TPS Issue - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 08-24-2012, 10:33 AM Thread Starter
TPS Issue
So I took our 2012 wrangler unlimited into the dealer this morning for the dreaded passenger door leak. After they had repaired I got a call from the dealer letting me know it was finished and asking about the TPS light being on. Long story short I explained that I had changed the 16" sport wheels out for the set of Rubicon wheels and tires that are on it now and the light had been on every since the change. The dealer explained that because I did not change out the TPS sensors the light would stay on until I had them break down my Rubicon set and get the serial numbers off the current sensors and have them programmed for our jeep. The guy also added that they were the only place around to take care of this issue and then said that this additional work would cost $130. Now I am fine with having them do this if this is correct and the only way around it, but having run in's with dealerships before I thought I would double check with the jeep community to verfiy. I would much rather spend this money on a AEV Procal if it would do the job as well. Can someone with experience shoot me some straight answers on the issue?
dwilson is offline
post #2 of 10 Old 08-24-2012, 12:18 PM
BullyWagon's Avatar
'12 have different sensors than the 07-11 Sounds like they are screwing you. As long as you have the correct sensor with the right frequency your jeep will learn the new sensors.
I too have rubi take offs on my 2012 sport... Mine are 2011s so I get the light on the dash.
Sounds like the dealer is just going to put some new sensors on.
BullyWagon is offline
post #3 of 10 Old 08-24-2012, 04:57 PM
Go to a tire store and pay to have them swapped. There is NO relearn needed.
You 12 wheels should have a soft valve stem, correct?
You will need to buy new soft stems at the tire shop 3-5 bucks each. Then have your 12 sensors mounted to the wheels your running
beedle4 is offline
post #4 of 10 Old 08-24-2012, 09:01 PM
bfj aka tambil's Avatar
Did your "new" rubi wheels have sensors? Are they from the same year as yours?
Proud to be an American
Shamed of our government
Native Floridian = MUD
bfj aka tambil is offline
post #5 of 10 Old 08-26-2012, 03:19 PM Thread Starter
Yeah, the Rubicon wheels and tires are from a 2012 as well. All I did was took my 2012 stocks off and put on the Rubicon package. The dealer is telling me that when you change out a sensor you have to reprogram the computer with the new serial number of the sensor or the tps light will never go off on the dash.
dwilson is offline
post #6 of 10 Old 08-26-2012, 03:35 PM
I was under the impression the 2012 will learn the new sensors after a short (few miles) of driving. Take it on a highway or weekend drive and the problem should work out on its own.
Assuming the new wheels have sensors installed on them lol.
jchurch is offline
post #7 of 10 Old 08-26-2012, 05:29 PM Thread Starter
Yeah, they were directly swapped off of a Rubicon with only 250 miles on it. They have been on our jeep for over 4 months. Anyone know if the pro cal could disable the TPS all together?
dwilson is offline
post #8 of 10 Old 08-26-2012, 05:38 PM
I have a 2008 and turned off my tps with the AEV Pro-Cal
post #9 of 10 Old 08-27-2012, 09:30 AM
If they are both 12, they should have the same sensors.
The only re-learn is driving 20+mph for 10-20 minutes.
beedle4 is offline
post #10 of 10 Old 08-30-2012, 10:09 PM
Banshee's Avatar
Yes the Procal & several other programmers can do it. Just set the pressure threshold to 0 & you should be fine.
Banshee is offline
