TBP's tail gate antenna bracket - JKowners.com : Jeep Wrangler JK Forum
post #1 of 42 Old 01-09-2010, 05:33 PM Thread Starter
TheBeatenPath's Avatar
Gen 2 is on the next page if you want a diff style
well i finally got a cb for the jeep and that means i needed a mount for the antenna i didn't feel like buying one so me and my dad made one.it bolts directly on to the stock tire carrier but if you don't use that because you have a swing out then you could probably bolt it onto the tailgate it self i don't know cause that's not how im using it.
1 go to your local hardware store and get a flattened metal i believe it was aluminum. we got a 2 ft piece in case for mess ups.
2 when you go into the store bring in one of the tire carrier bolts you plan putting it on and there should be a chart to measure the thread count and size.
3 get the type bolts that it says. you want it to be about a half inch longer than the stock one to accommodate the bracket as the carrier has a little lip.
4 put a 90 degree bend near the top of the metal bar by placing it in a vice.
5 place next to the two bolts on either side of the carrier and mark the center of the bolt.
6 place the metal back in the vice and cut off the unneeded metal using a hack saw.
7 our bolts were 5/16 so we started with a smaller titanium drill bit so the big bit wouldn't walk. you can use a punch but we didn't have one on hand.
8 we used a 3/8 drill bit so the bracket would bind with the threads and its on a little angle so it works out nicely.
9 measure out the width of your cb mount ours was a 1/2 inch we put it as close to the bend without it not being fully flush. and it barely touches the 285 75 r16 on the sidewall.
10 we rounded out the edges on the bracket so it wouldnt be sharp so we put a belt sander upside down in our vice.
11 bolt it back on to either side of the tire carriers two bolts and then hookup the antenna.
12 admire
pics time
looking in from in between spokes
looking down on it
ill get some better pics of it in the daylight tommorow and ill take the spare off too.
we put on a spring with the firestick and the bracket flexes some so it would take a really sturdy branch or something to break or bend it.
it sits inside of the 16 inch stock steel wheel with about and inch until it would actually contact the wheel.
it sits in the perfect position on the right side to where you can run your cox in between the holes on the carrier.
TheBeatenPath is offline
post #2 of 42 Old 01-09-2010, 05:34 PM Thread Starter
hope you guys like it
post #3 of 42 Old 01-09-2010, 06:32 PM
crypnite's Avatar
Nice and easy, well done! Always more satisfaction when doing it yourself, eh?
crypnite is offline
post #4 of 42 Old 01-09-2010, 06:37 PM Thread Starter
thx and yes it definetly does
post #5 of 42 Old 01-10-2010, 06:13 PM Thread Starter
better pics
that is a 3ft antenna for comparison in how much it will stick above the roof line.
post #6 of 42 Old 01-11-2010, 03:49 PM
Chunks's Avatar
Looks good Corey. Great job.
08 Silver Unlimited
3.5" RE Superflex
35" Pro Comp X Muds
5.13 Superiors
Rampage front
Rancho rear
Tabor 9K
Spidertrax and stockers
Line-x
Chunks is offline
post #7 of 42 Old 01-11-2010, 04:10 PM
sniper41's Avatar
You and your dad did some nice work there- looks very good!
Jersey
Crew
sniper41 is offline
post #8 of 42 Old 01-11-2010, 07:10 PM Thread Starter
thx guys
post #9 of 42 Old 01-11-2010, 08:05 PM
The Clam's Avatar
Nice work! I was looking in there the other day thinking ... I'm gonna have to drill a little hole in the tire mount to the the antenna to mount..
not anymore!
I'm going to be doing this to mine!
TBP...
wait.. your only 18..
~ Clam
The Clam is offline
post #10 of 42 Old 01-11-2010, 08:15 PM
gold knight's Avatar
Nice work. Good idea for a simple clean install!
gold knight is offline
post #11 of 42 Old 01-11-2010, 08:17 PM
SONIC's Avatar
not anymore!
TBP...
scratch that....16
root
very nice looks good
-Doc Holiday
SONIC is offline
post #12 of 42 Old 01-12-2010, 03:40 PM
Great job.. Root
Vote - Bacon for 2012!!!
benmar2000 is offline
post #13 of 42 Old 01-12-2010, 06:02 PM Thread Starter
im rly glad you guys like it and i got it in so you didnt have to drill a hole in your carrier
just make sure the bolt is really tight because it is still holding a tire on there
post #14 of 42 Old 01-19-2010, 09:31 AM
ockgator's Avatar
I did close to same and I needed to grind a bit off one of the tire carrier braces for a flush fit.
Not many young uns learn(or want to learn) how to build stuff on their rig. WTG
Proud to be deplorable
ockgator is offline
post #15 of 42 Old 01-19-2010, 12:05 PM
lbeato's Avatar
Wish I would have seen this thread yesterday. I ordered the TF mount for mine. Nice job on yours.
2012 SLV JK Unlimited Rubicon
lbeato is offline
post #16 of 42 Old 01-19-2010, 01:04 PM Thread Starter
i like building stuff i was a big knex man
post #17 of 42 Old 01-27-2010, 06:43 PM
d'sjk's Avatar
I you sure it is a WAS....?????
I thought you still had the knex set!!
Good job!
I got a surprise for you DIY crowd coming soon too!
d'sjk is offline
post #18 of 42 Old 01-27-2010, 07:02 PM Thread Starter
Good job!
ahh i need to change it to i dont i as i have a ton of knex
cant wait on the surprise
post #19 of 42 Old 01-27-2010, 07:09 PM
jk_techcrash's Avatar
Sweet. Nice Job. I am headed to Lowes this weekend. Thanks for savin me money.
Póg mo thóin!
jk_techcrash is offline
post #20 of 42 Old 01-27-2010, 07:13 PM Thread Starter
post #21 of 42 Old 01-27-2010, 07:14 PM
MaJiK hat's Avatar
If you want to give that aluminum a nice finish, mix up some Drano crystals in a bucket of water and soak the bracket in it for a little while. It will get a nice matte finish. Watch how long you do it for though. You could almost dissolve it if you mix a lot of the drano in with the water.
Be careful, because it's a caustic solution.
MaJiK hat is offline
post #22 of 42 Old 01-27-2010, 07:20 PM Thread Starter
i like the color of it im not a big fan of really shiny
post #23 of 42 Old 01-27-2010, 10:19 PM
.:eMETAL:.'s Avatar
Great job on the write-up Corey!! And kudos to you and your dad for the DIY it came out great!
.:eMETAL:. is offline
post #24 of 42 Old 01-27-2010, 10:33 PM
yellowJKmedic's Avatar
Looks good!
yellowJKmedic is offline
post #25 of 42 Old 01-28-2010, 06:29 AM
MaJiK hat's Avatar
No, the lye and water bath gives it a nice satin finish! No shiny
This guy uses that method to strip anodizing off of aluminum parts. Just don't leave it in too long, you would only want a light bath: [scroll down his page about halfway]
http://www.focuser.com/anodize.html
I think you'll like it. Try it out on a piece of aluminum for kicks. I did it on some small aluminum parts I machined and it was a cheap way to clean them up.
Nice job BTW!
