what can I do - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-13-2012, 11:26 PM Thread Starter
oncewas's Avatar
what can I do
Okay first off I searched and found a lot of stuff but not about what I want to know. I'm looking to upgrade my tires and wheels at the same time. I'm not looking to lift or do spacers. I'd like to go with AEV Pintlers as far as wheels go but what size tires can I go with. I just don't understand. I have 255 75 r17 and I want to go up to 33s so from my searches I need to go up to 295 70 r17?
I thought the middle number was the distance between the road and the rim. Boy am I confused
2013 JK True Blue Rubicon
oncewas is offline
post #2 of 7 Old 02-13-2012, 11:32 PM
oz97tj's Avatar
First number is width. Middle number is the aspect ration of the sidewall. This part is confusing because a 75 could be drastically different with width and rim size.
On a stock suspension, 33 is about as large as you'll be able to go. Figure out what type of tire you want to go with. Go to the manufacturers website and look up the specs of the tires. They will have the width and height of the tire in inches printed out to take any confusion out of the picture for you.
Support the sport. GLFWDA.org
oz97tj is offline
post #3 of 7 Old 02-14-2012, 12:50 AM Thread Starter
oncewas's Avatar
okay that's good. not looking to go taller than 33s. just trying to understand what tire size I should be looking at.
I mean if I go with the AEV what tire size do I go with if I'm looking to be at 33?
I thought 275 75 r17 would work but I can't find that tire size anywhere. So it looks like I need to go to a 295 70 r 17 to go up to 33s. I don't get it I thought a 75 was taller than a 70.
oncewas is offline
post #4 of 7 Old 02-14-2012, 02:05 AM
there isn't a 285? You could just flat fender it with 34's and call it a day. Most 34's don't run true to size
sent using the dark side of the force
check my site out
ms5490renegade is offline
post #5 of 7 Old 02-14-2012, 03:03 AM
Otnoc311's Avatar
4lo.com has a metric tire conversion calculator.
aka- Brian
08' JKU on 38's... parted out and SOLD
13' JKU Rubi... On HOLD, 04' LJ to suppliment
Rise and Rise Again Until Lambs Become Lions
Otnoc311 is offline
post #6 of 7 Old 02-14-2012, 04:23 AM
The middle number isnt exacly the height of the sidewall (dist between road and rim), but as Oz mentioned, it is the aspect ratio used to DETERMINE the sidewall height. In other words if it is "70", then you would multiply the first number(width) by .70 to determin actual sidewall height. Double the sidewall height and add your rim diameter and you got your tire size.... or just use the tire size converter, lol. Hope this helps!!
jeep#4 is offline
post #7 of 7 Old 02-19-2012, 09:42 AM
FYI, I just put 305/70-16" on my 2012 JK.
Wheels have 4.75" BS.
No lift.
Kevin
yellolab is offline
