LED rock lights. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 02-15-2010, 02:54 PM Thread Starter
OlegRock's Avatar
LED rock lights.
Bought 20 LED lights from http://www.oznium.com/prewired-superflux
Then mounted 14 lights in various location under the Jeep.
Also mounted 2 Leds under the hood for some hood light.
Connected them all to one toggle switch.
Used a 5amp Fuse to directly before the battery.
These lights fit perfectly into a 3/8 drilled hole. I drilled holes in various locations under the body, put a touch of gorilla glue in the hole, and just pushed the light in. Fit perfectly. Just take rocks into consideration when mounting the lights.
Below is the wiring pattern that I used. The red line is for the red and black wire, and the green light is for the toggle switch.
BTW... the last pic is the only location I have were rocks may be a concern. I wanted lights before my front tires though. I have some spare lights just in case.
OlegRock is offline
post #2 of 4 Old 02-15-2010, 07:55 PM
sweet, i've been wanting to get something like this. it's on my list
dnusher is offline
post #3 of 4 Old 02-15-2010, 09:51 PM
jeepersheart's Avatar
looks good, are you happy with the brightness of these lights? I actually have about 20 of these same lights just waiting till some of this snow melts.
2008 Detonator 2Dr. 6 Sp.
Jersey
Crew
jeepersheart is offline
post #4 of 4 Old 02-15-2010, 10:23 PM Thread Starter
OlegRock's Avatar
they are bright enough to serve their purpose. But you can put two side by side and then they are very bright... But I think that's just a waste of money.
OlegRock is offline
