Door Hangers - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 11-21-2009, 07:24 AM Thread Starter
IndianaJeep's Avatar
Door Hangers
MATERIALS:
(4) Jumbo Heavy Duty Hangers w/ Padding (50lb rating each)
(6) 3/8" x 3 1/2" Lag Bolts
(6) Washers for 3/4" bolts
(8) 1/4" x 2" Lag Bolts
(8) Washers for 1/4" bolts
2"x8"x 5' (2x10 or 2x12 would work if you have 5' laying around)
Drill Bits for wood sized: 5/16" and 7/32"
Wrench Set
Total Cost ~ $35
Build Time ~ 1.5 hrs
Step1- Decide where to mount the board, somewhere that allows your doors to hang without hitting anything. Plan on taking up 5'x5' of wall space. I placed the top of the board 6 1/2' from the floor- to allow the hooks to be at about the same level of the top of the doors when I have them in my arms.
Step 2- Locate 4 studs (16" on Center)- I always use an outlet to find a stud, there will be a stud on (1) side of an outlet.
Step 3- Pre-Drill 2 holes on both ends of board to get it mounted to the wall. Use a drill bit 5/16"- that allows the lag bolt to still "grab" into the wood.
Step 4- After mounting to wall with (2) 3/8" lag bolts and washers, pre-drill remaining (4) holes.
Step 5- Attach the (4) 3/8" lag bolts with washers, torq down good (I used my air impact wrench to speed up the process)
Step 6- Mark and pre-drill holes for the (2) outer brackets. Measuring in 1 1/2" from the outside of the board. Use the bracket as your template for the holes
Step 7- Attach the outer brackets using the 1/4" lag bolts and washers.
Step 8- Measure from your outside brackets, go in 14" on center for the inner (2) brackets. Pre-Drill and attach the same way as you did in Step 6. (Note- 14" on center is used so each set of brackets hold a Front door AND a Rear Door)
Step 9- Give the brackets the 'ol tug test before putting the doors on.
Step 10- Put front doors on first as close to the wall as you can, then the rear doors, keeping them close to the wall (better weight distribution).
OPTIONAL: I had some insulation laying around I put between the doors to keep any scratches down. If you have something similar you may want to use it.
IndianaJeep is offline
post #2 of 16 Old 11-21-2009, 09:00 AM
toddandshari'sjk's Avatar
I like this, I like how you can hang 2 doors on the same set of hooks . Maybe this will be the one I build!! Thanks for the write up!!
HANG ON TIGHT...I SAW THIS IN A CARTOON ONCE...I THINK I CAN DO IT!!
08 4 DOOR, FLAME RED, 3" SKYJACKER LIFT, 325/70-17 NITTO TERRA GRAPPLERS, MOTO METAL 951 WHEELS, RANCHO REAR BUMPER/TIRE CARRIER,DAYSTAR HOOD WRANGLERS, RAINGLER GRIPS, MOPAR SLUSH MATS
toddandshari'sjk is offline
post #3 of 16 Old 12-14-2009, 03:42 PM Thread Starter
finished paiting the hangers
I got around to bed-lining the wood and painting the brackets
I would have put a JKO decal but all i had were some black 1's and they wouldn't have showed up, so i found a Q-tec 1 laying around
post #4 of 16 Old 12-14-2009, 03:54 PM
joePILE's Avatar
love the write up man, but i hate the quadratec logo, they put that shit on everything
2008 BLACK Unlimited Sahara
and
joePILE is offline
post #5 of 16 Old 12-14-2009, 04:55 PM
JK Inferno's Avatar
only if i had full doors...
I understand the Jeep thing
JK Inferno is offline
post #6 of 16 Old 12-14-2009, 05:42 PM
RODICON's Avatar
Nice.
RODICON is offline
post #7 of 16 Old 12-14-2009, 06:59 PM
Butler20's Avatar
nice. im gonna make some of these for summer time
3.5" Rubicon Express lift
Bilstein 5100 Shocks
17x9 Mickey Thompson Classic II
35" Nitto Mud Grapplers
Smittybilt XRC Rear Bumper
Flowmaster 40 Series
48" Hi-Lift Jack
KC Slimlights long range
Rugged Ridge mirror relocation brackets
MasterCraft Grab Handles
Butler20 is offline
post #8 of 16 Old 01-12-2010, 02:16 PM
dtcc687's Avatar
i plan on making some of these when it gets nicer out
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #9 of 16 Old 01-12-2010, 06:37 PM
wow thanks for the write up...ill also be doing this once it warms up and i start taking the doors off again
BBirish is offline
post #10 of 16 Old 07-26-2010, 12:02 PM
jjbooth's Avatar
Thumbs up Door hangers
Indiana,
Thanks for the great post, well maybe not........my other half found your post and had me working all day Sunday (only kidding it was a half day) so she can hang her doors when her tube doors arrive on Friday.
Went to home depot and bought the items listed in your post with the addition of 8 lead wall anchors (installing into concrete block). My bill came to just at $60.00 for all the items. Anyway here's how it turned out........
Thanks again for the plans
JJ
jjbooth is offline
post #11 of 16 Old 07-26-2010, 12:13 PM
aislinn04's Avatar
Listen Booth, I didn't hear any complaining!!! LOL. Not to mention, I was the one minding 3 kids while the "boys" played bump swap all day Saturday. And I didn't even get a plate of nachos out of it!!!! But it did turn out great. Now get those doors on there man!!!
aislinn04 is offline
post #12 of 16 Old 07-26-2010, 01:54 PM
Nice write up!
post #13 of 16 Old 07-26-2010, 02:27 PM
jjbooth's Avatar
Damn in trouble again.....................
jjbooth is offline
post #14 of 16 Old 07-28-2010, 04:14 PM
jjbooth's Avatar
Finished product
Hangers with the door's...............used pool noodles for extra padding
JJ
jjbooth is offline
post #15 of 16 Old 07-28-2010, 09:05 PM
kenszel's Avatar
Great Idea... I didn't have the wall space so had to go another route. I built a little cart for mine.
kenszel is offline
post #16 of 16 Old 08-26-2011, 05:23 PM
Rumdrink1's Avatar
Hate to revive a old thread but what is the reason for the wood backing? My Garage is concrete, why couldn't I just tapcon the hooks to the wall?
Rumdrink1 is offline
