lip and tighten.
No more free play...the end.
gold knight is offline
post #2 of 5 Old 02-17-2010, 08:31 AM
J. Kickerman's Avatar
Thanks for the write up. I'll be checking my battery today.
2009 JK Rubicon Unlimited. Rock Hard skids, Skidrow Control Arm Skids, Shrockworks bumpers. Pro Comp 2" Puck Lift.
J. Kickerman is offline
post #3 of 5 Old 02-28-2010, 07:24 PM
babiehughie's Avatar
Thumbs up
Thanks for the write-up. Got a new Odyssey and it was loose as well. Did this fix to replace my block of wood and it works great!
babiehughie is offline
post #4 of 5 Old 02-28-2010, 07:28 PM
RODICON's Avatar
Thanks!
2014 Rubicon on the build!
RODICON is offline
post #5 of 5 Old 03-01-2010, 05:47 AM
ynkedad's Avatar
I'll be checking mine today as well.
I Freakin' Love My JEEP!! Hey, you in the Hummer..
I Love and Miss You Brodude..RIP.
ynkedad is offline
