3.5" MetalCloak Game Changer, Overline Tube Fenders, & 37 MTRs... Backspacing... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 08-11-2015, 05:18 PM Thread Starter
So from what I can tell if I want to avoid rubbing with this setup I need to get my wheels with a backspacing of somewhere between 3.5 and 4. So I started my search.. I'm a fan of all black wheels. If I didn't have restrictions and they were good quality the kind of look I'm after is like the American Outlaw Buckshot... However, with my restrictions to fit the tire to the JKU... I'm finding my options to be limited. Perhaps I'm looking in all the wrong places... But so far this is one of the options I've found that I find decent.
http://www.summitracing.com/parts/bmf-a201615/overview/
I'd rather get closer to 4 then to 3.5 to be honest, but I'm concerned that maybe 4 will cause rubbing issues or I'll have to start adjusting the steering stops, which I don't want to do.
Anyway, my question is, does anyone have any first hand experience with this that can help direct me towards sites to look at that are likely to have the wheel options I'm looking within?
Does anyone have any feedback on the wheel listed above? It's expensive.. that's for sure.
Altonymous is offline
post #2 of 5 Old 08-11-2015, 06:00 PM
BigPrince's Avatar
Just FYI I have the same suspension, tires, and armor. I was rubbing lca/frame and bumper(rockbrawler lite) with 4.5bs. I added 1.5 spacers so now 3" bs and do not rub. If I had to do it over I'd shoot for 3.75"bs. 4 may do it but it might be close.
BigPrince is offline
post #3 of 5 Old 08-11-2015, 06:43 PM Thread Starter
Yeah that's what I'm wondering.. I'm wondering if I can get away with 4 or not. It's really freaking hard to find wheels with 3.75" or 4" of backspacing in black alloy for under $200!
Found the above a 3.5 and then these at just over 4" - http://www.summitracing.com/parts/ar...724n/overview/
post #4 of 5 Old 08-27-2015, 09:28 AM
my wheels are 17x9 4.5bs and i'm looking to at the same setup you're describing (37, GC and overlines). as much as i don't want to run a wheel spacer, bora makes them as thin as .75" and are hub centric. i'll likely go with a 1" so i'll only have to grind down the very tips of my bolts. if the wheels you want are not hub centric, bora can also customize the spacers to make it so.
just an option you have that will allow you to run the wheels you really want instead of settling for just something that won't rub.
maxboxa is offline
post #5 of 5 Old 08-29-2015, 07:57 PM Thread Starter
Definitely don't want to run spacers... Probably going Dana 60s anyway.. will chance my options pretty drastically.
So, since I'm trying to keep my total stance width at 81.5" or less. Here's how I'm figuring out the math to see total stance width. Can someone check it for me and let me know if I've messed anything up.
Dana 44
Axle: 65"
8.5 Wheel Offset: 0.75" (3.75" Backspacing)
Half Tire Width: 6.75"
Total: 80" (65" + .75" + .75" + 6.75" + 6.75")
Dana 60
Axle: 69"
8.5" Wheel Offset: -0.5" (5.25" Backspacing)
Total: 81.5" (69" + (-0.5)" + (-0.5)" + 6.75" + 6.75")
So if my above calculations are correct, I'll be best off with:
8" Wheel: +19 offset
8.5" Wheel: +12 offset
9" Wheel: +6 offset
Does that seem right?
