What gear for 37s - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 03-24-2015, 06:35 PM Thread Starter
What gear for 37s
I need to know what diff gears to use with 37 13.50 20 on a 2014 Wrangler sport with an automatic. Mostly highway driving at 65mph with light trail use.
matulasport is offline
post #2 of 19 Old 03-24-2015, 06:38 PM
I'm personally going to go to 4.88's in my 2014. At 70 mph the chart shows to be about 2750 rpms which is a hair higher than my stock 4.10s on the stock rubicon tires.
I'm currently running 37 mt/r k with 4.10s and at 70 mph I'm at 2250 in 5th gear and it sucks. If I down shift to 4th it hits about 2700 and feels perfect power wise.
stretch79 is offline
post #3 of 19 Old 03-24-2015, 06:55 PM
wingnut2u's Avatar
Since you have a Dana 30 up front 5:13 is as high as you can go. You will still have to turn off overdrive at highway speeds but there will be enough power for you to get around town without it being too much of pain. You will have no problems in 4lo
I have 5:13 gears on mine and I am running 37x13.5r18 Toyo Open Country MT's. Mine is 2007 with the crappy 3.8. Not sure what differences there are with the 3.6
wingnut2u is offline
post #4 of 19 Old 03-24-2015, 07:22 PM
Look at gear charts. The sweet spot (fuel economy vs performance) is 4.88 for the 3.6. With the 3.8 you needed to gear as low as possible.
spinlock is offline
post #5 of 19 Old 03-24-2015, 08:50 PM
CamoCop's Avatar
if I were you I would do the 5.13's with your automatic. if you had a standard I would say 4.88's.
as mentioned above I have the 3.8 which is lower on HP and torque compared to the 3.6. i'm running an automatic and 5.38 gears which is almost perfect. I wouldn't have minded being able to go a little lower.
www.4ws.com has great deals on gear packages. they are also a site sponsor.
2011 Wrangler Unlimited Rubicon
- 3.5" Rubicon Express lift /w 1.25" BL
- 5.38 Yukon gears
- 40" Pro Comp MT2's
- Lot's of extra's
CamoCop is offline
post #6 of 19 Old 03-24-2015, 08:56 PM
You do realize that the newer auto trans 5th gear is lower than the manual trans 6th gear right? http://www.wanderingtrail.com/Mechanical/gearratio.html
post #7 of 19 Old 03-24-2015, 09:06 PM
CamoCop's Avatar
lol, no I didn't. my buddy is running 4.88's /w 35" tires on his 2013. usually the auto tranny's are geared higher than the manual tranny's.
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #8 of 19 Old 03-24-2015, 09:37 PM
Ronson's Avatar
Everytime someone asks for gear advice the answers are always all over the place. I would try to drive someone elses Jeep with lower gears to see how you like it.
The 12+ autos do better geared taller than the earlier ones. I personally like my auto with 4:10s/35"s and I would hate it if it was too low(been there on another vehicle). We do have 75mph speed limits though.
Ronson is offline
post #9 of 19 Old 03-25-2015, 06:30 AM Thread Starter
Thanks guys for responding, hey Ronson what is your RPMs at 65 MPH?
post #10 of 19 Old 03-25-2015, 05:46 PM
I understand your point but driving a Jeep with big tires and a gear ratio that is too low like some of the 3.21 + 35+ folks is not much better. Performance is really subjective for many, so it's better to look at the right gear chart and make your own decision unless you are just looking for some to help you rationalize not regearing.
spinlock is offline
post #11 of 19 Old 03-25-2015, 07:58 PM
Ronson's Avatar
I totally agree and that chart Is very useful, especially with the specific model year specs Included.
By too low I meant numerically low. I've had vehicles that would barely go 60 and get 7mpg. Geared tall is just as bad. A buddy of mine is constantly shifting from high to low range on easy dirt roads because he can't pull a hill in high range with 3.08s and 33s.
I will have to see what rpms I pull at 65. I do know I can get the "eco" light to come on at 75mph if I have a steady foot on flat ground.
Ronson is offline
post #12 of 19 Old 03-26-2015, 12:47 AM
Trail Concepts Hmfic
jdemonto's Avatar
We find the 4.56 gears work best with 2012-current 3.6 auto jeep's on 37's. If it's just a trail rig then I am sure you can go lower. Most of our customers use their jeeps on the hwy.
