Help with wheel/tires fit - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 06-13-2012, 12:36 AM Thread Starter
Question Help with wheel/tires fit
I have a 2012 Sahara and just ordered the following - V-Tec Raptor 17x9 +25 with BFG KM2 305/65r17, when reading up on the back space it seems that this wheel will end up with 6" backspace. When I voiced my concern to the salesman he was sure that these will fit w/o issue. Any help appreciated as they are to arrive in 3 days
bo54 is offline
post #2 of 6 Old 06-13-2012, 01:26 AM
Otnoc311's Avatar
6" of BS is a little much. If you plan on lifting it then you will have issues as most lift companies reccomend 4.5" BS or less for clearance. Looking at your tire choice it looks like a 33x12.5 and if that is true then with 6"BS you will rub the frame and sway bar. I think stock wheels are around 5.5"BS to give you an idea of how far under the jeep they will be.
aka- Brian
08' JKU on 38's... parted out and SOLD
13' JKU Rubi... On HOLD, 04' LJ to suppliment
Rise and Rise Again Until Lambs Become Lions
Otnoc311 is offline
post #3 of 6 Old 06-13-2012, 09:09 AM Thread Starter
My thoughts exactly, when I tell the saleman my concern he is sure these will work w/o issues. I am stopping by this afternoon for a test fit, as I think that the -12 wheel should be used versus the +25. Will know for sure in about 6 hours.
bo54 is offline
post #4 of 6 Old 06-13-2012, 05:43 PM
Otnoc311's Avatar
My current wheels have 3.5" bs and my last set had 4.5"bs with -8mm offset.
aka- Brian
Otnoc311 is offline
post #5 of 6 Old 06-13-2012, 05:59 PM
Panamon Creel's Avatar
I'd recommend -6mm offset for up to 35X12.5, 0mm offset also just ok at that max. tire size but may get rather tight with larger running tires.
+25mm offset might just work for the tire size you mentioned but it would be the far "outer limit" thus you'd need different rims if you ever want to go a bit larger diameter and/or width wise.
FYI stock rims have 7.5" bead width with 44.5mm offset ~6.2" Backspacing
2010 JKU Sahara
Panamon Creel is offline
post #6 of 6 Old 06-13-2012, 10:07 PM
Otnoc311's Avatar
Thanks for the info on stock, I thought it was less than that.
aka- Brian
Otnoc311 is offline
