17" or 18" wheel - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 04-26-2015, 06:54 AM Thread Starter
17" or 18" wheel
This is my first post. I am looking at wheel and tires for my 2013 Rubicon. I really like the XD rockstar II wheels, but in 18" they only sell them with 0 offset. They do make a 17" with the -12 offset. Then I found rugged ridge wheels in an 18" with 4.75 offset. What are the pros and cons of 17 vs 18? I can assume the 17 is the better choice maybe because of the bigger sidewall? Educate me please.
bowtech50 is offline
post #2 of 3 Old 04-26-2015, 08:52 PM
SilverBulletJKU's Avatar
I have 17s and they are great! The sidewall length is a concern if you wheel it. If you drive it more than 98% on road go with a smaller sidewall tire to help with handling. A bigger sidewall will help when you air down, you will get more flex with the tire.
SilverBulletJKU is offline
post #3 of 3 Old 05-14-2015, 11:45 PM
17's will perform better off the road when aired down. For street use, 18's will perform a bit better because of less sidewall roll in turns. I recommend getting 17s because you will have more choices and there's a lot of demand for this wheel size if you plan to sell them in the future. Try to check out the ATX-- http://4wheelonline.com/ATX_Wheels.137603 since XDs are pretty common.
karlduke is offline
