Cooper Discoverer STT PRO Above the Treeline - JKowners.com : Jeep Wrangler JK Forum
 8Likes
post #1 of 70 Old 08-07-2015, 11:22 AM Thread Starter
Discount Tire's Avatar
We put Cooper's new Discoverer STT PRO through the paces this past week on the scenic trails of Ouray, CO at the 9th Annual FJ Summit sponsored by Discount Tire. Those of you that have been to Ouray know that the terrain can change from one corner to the next and high altitude passes demand tires that don't slip. To us, it's a great location to put some new rubber to the test. As an added challenge, it rained nearly every day at the event so our Discoverer STT PRO equipped 2WD Tacoma had it's work cut out, or so we thought anyway.
The silica infused rubber compound provided the necessary grip on wet rocks and the asymmetrical scallops on alternating lugs, combined with the optimized 3-2 tread pattern, delivered solid traction and clean out in the slop. That said, we did find one spot on Imogene Pass that required us to get a little tug (the S-turn towards the top of the trail). The combination of slippery mud, tight turns, 2WD, and an incline was just enough to hold us up. If we would have had 4WD we would have pulled right through it.
In addition, we put approximately 1,000 highway miles on this tire making our way to and from Ouray. The tires tracked well down the road and were responsive to our steering input. There was some road noise present, but this is to be expected from an aggressive tire like this; with the windows up and the radio on, we quickly forgot about any tire noise.
We think Cooper hit the nail on the head with the STT PRO and it is an excellent option to consider for the enthusiast who spends a decent amount of time off-road but still needs on-road reliability and handling. If you're running a set of Discoverer STT PRO tires let us know what you think here; we, as well as Cooper, would love to hear from you.
Click image for 1001x1001 view
Click here for: Cooper Discoverer STT PRO Pricing and Availability
Key Features
  • 50% more protection against impact damage than standard two-ply tires through “ARMOR-TEK3” Carcass Protection
  • Maximum mud traction enabled by asymmetrical scallops on alternating lugs
  • Maintains excellent surface contact on loose terrain while increasing stability and reduced road noise through staggered 3-2 tread pattern
  • Delivers improved wet grip with silca enriched rubber compounding
For additional write-ups on the Cooper Discoverer STT PRO, check out the links below.
At The Store:
To Your Door:
Useful Links:
Discount Tire is offline
post #2 of 70 Old 08-07-2015, 01:39 PM
About time you guys got these in. I wish Cooper would make more of the common Jeep sizes with black side walls instead of the ghey raised white letters. (Yeah i know they can be turned to face the other way) I'm also on an active campaign for it to be offered in 255/80R17. I like my pizza cutters.
Spaste19 likes this.
IndyJLH is offline
post #3 of 70 Old 08-07-2015, 02:33 PM Thread Starter
Thanks for the comments, Indy. Tall and narrower is definitely increasing in popularity; I'll pass your suggestion along.
At The Store:
To Your Door:
Useful Links:
post #4 of 70 Old 08-08-2015, 07:33 AM
Yeah, right now it looks like the only real options for a 255/80R17 are the Cooper ST Maxx and the BFG KM2. I don't understand why there aren't more choices in this size. This is a popular size for 3/4-ton and 1-ton trucks with DRW too.
IndyJLH is offline
post #5 of 70 Old 08-08-2015, 08:26 AM
Boosted's Avatar
These tires are bad ass. I've had a couple of sets (315/70R17's and 37x12.50R17's) for a while now and have wheeled the 315/70's. They performed surprisingly well for an E rated tire and the sidewalls flexed better than expect. The 37's will do even better. Wet and dry traction offroad is amazing and on the street as well.
The STT Pro's are definitely my new favorite tire and I would recommend them. I am hoping they release a 40 soon as that's what I need for my latest build.
Boosted is offline
post #6 of 70 Old 09-04-2015, 09:39 AM
Just put a set of these on my JK the other day - replacing my Nitto TGs. With about 60 miles of road time thus far... far too early to offer any real experience feedback. But so far, I like them. I really like the tread pattern and from what I can tell and based on experience with many other designs I've had in the past, I think these are going to offer a nice balance of on/off road performance.
I've got an 18" wheel... so was limited to a 325/65 in the ~35" flavor (as calculated 34.6").
I'll be hitting the trails later this month... if I remember to do so, will offer more feedback afterwards.
SJDano is offline
post #7 of 70 Old 09-04-2015, 10:05 AM Thread Starter
Thanks for the feedback, guys!
