285's vs. 315's on stock suspension? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 06-28-2012, 08:16 AM Thread Starter
Please don't flame, I'm new to the Wrangler family, and I've searched the entire site, but I'm having trouble finding(or understanding) a scenario that's exactly like mine, so I'd appreciate your guys' feedback.
I have a 2012 Sahara Unlimited and I'm about to pull the trigger on Ultra Gauntlets, 17x9 with the following specs:
Offset: 12mm
Backspacing: 5.47"
I'm debating between 285/70's and 315/70's Duratracs. I can't swing a lift right now, but will likely do one in the near future. In the meantime my offroading will be limited to fairly light fire roads on fishing/hiking trips.
Can I get away with the 315's on stock suspension and with that offset? I'm ok with avoiding full-lock until I get it set up, and as mentioned, won't be doing any heavy wheeling until then.
Thoughts?? Thanks for your help!
Zoso77 is offline
post #2 of 4 Old 06-28-2012, 09:08 AM
Panamon Creel's Avatar
315/70R17 are too wide for a +12mm offset and will cause steering lock rub even with modified suspensions so you would have to use wheel spacers with that width.
285/70R17 would fit
2010 JKU Sahara
Panamon Creel is offline
post #3 of 4 Old 06-29-2012, 11:03 AM Thread Starter
Great, thanks for the info. I would've guessed that with a lift they'd eventually be ok, so that's good to know.
My other alternatives have the following specs. Would these work with 315's?
Offset: -12mm
Backspacing: 4.52"
Same size 17x9
Zoso77 is offline
post #4 of 4 Old 06-29-2012, 11:06 AM
Stopher's Avatar
Either way you'll love the Duratracs!
08 "X", RC BB, 33" Duratracs, Coast 1310 front, Hellfires, Woods evap relo.
Stopher is offline
