5.2" backspacing - will I rub? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 07-08-2016, 05:31 PM Thread Starter
I'm about to make the jump from stock wheels/tires to aftermarket. Running a 2016 JKU all stock suspension. It's a daily driver for my 8-5 and my chariot in the rocky mountains on the weekend.
I want to run 285/70r17 Duratracs on 17"x8.5" wheels with 5.2" backspacing and I want to avoid wheel spacers. My reading has told me that I will not rub the suspension, sway bar, etc - however, apparently I will have the clearance I need by a very small margin with 5.2" backspacing and I need certainty that this wont be problematic before i start shelling out the $.
Is anyone currently running this set up? Thoughts? Advise? Much appreciated!
Freddie the Pirate is offline
post #2 of 11 Old 07-08-2016, 08:26 PM
TCdawg's Avatar
Is there a reason you are choosing 5.2" BS wheels?
TCdawg is offline
post #3 of 11 Old 07-08-2016, 08:38 PM
boopiejones's Avatar
that tire size comes out to just under 33" I think you will be totally fine with 33" tires and 5.2" backspacing.
although personally i'd recommend going with a 4.5" backspaced wheel as it will allow you to install taller tires later if you want. everyone is happy with their tire choice for a few months, but it's pretty common for people to upsize tires later...
boopiejones is offline
post #4 of 11 Old 07-08-2016, 10:23 PM
No I run aev Salta with those specs and run Toyo 35/12.5-17 and no rubbing I like 5.2" bs.l of of guys running 37s on aev rims.
Jadmt is offline
post #5 of 11 Old 07-09-2016, 11:39 AM Thread Starter
Yes - I like the way my stock wheels look so I was leaning towards Quadratec Moabs (apparently I can't post a link because I'm a new member...?)
Either way, it's 17x8.5 with 5.2 BS
post #6 of 11 Old 07-09-2016, 03:49 PM
You will be fine.
Jadmt is offline
post #7 of 11 Old 07-09-2016, 11:40 PM Thread Starter
Thanks all
post #8 of 11 Old 08-05-2016, 12:22 PM Thread Starter
@Jadmt - are you running stock suspension without a lift? Any wheel spacers? Ideally I want to keep everything OEM for now (besides the wheels and tires, of course)
post #9 of 11 Old 08-05-2016, 01:25 PM
No spacers but a 3" lift. You won't be running with stock suspension with 35's without rubbing.
Jadmt is offline
post #10 of 11 Old 08-05-2016, 02:11 PM Thread Starter
Agreed - I'm trying to run 285/70r17 duratracs though (33"), it's a commuter so I need the MPG and I don't want to regear.
Research tells me that if I run 285/70r17 with 5.2" backspacing then I can keep everything else stock without rubbing the internal components or the OEM fenders. Some have told me this theory is right, and some have told me it's wrong...
post #11 of 11 Old 08-09-2016, 11:06 AM Thread Starter
Took it to the local 4x4 shop. The experts say I'm clear if I have 4.75 backspacing or less. Just ordered the Mamba MR1Xs. Thanks to all for the help.
