BenchMark Dual battery Kit install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 43 Old 01-10-2010, 05:58 PM Thread Starter
Dr.Dirty's Avatar
Feedback: 21 reviews
Im super excited about having the kit installed and ready to go. Installation was easy and we hit a few snags but over all Id say that someone with very little mechanical knowledge should feel confident in their ability to install this kit.
I am running Odyssey Batteries PC1500DT I think these will be up to all the challanges im going to put them thru (Dual winch setup is in the near future)
We had to use a few more tools than required but nothing major that most people dont already have in the tool box already.
Really the only thing that was a huge pain in the butt was the evap purge valve.
Benchmarks instructions are very well written and easy to folow thanks John.
here is a lay out of the parts.
Here is what we started with
This is the tool list required
Here is a picture f the tools actually used
www.jeepasylum.com
Dr.Dirty is offline
post #2 of 43 Old 01-10-2010, 06:04 PM Thread Starter
Dr.Dirty's Avatar
Battery removed and taking the fuse box out
Making room to get the factory battery tray out
Trimming the insulation so the new battery tray can sit flush against the fire wall
Here is a shot of the new tray in place and it slides right in
www.jeepasylum.com
Dr.Dirty is offline
post #3 of 43 Old 01-10-2010, 06:11 PM
RODICON's Avatar
Nice,what did you do with the yellow top battery?
RODICON is offline
post #4 of 43 Old 01-10-2010, 06:17 PM Thread Starter
Dr.Dirty's Avatar
Installing the support bracket was were i hit my first snag but it wasnt a show stopper. the threaded insert was stripped out because i was trying to put a standard bolt in a netric thread. So i took a hammer and punch and knocked the insert out and used a nut and bolt combo
My fuse box bracket did not line up with the holes so i had to enlarge them so the bolys would go in
Next it was time to put the batteries they were a tight fit but they look great
Now is the fun part hooking everything back up
here is a shot of the wire harness you need to tap into using the included TEE Tap
www.jeepasylum.com
Dr.Dirty is offline
post #5 of 43 Old 01-10-2010, 06:18 PM Thread Starter
Dr.Dirty's Avatar
The factory terminals need to be drilled out to accomodate the new terminals.
Finding a place to put the evap purge was a pain in the butt so i ziptied it to the fusebox for now ill build a braket for it at a later date
Here it is all installed and wired up
www.jeepasylum.com
Dr.Dirty is offline
post #6 of 43 Old 01-10-2010, 06:18 PM Thread Starter
Dr.Dirty's Avatar
The yellow top will me moved to the wifes YJ
www.jeepasylum.com
Dr.Dirty is offline
post #7 of 43 Old 01-10-2010, 06:45 PM
offroader613's Avatar
Very nice!
offroader613 is offline
post #8 of 43 Old 01-10-2010, 06:46 PM
RODICON's Avatar
Nice job.
RODICON is offline
post #9 of 43 Old 01-10-2010, 06:52 PM Thread Starter
Dr.Dirty's Avatar
thanks guys
www.jeepasylum.com
Dr.Dirty is offline
post #10 of 43 Old 01-10-2010, 07:59 PM
SFCCotton's Avatar
Looks good!
Now how about some props to the damn cameraman!
SFCCotton is offline
post #11 of 43 Old 01-11-2010, 01:03 AM
brent_f70's Avatar
Great job and thanks for posting....
brent_f70 is offline
post #12 of 43 Old 01-11-2010, 01:35 PM Thread Starter
Dr.Dirty's Avatar
Well need to figure some things out
Now the Jeep stays running when you turn the key off in th accessory position
and need to figure out a way to insulate the isolator becuse that little booger gets hot
www.jeepasylum.com
Dr.Dirty is offline
post #13 of 43 Old 01-11-2010, 01:56 PM
SFCCotton's Avatar
Got the $69 fix.
http://www.delcity.net/store/Battery...794048.a_1.t_1
post #14 of 43 Old 01-11-2010, 11:30 PM
Feedback: -1 reviews
Jeep stays running? Something's not right. Did you guys figure it out?
John
www.benchmarkdesigns.com
post #15 of 43 Old 01-16-2010, 08:00 PM
TheBeatenPath's Avatar
i think he meant as in it will start even if its ben in accessory mode awhile
TheBeatenPath is offline
post #16 of 43 Old 01-16-2010, 08:48 PM Thread Starter
Dr.Dirty's Avatar
nope the jeep does not turn off in acc mode you have to go all the way to off for the Jeep to turn off
www.jeepasylum.com
Dr.Dirty is offline
post #17 of 43 Old 01-17-2010, 05:48 AM
ynkedad's Avatar
Nice write-up!
Hope you're able to work out the bugs w/out too much grief.
I Freakin' Love My JEEP!! Hey, you in the Hummer..
I Love and Miss You Brodude..RIP.
ynkedad is offline
post #18 of 43 Old 01-17-2010, 05:50 AM Thread Starter
Dr.Dirty's Avatar
Originally Posted by ynkedad View Post
Nice write-up!
Yeah i have them narrowed down to the PCM or ignition switch
www.jeepasylum.com
Dr.Dirty is offline
post #19 of 43 Old 01-17-2010, 06:08 AM
ynkedad's Avatar
Question
Well that's good. Best of luck.
ynkedad is offline
post #20 of 43 Old 02-02-2010, 09:48 AM
dayton1999's Avatar
Dirty,
Can we get a final verdict and shots of the install? I'm thinking of running dual batteries here pretty soon and I'm wondering how your install ended up...?
dayton1999 is offline
post #21 of 43 Old 02-02-2010, 09:51 AM Thread Starter
Dr.Dirty's Avatar
Originally Posted by dayton1999 View Post
Dirty,
Its working great and I honestly couldnt be happier the fit and finish is awesome and the peace of mind having a backup battery is great. The Odysseys are a tight fit but I think in the long run it will be a great upgrade because im working on making a rear winch bumper so the jeep will have dual winches
www.jeepasylum.com
Dr.Dirty is offline
post #22 of 43 Old 02-02-2010, 09:53 AM
dayton1999's Avatar
Thanks Dirty.
post #23 of 43 Old 02-02-2010, 09:55 AM Thread Starter
Dr.Dirty's Avatar
The install directions were awesome and very easy to follow with very good pictures. so really the toughest part about this system is picking your batteries
www.jeepasylum.com
Dr.Dirty is offline
post #24 of 43 Old 02-02-2010, 04:10 PM
ynkedad's Avatar
Sweet!
Glad you've figured shat out.
ynkedad is offline
post #25 of 43 Old 03-20-2010, 08:17 PM
JKDinker's Avatar
Dirty, does your solenoid stay hot like mine does, even when you have had your jeep turned off for a while? Very warm to the touch?
JKDinker is offline
