15" on 5x5 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 08-01-2012, 01:34 PM Thread Starter
15" on 5x5
Have a chance to get a deal on some used 37's but they are for 15" wheels. Anyone know who makes a set of steelies 15" 5x5? Could always use adapters too I guess. He wants 500 for the tires, or 700 with the wheels. Good deal?
Here they are.
mitter is offline
post #2 of 11 Old 08-01-2012, 02:26 PM
Jaybee1669's Avatar
buy the tires, not the wheels, unless you want to have a spacer/converter made.
Cragar soft 8's work 90% of the time on a JK.
Jaybee1669 is offline
post #3 of 11 Old 08-01-2012, 02:36 PM Thread Starter
Kinda what I was figuring. I really wasn't wanting to run a spacer. Ill check out the soft 8's.
mitter is offline
post #4 of 11 Old 08-01-2012, 03:00 PM
Discount Tire's Avatar
15" steel wheels (Cragar, Unique) will require a spacer or modification to your caliper or they will hit your brakes.
MB72's, MB Chaos 5's, MB TKO, MB Razor, Black Rock Viper, Black Rock D-window Alloy will all clear your JK brakes without spacers or grinding of your caliper.
http://www.discounttiredirect.com/di...*5-5%2F5.5&rw=
At The Store:
To Your Door:
Useful Links:
Discount Tire is offline
post #5 of 11 Old 08-01-2012, 04:36 PM
Recon!'s Avatar
15" wheels do not always require a spacer or mods. Ask around, there are people running steel wheels with 4" of back spacing without spacers or caliper grinding.
Sent from my iPhone on the toilet.
Recon! is offline
post #6 of 11 Old 08-01-2012, 05:39 PM
Catfish's Avatar
Anyone else think thsoe look like the trail duty hummer wheels wiht treadright retreads? If there treadrights you can get them "new" for not much more.....
Catfish is offline
post #7 of 11 Old 08-01-2012, 06:19 PM
Based on our test fitting 15" steel wheels and the number of returns we have had from customers that have purchased 15" steel wheels, they don't clear without some sort of modification or spacer. (neither of which we recommend) The flange created at the back side of the wheels holes hits the calipers. This is not the case with all sizes of steel wheels but has been the case with all 15" steel wheels that we have test fit.
At The Store:
To Your Door:
Useful Links:
post #8 of 11 Old 08-01-2012, 06:42 PM Thread Starter
Really? Never heard of those. Is the tread similar?
mitter is offline
post #9 of 11 Old 08-01-2012, 07:36 PM
Recon!'s Avatar
My friend is running 15 x 8 soft 8's with 4 inches of backspace and no mods or spacers on his JK.
Recon! is offline
post #10 of 11 Old 08-04-2012, 06:52 AM
Not steelies, but as mentioned above the MB72s from Discount fit perfectly in the 15" variety.
'11 JK Unlimited Sahara - 2.5 Frankenlift, ,33X12.50 Duratracs on 15" MB72s, Genright Rockers (aluminum), WURX front and rear bumpers/tire carrier, Warn winch
'01 TJ 60th Anniversary, 2" Budget Boost, 33" BFG ATs, AFW Front Bumper, Olympic Rock Bumper, Warn Engine & Steering box skid, Kilby Gas Tank Skid, OR Fab Rock Slider Bars, Rhino'd tub - GONE
murfysflaw is offline
post #11 of 11 Old 08-04-2012, 07:36 AM
JKO Dickhead
Asmmns's Avatar
I have 15" Pro Comp 8069's and Raceline Monster beadlocks... both aluminum but bot have no rubbing issues - 3.75 bs
__________________
CURE SMA !
Asmmns is offline
