Currie Front Axle Johnny Joint Kit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 01-14-2010, 10:14 AM Thread Starter
TrailDuty.com
PhilD's Avatar
The factory bushings on the axle end of my front upper control arms were starting to show signs wear and were a bit sloppy. So I replaced them with the Currie Front Axle Johnny Joint Kit.
The instructions are very clear and detailed, so I won't go through every step, but you will need to cut and weld.
I did one side at a time and started on the passenger side.
After measuring and marking, the top half of the factory side mount was removed with a sawzall very easily.
The new Johhny joint mount fit perfectly into the lower half of the factory mount.
It was welded in place around the top and with three rosettes. An inch or so was welded at a time to prevent overheating the joint. It's a little tricky for an amateur welder like me to weld in the confined space.
The driver side factory bushing did not want to come out easily, so I removed it in pieces.
It took a little pounding with the provided tool and a hammer to get the Johnny joint mount in, but it went in easily enough. Once in, a couple of tack welds on the inside edge ensure it will not move.
Like I said, the instructions were very detailed and clearly written and easy to follow.
I can't say that I can feel any increase in vibration or road noise by having upper control arms with Johnny joints at either end.
They do help hold the front axle better, and when my tires get some imbalance from the Airsoft BB's it is far less noticeable.
They will also not bind like the factory bushings and should allow for more flex.
A very worthwhile and easy to do upgrade.
PhilD is offline
post #2 of 10 Old 01-14-2010, 07:45 PM
km2jk's Avatar
I got mine in too. To bad i didnt get any instructions. It still went easily enough though. Great product
TNT Customs
Genright
Poison Spyder
Or-Fab
River Raider
Mastercraft
Spod
M.O.R.E.
Goodyear
Diablosport
km2jk is offline
post #3 of 10 Old 01-14-2010, 08:30 PM
bodyguy's Avatar
Good deal Phil, and yeah the install is a breeze. Even with the axle out putting the driver side in took a bit and I'm not sure the weld were necessary.
bodyguy is offline
post #4 of 10 Old 01-15-2010, 05:05 AM
Mr.RonGilbert's Avatar
Looks good Phil!
Mr.RonGilbert is offline
post #5 of 10 Old 01-15-2010, 05:22 AM
RotorHead's Avatar
Looks great Phil. Another nice writeup.
RotorHead is offline
post #6 of 10 Old 01-15-2010, 07:12 AM Thread Starter
TrailDuty.com
PhilD's Avatar
Yeah I thought the same thing, but did them anyway.
PhilD is offline
post #7 of 10 Old 01-26-2010, 06:47 PM
Do you have to pull the axle to do this?
Hellbound13 is offline
post #8 of 10 Old 01-26-2010, 06:54 PM
bodyguy's Avatar
No you do not
bodyguy is offline
post #9 of 10 Old 01-26-2010, 08:13 PM
Riverkid's Avatar
Doing that to mine as well... You can tell the bushings are wasted. Managed to smack the steering box brace bolt as well.
Riverkid is offline
post #10 of 10 Old 01-27-2010, 06:45 AM Thread Starter
TrailDuty.com
PhilD's Avatar
No you do not
X2 It's simple enough to do with the axle in place. However, it would be a little easier with the axle out and if you plan on doing any other work to the axle then pull it out, but it's not worth pulling the axle out for just this job in my view.
PhilD is offline
