37x13.50x17 Toyo Open Country on OEM wheels? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 11-17-2012, 08:06 PM Thread Starter
membrain's Avatar
I'm thinking 37x13.50x17 Toyo Open Country on 2010 Rubicon OEM wheels...
I have a 4" TeraFlex lift and 1.5" spacers...
(been eyeballing pretty good prices from a non-advertiser... but also trying to get in contact with Marcus at RCO to give him a shot)
Will they fit?
Opinions please:
2010 Red Unlimited Rubicon 6 speed - Traded!
2014 Red Unlimited Rubicon X 6 speed - starting over!
membrain is offline
post #2 of 26 Old 11-17-2012, 08:42 PM
They'll fit, certainly not the first to run that setup.
Sent via paper airplane
post #3 of 26 Old 11-17-2012, 08:52 PM Thread Starter
membrain's Avatar
Thanks for the reply -
No issues with 13.5 inch width on 9 in wheels?
I'm not too worried about stuffing or rubbing yet...
.. I want these bad
membrain is offline
post #4 of 26 Old 11-17-2012, 08:57 PM
9"? The factory JK wheels 7.5" wide.
It's a poor mans Beadlock off road, but there aren't any major issues with running that setup.
post #5 of 26 Old 11-17-2012, 09:13 PM Thread Starter
membrain's Avatar
See! I knew I had something wrong.
membrain is offline
post #6 of 26 Old 11-18-2012, 08:08 AM
You will have some crazy rubbing if you take them off road. A net bs of around 3.5" would be a better fit for that size tire
post #7 of 26 Old 11-18-2012, 09:01 AM
Doesn't crazy rub. It does rub his RK arms, but not an obnoxious amount.
post #8 of 26 Old 11-18-2012, 09:05 AM
I bet there are a couple of streaks in the sidewalls on the rear of that rig from the sway bar links rubbing the tires. There must be some limits on the steering as well not rub the front sway bar and frame.
post #9 of 26 Old 11-18-2012, 09:27 AM
No rear sway bar. Has a front Rubi bar.
post #10 of 26 Old 11-18-2012, 11:44 AM Thread Starter
membrain's Avatar
(still entertaining comments)
Stock wheels with spacers will still have rubbing?
membrain is offline
post #11 of 26 Old 11-18-2012, 01:22 PM
I would not they spec wider than most do.
They are a stiffer load range E. So to get a flat contract onroad you would have to run super low air pressure.
I have them on AEV running 20-25 on road.
beedle4 is offline
post #12 of 26 Old 11-18-2012, 04:28 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
You will want to chalk test them and adjust the air pressure accordingly so you're not running on the center of the tire, but you'll be OK.
With wheel spacers you'll be at about 4.5" back spacing and it'll rub lowers at full lock when you turn but you can fix that with the steering stops. 37/1250s do the same thing at that back spacing FYI.
Marcus
RiverCityOffroad is offline
post #13 of 26 Old 11-18-2012, 10:32 PM
Abacabb's Avatar
Here's my old rig.
4" TF
37x13.50r17 Toyo
17x8 with 4.5 bs
I rubbed at full lock and ran 28 psi with no problems with the wearing.
2012 Jeep Wrangler - Gecko
3.5" Rock Krawler X Factor
Abacabb is offline
post #14 of 26 Old 11-18-2012, 10:36 PM
bthomas's Avatar
thats my steel blue above. 1.5 spacers in front will rub slightly on the arms and swaybar at full lock. 2.5 spacers in the front is perfect. still running 1.5 spacers in the rear.
bthomas is offline
post #15 of 26 Old 11-21-2012, 09:23 PM Thread Starter
membrain's Avatar
Ok, since Discount Tire won't install the 37's on my OEM wheels, who in the DFW area is the "go-to-guy" to get this done?
membrain is offline
post #16 of 26 Old 11-21-2012, 09:29 PM
bthomas's Avatar
Anywhere that's not a chain store.
bthomas is offline
post #17 of 26 Old 11-22-2012, 04:51 AM
TCdawg's Avatar
Discount won't put the tire on your wheel at all or will they not do it with the spacer?
Discount mounted my 37's, which I bought from them, although on a 8" wide aftermarket wheel. I put my 1.5" spacers on my self. They won't mess with spacers.
TC
TCdawg is offline
post #18 of 26 Old 11-22-2012, 04:52 AM
Yep, there are about 3 mexican tire shops down 380 I can think of that I don't think would care what you wanted to do.
post #19 of 26 Old 11-22-2012, 02:51 PM Thread Starter
membrain's Avatar
Discount Tire wouldn't do it just with tires and wheels.
So I guess I'll check the Goodyear garage first and then visit one of those other places.
membrain is offline
post #20 of 26 Old 11-23-2012, 06:06 PM Thread Starter
membrain's Avatar
Kudos to the local 4 Wheel Parts guys in Coppell, TX.
They didn't bat an eye when I asked them about mounting 37x12.50x17 on OEM 17x7.5 Moabs.
Shame on DT, NTB and GY, lol... but I suppose I can understand...
membrain is offline
post #21 of 26 Old 01-29-2013, 12:04 PM
what prices are you seeing?
x-rated is offline
post #22 of 26 Old 01-30-2013, 06:12 PM
TipsEZ's Avatar
How is the handling without the rear sway bar? Mine is rubbing on my coils and I was thinking of removing it but I am a die hard "Drive it to the trail, drive it home" guy.... I wasn't sure how bad it affected it.
My YJ was a no brainer. Rip off as much craps as possible so it'd at least flex like a wet log.
FC F&AM USMC
'10 JKU Rubi '94 YJ
TipsEZ is offline
post #23 of 26 Old 01-13-2015, 08:56 PM
GRIZZLY47's Avatar
Feedback: 13 reviews
For the Toyo 13.50s, on a set of 17x8.5 beadlocks, am I able to getaway with 4" of backspacing do I need to go for 3.5"?
2010 4-DOOR MOUNTAIN
GRIZZLY47 is offline
post #24 of 26 Old 01-13-2015, 09:03 PM
I would expect a bit of rubbing on the control arms and frame at full flex with 12" travel shocks but nothing to be really concerned about.
post #25 of 26 Old 01-16-2015, 12:21 PM
White13JKUR's Avatar
so this is an interesting thread.
I am currently running 37" MTR/k's on stock rubi wheels with 1.75" spydertrax spacers for a measured/verified backspace of 4.5". I get some rub on the frame and the metalcloak LCAs when aired down off road.
That said, I want to move to a set of walker evans beadlocks and have a backspacing question...
I plan to replace the MTRs with the Nittos and was torn between ordering the wheels in 4.0 bs and 4.25 bs. Sounds like 3.75 might even be the better choice? FWIW, stock width axles with no upgrade plans.
OH and BTW.... I had to go to some local mom and pop hole in the wall used tire dealer to get them mounted. no chain store (local or national) would touch the job with a 10' pole.
White13JKUR is offline
