285/70/17s on stock ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 06-20-2012, 03:15 PM Thread Starter
James.j.six's Avatar
Hey, I'm new here and looking for some help on tire sizing. My JK is currently all stock and I wanted to know if I can run 285/70/17s on the 17" stock rims? I really want to put a set of trail grapplers on and want a slightly larger tire but without a lift I not sure of any issues. Eventually want to upgrade to a 17"x9" wheel but can't quite pull that off right now so I'm looking at this size so I can still move them later. Thanks!
James.j.six is offline
post #2 of 5 Old 06-20-2012, 06:53 PM
snipedu1st's Avatar
I'm running the 285/70/17 on stock Rubicon Polished Aluminum rims. I went with Falken Rocky Mountain ATS tires & got them from Discount Tire. They'll fit the rim just fine on the rim.
The tire is wider, tough. I don't know if they'll rub on anything or not. I switched to this tire size, the same time I added my 2.5" lift and (the required) 1.5" wheel spacers. Therefore, I can't tell you if they would rub on anything or not. That would be a question for your chosen tire center.
Technical write-ups, trip photos, firearm related posts. Just finished my M416-A1 restoration!
snipedu1st is offline
post #3 of 5 Old 06-21-2012, 02:17 PM
RockMolester's Avatar
I wouldn't recommend putting a 285 on a 9-inch-wide rim - that would look rather silly. The original 7.5-inch-wide rims will be perfect for your 285's. Even 315's work great on the OEM wheels, but that's as wide as I'd recommend. If you insist upon using aftermarket wheels, look for a 17x8 instead of a 17x9.
: Daily driven rockcrawler
Nothing but the best: AEV, Rancho, MetalCloak, Synergy, Reid Racing, Artec, Warn, Cooper
RockMolester is offline
post #4 of 5 Old 06-22-2012, 04:26 AM Thread Starter
Thanks for the input. I see your point about the 17x9 looking a little odd on with that tire size. I'm thinking that the best idea might be to just stick with the stock rims for now or just wait a bit and go up to 35's after a 2.5 lift.
post #5 of 5 Old 06-22-2012, 06:12 PM
Vladivar's Avatar
285/75R17 on 17x8 rims.
2010 Sahara 2dr
Deep Water Blue
Stock (for now)
Once a King - always a King.......but once a knight is enough
Vladivar is offline