At The Store:
To Your Door:
Useful Links:
post #8 of 70 Old 09-04-2015, 06:39 PM
Bacon's Avatar
I really like the look of these tires. Anyone know the weight of a 37x12.50x17?
08 JKUR
Just an asshole with a Jeep....
Rancho+AEV+Rubicon Express+Rock Krawler+Synergy+Warn,+Rough Country+Cobra+Banks+Magnaflow+Superchips+Bestop+Po ison Spyder+EVO+G2+Mopar+Yukon+WTO+Level 8+Coopers+garage wontons
Bacon is offline
post #9 of 70 Old 09-04-2015, 06:40 PM
Bacon's Avatar
Road noise comparison between the Trail grappler and stt pro?
08 JKUR
Bacon is offline
post #10 of 70 Old 09-04-2015, 06:43 PM Thread Starter
83lbs
At The Store:
To Your Door:
Useful Links:
post #11 of 70 Old 09-05-2015, 05:23 AM
I would think the STT Pro would have less road noise due to it having a 2-3-2-3 center lug pattern. This should breakup vibration nodes that contribute to noise. The Nitto Trail Grappler has a repeating 2 lug center pattern so I would think it would be more prone to noise generation.
IndyJLH is offline
post #12 of 70 Old 09-05-2015, 06:22 AM
Bacon's Avatar
Originally Posted by Discount Tire View Post
83lbs
Thanks.
08 JKUR
Bacon is offline
post #13 of 70 Old 10-05-2015, 05:41 PM
Bumpstick's Avatar
I'm interested in trying these but, I'm nite looking for how they do on road. How do they compare to my Irok ND's?
Bumpstick is offline
post #14 of 70 Old 10-05-2015, 06:14 PM
RedRubiconLJ's Avatar
So how much weight did they take to balance? How do they do on road as far as balancing shake shinny wobble?
Highway speeds are important too....
RedRubiconLJ is offline
post #15 of 70 Old 10-05-2015, 10:53 PM
Anyone know how tall the 37's are compared to the nittos?
aus-jeep is offline
post #16 of 70 Old 10-06-2015, 05:10 AM
Size avail for 35x12.50r17?
Slickonice is offline
post #17 of 70 Old 10-06-2015, 11:29 AM Thread Starter
We haven't seen a side by side comparison but Cooper and Nitto truck tires tend to run pretty true in size.
Cooper is not building the STT PRO in the flotation 35x12.50R-17 size (maybe in the future?), however they do have the LT-Metric equivalent available. See the link below for details.
At The Store:
To Your Door:
Useful Links:
post #18 of 70 Old 10-06-2015, 01:00 PM
Boosted's Avatar
On road performance is great....I would say comparable to an aggressive AT like a Duratrac.
Balanced well with no shake, shimmy or wobble. Highway speeds are not a problem
Not sure about Nitto's but the 37's measured out at 36.8" with 28lbs of air pressure.
Love these tires so much I even got a set of 285/70R17's for my daughters Willys.
Boosted is offline
post #19 of 70 Old 10-06-2015, 01:06 PM
Wow! They look absolutely amazing on those rigs!
post #20 of 70 Old 10-08-2015, 09:25 PM
Hopefully I'll have them mounted and balanced tomorrow!
Rmiller31 is offline
post #21 of 70 Old 10-09-2015, 08:56 AM
Looks sweet! What size?
CrazyLarry is offline
post #22 of 70 Old 10-09-2015, 09:07 PM
a_ridder's Avatar
37x12.5 on rubicon wheels and 2.5" Rock Krawler springs
a_ridder is offline
post #23 of 70 Old 10-09-2015, 10:18 PM
37x12.50
I got them mounted today and I've got some rubbing in the rear. I smashed the plastic bumper last weekend wheeling which caused it to stick out some. I'm going to cut the fenders and bumper soon.
post #24 of 70 Old 10-14-2015, 06:00 AM
Did you have to run spacers with the stock wheels to prevent rubbing? How tall do they measure out and at what pressure? Thanks.
IndyJLH is offline
post #25 of 70 Old 10-14-2015, 10:42 AM
Boosted's Avatar
They measured 33" tall at 35psi. No spacers needed but we are running Poison Spyder Customs 1.5" spacers for aesthetics.
Just picked up a set of 295/70R17's to throw on because my daughter wanted to go taller. Off the Jeep they look much bigger but my guess is we will see about 1/2" more once they are mounted.
Boosted is offline
