Upper Track Bar Repair - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 12-13-2009, 07:50 PM Thread Starter
bodyguy's Avatar
Tired of the damn popping so I took the time today to get rid of it. For starters this is not completely my idea I stole some of it from crusty.
First I removed the drivers side spring and shock and then the track bar.
Prepped the mount and the washers, I used thick washers with a 1/2" hole that I drilled out to 9/16 to match the bolt. If you buy 9/16 washers the hole is much larger to allow play for normal use, i needed them to be tight.
I then mocked it all up and welded the washers
Paint
I drilled some smaller diameter 1/2" washers to add a little more strength and help distribute the load from the bolt head and nut.
The 9/16 bolt I used has fewer threads on it to keep the wear down from the threads grinding on the hole. Finished off with an aircraft grade lock nut
bodyguy is offline
post #2 of 22 Old 12-13-2009, 08:06 PM
good job I want to do this as well and change all the suspension bolts out to the less threaded ones to hopefully keep the wear and tear down on the bushings and mounts.
rob4607 is offline
post #3 of 22 Old 12-13-2009, 08:16 PM
StubEXrube's Avatar
great execution Joe, regardless of who's idea it was.
StubEXrube is offline
post #4 of 22 Old 12-13-2009, 08:19 PM Thread Starter
bodyguy's Avatar
You ready to do yours, now that you know what I'm talking about?
bodyguy is offline
post #5 of 22 Old 12-13-2009, 08:28 PM
StubEXrube's Avatar
Absolutely! I need to find some washers like that too.
*side note- the bead around that washer is really fantastic.
post #6 of 22 Old 12-14-2009, 09:18 AM
sweet....add it to the list.
BIGCAT is offline
post #7 of 22 Old 12-14-2009, 03:04 PM
TrailDuty.com
PhilD's Avatar
X2, way better than when I did mine.
I actually found that I could get an oversize bolt (5/8" I think) through the drag link sleeve and used that to help reduce any movement.
PhilD is offline
post #8 of 22 Old 12-14-2009, 03:09 PM
toddandshari'sjk's Avatar
X2, those welds do like nice considering that it probably wasn't easy to get to!!
HANG ON TIGHT...I SAW THIS IN A CARTOON ONCE...I THINK I CAN DO IT!!
08 4 DOOR, FLAME RED, 3" SKYJACKER LIFT, 325/70-17 NITTO TERRA GRAPPLERS, MOTO METAL 951 WHEELS, RANCHO REAR BUMPER/TIRE CARRIER,DAYSTAR HOOD WRANGLERS, RAINGLER GRIPS, MOPAR SLUSH MATS
toddandshari'sjk is offline
post #9 of 22 Old 12-14-2009, 05:11 PM Thread Starter
bodyguy's Avatar
I would had to have drilled it to fit anything larger
bodyguy is offline
post #10 of 22 Old 12-14-2009, 08:34 PM
Hey Joe, great work (as always). But can you describe what the origional isue was? I don't think that I've gotten any poping sound from there on mine yet. Oh, I have poping sounds, but not from there so far. Thanks!
post #11 of 22 Old 12-14-2009, 09:13 PM Thread Starter
bodyguy's Avatar
I forgot to take a picture of the hole on the back side before fixing it, it was elongated I guess cause the threads are on that side.
bodyguy is offline
post #12 of 22 Old 12-14-2009, 09:16 PM
SONIC's Avatar
Im a little lost as to how the welded on washers help?
Were your stock holes just worn out too large?
-Doc Holiday
SONIC is offline
post #13 of 22 Old 12-14-2009, 09:30 PM
Ahhhh, cool. Thanks Joe. I'll keep an eye on that then. I'll add it to the other 100 things that I have to keep an eye on under my JK Again, nice fab work, if you were in north Austin I'd be over all the time weeeeziiiing off of your skills. But I'd feed you beer
post #14 of 22 Old 12-14-2009, 09:34 PM
StubEXrube's Avatar
Dr. Pepper and Whataburger works.
post #15 of 22 Old 12-14-2009, 09:38 PM
Yeah, that's good stuff to! I like to have DP, Whataburger and then beer Its a nice rounded diet.
post #16 of 22 Old 12-15-2009, 03:52 AM Thread Starter
bodyguy's Avatar
I'm not too far out, Shawn (BIGCAT) makes trips out here. Thanks
bodyguy is offline
post #17 of 22 Old 12-15-2009, 03:55 AM Thread Starter
bodyguy's Avatar
The washers are 1/16 thick and I drilled them so that the bolt fits tight to keep any chance of play to a minimum. Yes the stock hole had worn out allowing the bolt to move even when I tightened the shit out of it.
bodyguy is offline
post #18 of 22 Old 12-15-2009, 03:56 AM Thread Starter
bodyguy's Avatar
Thanks, once you remove the sway bar link, shock and coil it wasn't too bad to get to.
bodyguy is offline
post #19 of 22 Old 01-06-2010, 09:02 PM
Did you do the axle mount also?
Hellbound13 is offline
post #20 of 22 Old 01-06-2010, 09:07 PM Thread Starter
bodyguy's Avatar
I am right now while I am installing the coilovers
bodyguy is offline
post #21 of 22 Old 01-06-2010, 09:11 PM
Let me l know how you got to the rear of the bracket, I couldn't get a welder in there..
post #22 of 22 Old 01-07-2010, 05:11 PM Thread Starter
bodyguy's Avatar
I'll fix the lower mount with this
bodyguy is offline