Jason
602-314-5356 or
jdemonto is offline
post #13 of 19 Old 03-26-2015, 02:13 AM
UnlimiDozer's Avatar
2012 Unlimited auto here with 37s and 5.13s. Ran with the OEM 4.10s for a while and it was tolerable from a performance perspective, but at freeway speeds, was searching between OD and 4th too much.
@jdemonto, that really surprises me that you find 4.56s to work well with 37s. I think the 5.13s are perfect.
@OP, what many do not consider, and what a mathematical chart cannot tell you, is that the larger the tire/wheel combo, the more your drivetrain will be having to overcome inertia. Especially with the auto, that means you actually want a ratio that is slightly lower (numerically higher) than the numerical charts suggest should give you the same RPM. In other words, the same RPM will feel different, and perform different with 32s than it will with 37s because of the additional rotating mass creating a flywheel effect. I have the info somewhere for the RPM on my setup. I'll search for it and edit if/when I find it.
Edit: Well, I searched and can't find a specific RPM, but I do know that at 70 MPH, my current setup runs only about 250 RPM higher than it did with stock Rubicon tires and 4.10s.
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #14 of 19 Old 03-28-2015, 06:08 PM
I was about to regear to 4.88s myself and started thinking about this ^^^ myself. Do I want "stock performance" on a big heavy 37? Gonna need a few more horses to get those bad boys moving and keep them moving especially on long hills on the freeway.
I currently have a 2013 auto w/ the 3.6, 4.10s, and 33.75" Duratracs and I'll still get 4000-5000 RPM drops on windy days and long hills on the freeways here in D/FW.
I'm thinking 5.13s for me when I make the jump to 37s...
flomingo is offline
post #15 of 19 Old 03-28-2015, 07:34 PM
Jonboy's Avatar
I'm running 37's on a 2012 manual and went for 5.13's. All the folks I know with autos and 37's are at 4.88 with the 3.6L.
Chart should tell you all you need to know.
Jonboy is offline
post #16 of 19 Old 04-05-2015, 03:29 AM Thread Starter
Thank you Jonboy for posting the chart, very helpful.
post #17 of 19 Old 04-13-2015, 11:28 AM
ratchettt's Avatar
I think your choice is between 4.88 and 5.13. If you can't find anything to drive with your engine/transmission, 37's, and those gears to compare, you'll have to take what I call a leap-of-faith decision. I was between 4.56 and 4.88 for my 35's, went 4.56 on faith and it worked out perfectly. Good luck.
PS................based on your opening post, I think 4.88 is your probable best gamble.
2013 JKR, Auto, Yukon 4.56, Nitto Trail Grappler 35/12.5/17 on XD222 KMC Enduro Beadlocks,Teraflex Big Brakes & Spare Carrier, Warn RC Winch, Metalcloak Front & Rear Bumpers, Metalcloak Overliner Flares & Front Inner Fenders w/ Corner Guards/Tail Lamps, Metalcloak Game Changer 2.5" w/6-Pac's, ARB Diff Covers & Onboard Air, AFE High Tuck Muffler, Front Lower Control Arm Skids, Artec Aluminum Skid System, Poison Spyder Hood Vents, Ripp SC.
There are no winners here; just beguiled participants
ratchettt is offline
post #18 of 19 Old 04-13-2015, 11:59 PM
I went 5.13 with 37s, but I chose to go a little lower geared (numerically higher) to get the benefits crawling rocks on the trail. I would personally not run 37s just for "mostly street and occasional light trail".
Also before tossing 37s onto a Sport, make sure you read around to understand what other parts you may need to beef up or address (or realize they are going to break or wear much faster).
2014 JKR "Bob" - RK X Factor 2.5, Nitto Trail Grapplers 37x12.5x17, Auto, 5.13, Rock Hard Skids, PS HD Cross member, Artec Axle Armor F&R, Artec Rear LCA Mounts/Skids, Synergy Rear Axle Side Weld on TB Bracket, PSC Hydroassist
queenmallcrawler is offline
post #19 of 19 Old 04-14-2015, 09:09 AM
jdemonto's Avatar
Here is 65 with 4.56 gears in 5th gear on the edge of the Eco
2013 3.6 auto 37" nittos
602-314-5356 or
jdemonto is offline
