35" with a TF leveling kit ?? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 10-19-2012, 10:46 AM Thread Starter
RINGO's Avatar
Trying to determine weather or not I"ll need to keep my Spidertrax. Have purchased a set of 35" Toyo MT"s and am waiting on 17x9 Mickey Thompson Classic II"s. The wheels that are coming off have approx 6-6.25 backspace where as the Thompson's are either 4.5 or 4.75. There's a lift in the plan (probably a 3.5 AEV) but most likely not for another year or two. So..for dd and mostly on pavement could I nix the spacers with this new set up?
RINGO is offline
post #2 of 8 Old 10-19-2012, 11:30 AM
kjeeper10's Avatar
Yes but you are going to have to trim the pitch seam. Flat or trim flares and ditch the air dam if still on the jeep.
Stay connected and on road you should be fine.
kjeeper10 is offline
post #3 of 8 Old 10-19-2012, 05:21 PM Thread Starter
RINGO's Avatar
After double checking the spec's on the Classic II's, the back space is listed at 4.5 and so I'm thinking I should be ok running without spacers. I haven't had any problem's with them just prefer not using them if not necessary. Plus the bigger tires will be thowing rocks/mud bad enough as is without the extra help.
RINGO is offline
post #4 of 8 Old 10-19-2012, 06:07 PM
kjeeper10's Avatar
You don't want to run spacers and wheels with that or less BS'ing. Just imagine the stress put on the axle/ball joints/bearings. It's not so much the width anyways, it's going to be the height.
post #5 of 8 Old 10-20-2012, 03:18 PM Thread Starter
RINGO's Avatar
Check, and thanks for the input.
RINGO is offline
post #6 of 8 Old 10-20-2012, 03:24 PM
kjeeper10's Avatar
no problem
post #7 of 8 Old 11-03-2012, 06:32 AM
I am running terraflex leveling kit with nitto305's on 4.5 backspacing only issue was hauling 3 dirt bikes trailer and 3 ppl in a 2 door wee bit cramped rubbed little in back on flares
g1shadow is offline
post #8 of 8 Old 11-05-2012, 03:19 PM Thread Starter
RINGO's Avatar
Done and no touching yet, but all she gonna see until spring is snowy-slushy pavement. Gives me time to decide on lift.
RINGO is offline
